1 Reply Latest reply on Dec 7, 2018 9:36 AM by Jean-Serge Biron
    how to specify a memo type field in xtkquerydef
    priyankav25102322 Level 1
      i want to select mdata type of field eg visualState in xtk:workflow, how to specify this attribute in querydef call
      eg
      var query = xtk.queryDef.create(
      <queryDef schema={schemaName} operation="select" lineCount="1">
        <select>
          <node expr="visualState" alias="@visualState"/>
        </select>
        <where>
          <condition expr={condition} />
        </where>
      </queryDef>
      is this correct or is there special syntax to select such elements.
      my javascript activity is hanging when i execute this query. it works fine when some simple attribute or element is specified for selection.
        • 1. Re: how to specify a memo type field in xtkquerydef
          Jean-Serge Biron Experience Cloud MVP
          Hi Priyanka,
          Your syntax is correct, but you were unlucky with your test.
          If you replace visualState by the other memo (mdata) field in xtk:workflow, called data, it works fine:
          <node expr="data" alias="@data"/>
          For me as well the workflow hangs when I use;
          It seems the binary data (an image) can't be manage by a standard queryDef, probably you must use buffer manipulation to manage image.
          Regards.
          J-Serge
