2 Replies Latest reply on Mar 20, 2008 10:56 AM by mrigor
    Manage menu buttons
    mrigor
      I am writing a flex 2 that will require a user to interact with a gui. This gui will display different buttons based on what the user selects in the same container. I was initially trying to hide and display the buttons based on visibility attribute, but if two buttons occupy the same space neither of them display.
      There must be a better method, my only thought was states. Any suggestions?
      Matt
        • 1. Re: Manage menu buttons
          SujitG Level 2
          states is a good option. You can try using layout containers and while setting the visibility of the button to false, also set the the includeInLayout to false. By setting in the includeInLayout to false, the layout container will make sure the component is not included while laying out the components in the container.
          Hope this helps.
          • 2. Re: Manage menu buttons
            mrigor Level 1
            SujitG thanks for the response. Your idea is what I needed. Having not used states yet, I was a little daunted to dig into a whole new area for a simple application. Thanks again,
