• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Re: Adobe Stock .ai Image with transparent background in photoshop
New Here ,
Dec 04, 2018 Dec 04, 2018
I'm having a similar problem but when I try to follow the advice above the halo around the stars goes black -  ID #173047932
Views
768
Translate
Translate
Report
Report
Community guidelines
community guidelines
correct answers 2 Correct answers
Community Expert , Jan 11, 2019 Jan 11, 2019
Geckoz100  schrieb
Sorry, I should have clarified -- the above is a screenshot of AI, but when I removed (hid) the group to remove the gray blocks it just leaves a solid white background.  I would like to have a transparent background.
In Illustrator there is always a white canvas. In order to check whether your image is now really transparent, go to View > Transparency grid. If you now see the transparency grid, then your image is transparent.
It will stay transparent when you export it to a forma
Votes
Translate
Translate
Community Expert , Sep 24, 2022 Sep 24, 2022
quote
Downloaded the second one, because I thought I made some sort of mistake in my selection. Once I removed the background layer I get black around the burst.
By @irvinec95153830
There is nothing wrong with this asset. You will need a dark background for this to work. A light source requires darkness to shine. The way these assets work, they multiply the foreground with the background. Those are complex graphics arithmetic. There is nothing wrong with assets like this, except the chequerboard ba
Votes
Translate
Translate
Adobe Employee ,
Branching to a new discussion,
Hi Emma,
Sorry to hear that.
Are you using the above-mentioned file(#173047932)with Illustrator CC? Also, can you please share some screenshots of the result which you are getting so that we can further assist you?
Regards,
Twarita
Votes
Translate
Translate
Report
Report
Contributor ,
Jan 10, 2019 Jan 10, 2019
Hello, I could not find the layer to delete to get rid of the background....can anyone help?
Votes
Translate
Translate
Report
Report
Community Expert ,
The solution is to open the file in Illustrator and delete the background (consisting in this nice chequerboard background)
If you do not have Illustrator, consider using the 7 day trial.
ABAMBO | Hard- and Software Engineer | Photographer
Votes
Translate
Translate
Report
Report
Contributor ,
Votes
Translate
Translate
Report
Report
Community Expert ,
The chequerboard usually is an element of your file. Depending on how it is build, you need to double click the data, to enter isolation mode and to be able to select the background. You can select and delete or switch off visibility. But that is a question for the Illustrator forum:Illustrator
Votes
Translate
Translate
Report
Report
Community Expert ,
It will stay transparent when you export it to a format that supports transparency.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 23, 2022 Sep 23, 2022
This is so frustrating, just used credits for a lens flare and a star burst image. Downloaded the second one, because I thought I made some sort of mistake in my selection. Once I removed the background layer I get black around the burst. Files should be delivered ready to use or at least the layer clearly marked "Hide Background." Adobe, you need to fix this. Unacceptable. I often download files to save time when on deadline. The complicated instructions for solving this issue are equally unacceptable. That should be done on Adobe's end before selling the files. You make each and every costumer trouble shoot your products, the same product over and over???!!! Why not do it once!??
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
quote
By @irvinec95153830
There is nothing wrong with this asset. You will need a dark background for this to work. A light source requires darkness to shine. The way these assets work, they multiply the foreground with the background. Those are complex graphics arithmetic. There is nothing wrong with assets like this, except the chequerboard background that is commonly used to show the transparency of the foreground. You need to switch off that chequerboard, and different contributors use different methods. It should really be part of a layer on its own.
Votes
Translate
Translate
Report
Report
Resources
Buy Adobe Stock
Getting Started
