I'm having a problem integrating .NET on the Windows 2003
Server with CF 8 (8,0,1,195765). As a test I tried two well known
.NET examples:
From Ben Forta:
<cfobject type=".NET" name="sidiClass"
class="System.IO.DriveInfo">
and from tutorial11.learncf.com:
<cfobject type="dotnet" name="test" class="CfSample"
assembly="C:\ColdFusion8\wwwroot\av\CfSample.dll"> (assembly
argument pointing to the correct path)
Both of the above examples work OK on my two dev servers:
XP+CF8 and Vista+CF8.
The production server throws the following: Class CfSample
not found in the specified assembly list (Class System.IO.DriveInfo
not found in the specified assembly list. - for Ben Forta's
example).
If I stop the ColdFusion 8 .NET service, I'm getting the same
error....
Here is what I installed:
1. .NET Framework 3.5
2. CF801-DotNetIntegration
Rebooted.
ColdFusion 8 .NET service running.
Under jnbridge folder, file
'Adobe_ColdFusion_8_.NET_Integration_Services_InstallLog.log'
indicates that all inastallation steps were SUCCESSFUL.
I also checked the neo-dotnet.xml, and all seems to be OK:
<?xml version="1.0" encoding="UTF-8"?>
<wddxPacket version="1.0">
<header/>
<data>
<struct type="coldfusion.server.ConfigMap">
<var name="port">
<string>6085</string>
</var>
<var name="protocol">
<string>tcp</string>
</var>
<var name="install_dir">
<string>C:\ColdFusion8\jnbridge</string>
</var>
</struct>
</data>
</wddxPacket>
I changed both services: ColdFusion 8 Application server and
ColdFusion 8 .NET to log on as administrator but this has not
helped either.
I'm out of options now...
