3 Replies Latest reply on Dec 6, 2018 1:27 PM by Adorobat
    newly installed Pro 2017 opens pdf, unable to edit as converts to scanned image
    malcj6047725 Level 1
      In Acrobat XI I was able to edit existing pdf documents, both text and images. Now with Pro 2017 installed an existing pdf that contains an image and text opens fine, but as soon as I select edit tools it converts the file to a scanned image and I am unable to select separate entities to edit them, although the text recognition is good and is editable. If I take the same document and add some text to it in Acrobat XI and then import it all is fine and I can edit as I used to be able to.
