1 Reply Latest reply on Jan 12, 2009 9:47 AM by W_Bell
    Dynamic TextArea cut-off when scrolling
    W_Bell Level 1
      I have a fixed size for the text area, and using html formating.
      The top CSS will not format the margin or padding.
      Also the last paragraph of text gets cut=off half way through it.
      I thought I saw something in the doc but I can't find it now.
      Anybody had this problem?
        • 1. Re: Dynamic TextArea cut-off when scrolling
          W_Bell Level 1
          With html = true:
          Padding on top and the bottom does not seem to work but on the sides it does work.
          The cut-off text was due to using the & symbol in html tagged as &
          The cause the text to end. Simply removed it and used "and" then it worked.
          The space for the first row needs white space so inside the html tag just line feed
          down one and all looks fine.
          How this helps someone else.
