8 Replies Latest reply on Dec 6, 2018 11:48 AM by smacdonald2008
    No data source found with name (after asking 0 providers)
    kirillo71434335
      Hello.
      I made everything needed that is described in this article: Adobe Experience Manager Help | Querying MySQL data using an Adobe Experience Manager 6.4 DataSourcePool
      I can successfuly get data source instance only after component activation. If I do it during the activation I get this error message: "No data source found with name 'MyDatabase' (after asking 0 providers)".
      Here below is the source code. I have no errors getting dataSource if I only call getConnection() method. Activation method is problematic.
      I use Adobe Experience Manager (6.2.0.SP1-CFP16) version.
      Could I get some assistance? Thanks in advance.
      ================== THE SOURCE CODE ==================
      DataBaseComponent.java:
      package test.components;
      import java.sql.Connection;
      public interface DataBaseComponent {
             Connection getConnection();
      DataBaseComponentImpl.java:
      package test.components.impl;
      import org.osgi.service.component.annotations.*;
      import org.slf4j.Logger;
      import org.slf4j.LoggerFactory;
      import javax.sql.DataSource;
      import com.day.commons.datasource.poolservice.DataSourcePool;
      import com.day.commons.datasource.poolservice.DataSourceNotFoundException;
      import test.components.DataBaseComponent;
      @Component (
         immediate = true,
         scope = ServiceScope.SINGLETON
      public class DataBaseComponentImpl implements DataBaseComponent {
              private static final String DATA_SOURCE_NAME = "MyDatabase";
              @Reference
              private DataSourcePool dataSourcePool;
              private DataSource dataSource;
              private Logger logger = LoggerFactory.getLogger(getClass());
              public Connection getConnection() {
                    Connection con = null;
                    if (dataSource != null) {
                        try {
                             con = dataSource.getConnection();
                             return con;
                         } catch (Exception e) {
                             logger.error(e.getMessage());
                   } else {
                        try {
                             dataSource = (DataSource) dataSourcePool.getDataSource(DATA_SOURCE_NAME);
                             logger.info("dataSource in instantiated ...");
                        return con;
                   return null;
              @Activate
              public void activate() {
                    try {
                             logger.info("activation step: dataSource in instantiated ...");
                   } catch(DataSourceNotFoundException e) {
