I am using Acrobat Pro 2017 Mac version under OS 10.14.1 since today.
The program does not print and shows the following:
Translation: 1. The document could not be print.
Translation: 2. No page chosen for printing.
Since I have installed Acrobat Pro 2018 my other program Acrobat pro version 11.0.23 shows the same problem.
I should be grateful if somebody could help. Its annoying.
Thanks in advance.
Kind regards.
Norbert
I do not know what happened. hHen I started the computer the next day, the
problem had vanished.
The ghost in the machine had been gracious.
Kind regards.
Norbert
Hi Norbert,
Sorry for the delay in response to your query.
Looking at the information given above, it seems none of the version has helped you printing the PDF properly. Could you please confirm the printer specification? Or try printing any document using any other application installed on your computer?
Akanchha
Thank you!
The problem is solved.
Kind regards.
Norbert
Hi Norbert,
Glad to hear it worked for you.
Thanks for taking out time and updating the discussion. Would you please help us with your findings or let us know which troubleshooting step exactly solved the problem?
-Akanchha
Kind regards.
Norbert
At times simple restart of the computer fixes many complicated issues. This is the first step we should try to see whether that helps or not.
-Akanchha
