I am working on a 224pp brochure which I need to change all the codes (literally swap them out) whats the easiest way? I have tried using FindChangeList but for some reason cannot get it to work. Any ideas?
Example layout:
The black numbers on the far right are the codes that I am trying to swap out automatically - Ive got an excel for the code swap.
Any help would be amazing.
Hi Charlotter,
Can you share the exact string you use in the FindChangeList.txt file and a sample indd document, so that i can see what is happening.
-Manan
I have actually managed to get this to work now I am using notepad++ to edit it with. Do you have any tips for doing large amounts of these? Can I import them from an excel or anything?
You could use vbscript to parse your excel files and then add search strings to the FindChangeList.txt via the same code. After that you can trigger the FindChangeList script. So the steps to follow would be
Hope this helps
-Manan
Just brewing ideas and need some clarification. Are you changing the codes because a new code is being used now, like it used to be the old codes and now the company has updated everything to a new list of codes? Or is it something like you need 2 sets of codes because this gets sent to 2 different places who use different code systems?
