1 Reply Latest reply on Mar 19, 2008 7:50 AM by theNOCer
    HTTPService and JSON
    theNOCer Level 1
      I am trying get dynamic data into my charts using mx:HTTPService to get a JSON. I have used the flex 3 help and combed the forums to get this far but i am now stuck.
      here is my code
      quote:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" viewSourceURL="srcview/index.html"preinitialize="srv.send();" >
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.rpc.events.ResultEvent;
      import com.adobe.serialization.json.JSON;
      import mx.controls.Alert;
      import mx.utils.ObjectUtil;
      [Bindable]
      private var expensesAC:ArrayCollection = new ArrayCollection( [
      { time: "1-24 19:00", cal: 2000, tva: 1500 },
      { time: "1-24 20:00", cal: 1000, tva: 200 } ]);
      private function onJSONLoad(event:ResultEvent):void{
      Alert.show("onJSONLoad called!");
      var myData:String = String(event.result.DATA);
      Alert.show("data worked");
      // Alert.show(myData);
      // myText.text = myData;
      // var ary:Array = (JSON.decode(myData) as Array);
      // var dp:ArrayCollection = new ArrayCollection(ary.data);
      // linechart.dataProvider = dp;
      private function failed():void{
      Alert.show("Fail!!");
      ]]></mx:Script>
      <!-- HTTP SERVICE -->
      <mx:HTTPService id="srv" resultFormat="text" showBusyCursor="true"
      url="-MySever-/readings.jsp"
      result="onJSONLoad(event)" fault="failed()" />
      <!-- CHART STUFF BELOW -->
      <mx:TextArea id="myText" y="310" width="600" height="250" />
      <mx:Panel title="ISO Hourly Demand" height="300" width="600" layout="horizontal" >
      <mx:LineChart id="linechart" showDataTips="true" dataProvider="{expensesAC}">
      <mx:horizontalAxis>
      <mx:CategoryAxis categoryField="time" />
      </mx:horizontalAxis>
      <mx:series>
      <mx:LineSeries yField="cal" form="curve" displayName=" Calforina" />
      <mx:LineSeries yField="tva" form="segment" displayName="TVA" />
      </mx:series>
      </mx:LineChart>
      </mx:Panel>
      </mx:Application>
      So when i run this i get the Alert "onJSONLoad called!" but not the "data worked".
      when i run the service in my browser with firebug i get a response that looks like so
      quote:
      "CALIFORNIA" : {
      demand : [ <list of ints> 40, 41,42,43, ect ],
      baseline : [ <list of ints> 40, 41,42,43, ect ],
      numReadings : [ <list of ints> 40, 41,42,43, ect ]
      "ERCOT" : {
      }, ect...
      so i seems fairly obvious that the problem lies in the "var myData:String = String(event.result.DATA);" line. To be honest i pretty much took this line right out of the help file so i have no idea what is wrong with it. help?
      Thanks and good day
