8 Replies Latest reply on Apr 16, 2008 1:45 PM by Mush15
    HTTPService caching issue? (PL/SQL backend)
    ChrisBAH1008
      Hi All,
      I'm working to create a RIA using Flex running on Oracle (mod_plsql + Apache). I am using Oracle's DBMS_XMLQuery library to retrieve data from the database and return it as a CLOB to HTP.P in XML format. This is working exceptionally well for our needs as installing an RIA server (such as WebORB) is out of the question.
      The issue I am having is that I should be having numerous places within the RIA wherein my HTTP Service calls are being "re-sent"; that is, literally, when the app initially loads and calls httpService.send() - the data loads fine. When I then call the same method later in the application, I can tell that the being retrieved is stale.
      Some of the examples of where I do this:
      1) on a timed refresh
      2) after an insert of new data
      3) on a manual click of a button
      In each case, I get valid messages that the resultHandlers for each httpService.send() are being performed. However, I can also validate that these calls are returning exactly the same data that was initially loaded.
      *However*, the second I manually call the URL (let's say, pkg_xml.get_xml?id=123) via a separate browser window and *then* manually refresh the Flex app (not Browser refresh, but one of the options above) the *new* data is then returned and all data grides and UI components are freshed with the new data set.
      I am using a combination of ArrayCollection and XMLList.
      At this point, I can't narrow down the issue as much as I'd like. I don't know if it is an Oracle session issue, an Apache caching problem, or if I need to tell Flex to disconnect() from the HTTPService and then re-connect each time.
      I'd love to get your feedback and I hope that others out there integrating Flex with Oracle/PL/SQL can chime in.
      Thanks!
