Expand my Community achievements bar.
SOLVED
Using Sequential segment
Avatar
Level 3
I'm looking to get click-through rate from page A->pageB using the condition that the user should have clicked on the banner/hero carousel present on page A.
Simply put: Homepage-> click on banner->campaign page
Can anyone help if the methodology is correct & we'll get the right click-through rate% when using 'sequential segment?
Upon running the report, I'm using our 'internal click event' and 'visits' to calculate the click-through rate.
Best,
M
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
I agree with Gigazelle​ and H_L
I would change the "then" condition to "then within 1 hit" to be sure it is really a path you are looking for.
remark: use fallout
instead of manually creating the segment you could follow those steps:
  1. In workspace create a new Fallout
  2. Add the touchpoints as in your segment
  3. Change the "path" between the touchpoint to "next hit"
  4. Change Fallout setting to "start on first touchpoint" and "visit based" (gear icon top right)
  5. on last touchpoint hit "create segment from touchpoint"
working with fallouts have several advantages compared to creating a segment directly:
  • you see the numbers at each step in the fallout
  • you can add more segments to compare (drop them at the top of the fallout next to "all visitors")
  • you can do fallout/fallthrough analysis directly at each touchpoint
View solution in original post
Avatar
Employee Advisor
Yeah, that appears pretty sound. It looks to be pretty specific in that to get to page B they have to click on a carousel link to get there.
Are you seeing any issues with the segment?
Avatar
Level 8
Level 8
the only question I would ask: is any link on the page A user clicks will trigger the eVar39 or eVar38? If yes, it's fine.
Avatar
Correct answer by
Community Advisor
remark: use fallout
