Hi Guys,
My client wants to migrate from DTM to Launch but they want to use the same DTM prod embed code in launch by creating production environment in Launch.
I have already created new production environment in launch using DTM embed code but while publishing it I am creating New Library using prod environment(which i have created using DTM prod embed code) I am getting this environment as inactive in new library dropdown list.
Prod Environment using DTM prod Embed code.
Getting Prod Environment(Embed code copied from DTM prod Embed code) Inactive while creating New Library.
Please suggest to do the needful.
Solved! Go to Solution.
This is only usefull is you migrate from DTM to Launch.#
In DTM click on the button to migrate to Launch you should a dialog box that asks if you want to use same production as DTM check this.
During migration Launch should create Development, Staging and Production enviroment for you.
You can never link a build to the Stage or Production environment, it should always be a dev one.
Once you finish the development you should push your build for approval which should move it to stage env. Once it is approved and published it will be available in prod env for both the DTM prod location as we decided to link it during migration and the launch one.
Views
Total Likes
Views
Total Likes
First of all I would like to thanks for your reply!
My client wants step by step migration from DTM to Launch. He wants to use the same DTM Embed stage code for creating stage environment in Adobe Launch. There after DTM prod Embed code for creating Launch Production Environment.https://www.youtube.com/watch?v=4DyA1nqtgVg
He is referring this video: Migrating from Adobe DTM to Launch by Adobe - YouTube
Is it possible?
Views
Total Likes
When you migrate a DTM we property to Launch and select the option to use same prod location then when you publish code to production it will be both uploade to the Legacy DTM production endpoint and to the new Adobe Launch Endpoint.
For staging then will have to use the Adobe Launch staging endpoint. It is not possible to link the legacy DTM staging endpoint to the Launch Staging Endpoint. So they will need to update the embedded code on their staging websites.
Some points to b aware off:
Views
Total Likes
We're just in the process of upgrading to Launch and need some clarification on your point
So this means if we using the 'Upgrade to Launch' option only production is migrated, we'll still need dev time to update the staging tags?
Also will we have different physical views of the tags? i.e. staging looks different to live
Views
Total Likes
Views
Likes
Views
Likes
