I am trying to extend a java integration which adds users into meetings/seminars in adobe. The problem that is being experienced is that the code was originally using "principal-list" to see if the user already existed or if a new one was needed, however, if a guest already existed with a given email address then a new principal could not be created. So I know I can change the lookup to use "report-bulk-users" which looks to include guests but I am not sure if there is a way of converting the guest to a user. I know it is possible through the Adobe Connect UI but not sure if it is exposed through API.
I have tried using principal-update with the principal-id of the guest along with type being user but that doesnt seem to work and from looking at the documentation type can only be used when creating a new principal.
Hi there,
So /api/xml?action=report-bulk-users&filter-type=guest will get you all Guests on the system and their principal-id values. (keep in mind this API hits the reporting DB, not production, so it can be delayed in it's data.)
Once you find the principal-id of the Guest you want to convert to a full user, you can use this API:
/api/xml?action=update-principal-type&principal-id=xxxxxxxx&type=user
- where xxxxxxxx = the actual principal-id of the guest you want to make a full user.
Response exam
...Copy link to clipboard
That is how I would do it. I'll do a quick test and see if I can get it to work.
Hi there,
Response example:
<results>
<style type="text/css" id="dark-mode-custom-style"/>
<status code="ok"/>
<update-principal-type type="user" principal-id="xxxxxxxx"/>
</results>
Let me know if this is what you are looking for.
(Full disclosure, the above API is undocumented but it is a 'normal' API access level and works just fine if you have Admin permissions on any Adobe Connect account).
Thats worked perfectly thanks.
Is there a better approach for finding guests as oppose to "report-bulk-users" so that it doesnt have any time delay?
Sure. Actually there is. Now that I think of it...
/api/xml?action=principal-list&filter-type=guest
If you do not append 'filter-type=guest', you just get back users and groups (and system groups). If you FILTER on (type=guest), you will get back all the guests. Remember the filter!
That should give you back the guests in real-time. Try it out. Create a guest, then fire that API compared to report-bulk-users API. You should see it in the principal-list and not in the other (until the reporting DB is updated).
Let me know.
Thanks.
That worked.
