2 Replies Latest reply on Dec 4, 2018 1:06 AM by federico platon
    Perfiles .dcp y Camera Raw
    Andrea Ramírez Díaz Level 1
      Hola, no logro visualizar los perfiles de color creador en ColorChecker Passport (.dcp) en el pluging Camera Raw en Calibracion de camara.
      Alguien sabe que sucede o alguna pista
      Saludos
        • 1. Re: Perfiles .dcp y Camera Raw
          federico platon Adobe Community Professional & MVP
          https://www.dzoom.org.es/colorchecker-passport-logra-la-maxima-fidelidad-de-color-en-tus-f otografias/
          Has realizado todos los pasos correctamente?
          Precisa qué versiones de Camera Raw y de Lightroom estás utilizando.
          • 2. Re: Perfiles .dcp y Camera Raw
            The solution from X-Rite support:
            Please follow the instructions below.
            To set up the plugin manually try the following.
            1.        Open Lightroom  and click File > Plug-in Manager
            2.        This will show you all the plug-ins on your system.
            3.        If the ColorChecker Passport is listed select it and make sure it is enabled. If the plug-in is disabled enable
            it and restart Lightroom. This then should work OK.
            4.        If the plugin is not listed you will have to install it manually.
            5.        Click File > Plugin Manager and click the ‘Add’ button.
            In the pop up window browse to:
            Macintosh HD > Library > Application Support > Adobe > Lightroom > Modules
            If the ‘Modules’ folder is missing please use the instructions in the ‘Modules Folder Not Available on a Macintosh computer section below to add the folder manually*.
            6.        In the Modules folder you should see the “XRiteColorCheckerPassport.lrplugin” plugin click on it and then click “Add Plug-in”
            7.        Restart Lightroom and it should now run correctly.
