I Click on the signature box to sign and I get a black translucent screen that locks down Acrobat PRO DC.
I now have to activate task master to end task.
How do I configure !PRO DC to allow me to sign.
Hi Richie,
As you have mentioned above, when you click on the signature box a black translucent screen appears.
Try once to create a test file and add a signature field to it.
Then try to add a signature using the same steps and check if the behavior is replicable.
Let us know how it goes.
When the black screen appears, do you see anything mentioned on that screen or any error message that appears on the window?
Did you check if this issue occurs with this particular document or with all?
Would you mind sharing the screenshot of the window that appears?
To share the screenshot, use the steps provided below:
- Click on the insert icon provided in the reply window as shown below:
- An Insert Image window will appear.
- Then click on Insert Image and browse the location where you have saved the screenshot file.
- Select the file and click on Open > Insert Image.
Please also share the information as asked below:
- Application version
- OS on the machine
- Steps to replicate the issue
- It would be helpful if you can share the PDF with us. ( you can share the PDF either here or in a private message as well How Do I Send Private Message)
To share a PDF, use the steps mentioned here How to share a file using Adobe Document Cloud
Let us know if you need any help.
We will be waiting for your response.
Regards,
Meenakshi
Dear Meenakshi,
I followed your instructions but no avail. I still produce a black translucent screen. Here are answers to your questions.
Richie's Answer: No
Richie's Answer: This occurs with every PDF I sign with PRO DC; however, I can sign documents using Reader
Richie' Answer: Attached Shared Files - Acrobat.com
Thank you for sharing the details.
I did check the files that you have shared.
When we click on the signature field, the black translucent screen appears and then pop-ups the "Sign with Digital ID" window.
As you do not get that window in Acrobat Dc, please try once to repair the application if you are on Windows.
Also, check if the application is updated to the latest version available for the application.
Launch the application and go to Help > Repair Installation or Check for updates.
Reboot your machine once and check if that makes any difference.
Also, try once the troubleshooting steps mentioned in this help document Resolve Acrobat DC intermittent crashes on Windows
On Mac, refer this help document Troubleshoot Mac OS 10.x system errors, freezes | Adobe software
Regards,
Meenakshi
Dear Meenakshi,
I followed your instructions; however, when I tried to sign the Test1 got to the Black translucent screen and no further.
Any other advice?
Richie
Hi Richie,
Sorry for the delay in response.
We have released an update to the application.
Please try to update the application and check if the issue still persists?
You may refer to this help document Release Notes | Adobe Acrobat, Reader to check the recent update details.
Feel free to update the thread if the issue persists.
Let us know if the issue resolves.
Regards,
Meenakshi
