I am beginning to think this is not possible. The code is
below. The images are their but the two side ones are not showing
up or they do not even work like the top leaves. I even dropped the
2 layers lft & rgt inside the top layer that does work and the
top layer still works but the other 2 still don't, puzzling. Here
are the link
http://www.lasalleboat.org/index2.htm
On number 2 the links do not work the leaves layer/DIV/AP
Element is above the links layer
http://www.lasalleboat.org/index3.htm
On number three the links work but they move over the graphic
and the links layer is above the leaves layer
I have tried adding two more layers one on each side of the
page and put thin graphics.png in the layers so they clear the
links and made the leaves graphic crop at the bottom of the trees
line so it cleared the links neither of the two layers I added will
work or show up withe code below so I tried putting the two lft
& rgt layers inside the leaf layer and resize the leaf layer
and that kind works but not you can see this at the next link.
http://www.lasalleboat.org/index4.htm
Any suggestions welcome.
INVT
Attach Code
