6 Replies Latest reply on Mar 26, 2008 6:56 PM by Newsgroup_User
    web service
    mikey999
      so i have never created a web service and find my self wanting to learn how. So I found this page with examples
      http://www.quackit.com/coldfusion/tutorial/coldfusion_web_services.cfm
      i followed the example and built my own script just changing out my database info so it would use my data.
      here is my data
      <cfcomponent>
      <cffunction name="listBooks"
      access="remote"
      returntype="string"
      output="no">
      <cfargument name="category"
      type="string"
      required="yes">
      <cfset Var BookList = "">
      <cfset Var getBooks = "">
      <cfquery name="getBooks" datasource="datasource">
      SELECT FileToolID,FileTitle, UrlLink, FileDescription, File3
      FROM FileTool
      AND FileTool.StatusID = 'Approved'
      AND FileTool.FileCONFIGID = 24
      </cfquery>
      <cfsavecontent variable="BookList">
      <books>
      <cfoutput query="getBooks">
      <book id="#FileToolID#">
      <booktitle>#XMLFormat(FileTitle)#</booktitle>
      <teaser>#XMLFormat(UrlLink)#</teaser>
      <price>#XMLFormat(FileDescription)#</price>
      </book>
      </cfoutput>
      </books>
      </cfsavecontent>
      <cfreturn BookList>
      </cffunction>
      </cfcomponent>
      i tried to then run this script
      <cfinvoke
      method="listBooks"
      returnvariable="rawXMLBookList"
      webservice=" http://yourdomain.com/web_services/book.cfc?wsdl">
      <cfinvokeargument name="category" value="123">
      </cfinvoke>
      <cfset computerBooks = XmlParse(rawXMLBookList)>
      <cfdump var="#computerBooks#">
      and i get nothing but an error. the part i do not get is my first file is called test.cfm do i need to cal lit test.cfc? or does it create a file called test.cfm
      this part confuses me.
      thanks much
        • 1. Re: web service
          mikey999 Level 1
          ps this part webservice=" http://yourdomain.com/web_services/book.cfc?wsdl"> i did put in the link to my file test.cfc
          • 2. Re: web service
            Level 7
            > here is my data
            > <cfcomponent>
            > access="remote"
            > returntype="string"
            > output="no">
            > type="string"
            > required="yes">
            > FROM FileTool
            > </cfquery>
            > <books>
            > </book>
            > </cfoutput>
            > </books>
            > </cfsavecontent>
            > <cfreturn BookList>
            > </cffunction>
            > </cfcomponent>
            > <cfinvoke
            > method="listBooks"
            > </cfinvoke>
            > test.cfm
            > thanks much
            The <cfcomponent...>...</cfcomponent> code should be in a file with a
            .cfc extension, this is not required, but it is the default expectation.
            The <cfinvoke...> tag should be in an .cfm file. It could also be in a
            higer level cfc, but let's not get ahead of ourselves here. The
            "webservice" parameter of the <cfinvoke...> tag should reference the cfc
            file created above.
            Before running your cfc as a web service run it as a component. Just
            add a component version of <cfinvoke...> before your web service
            version. This makes sure that errors in the cfc itself is not stopping
            you dead in your tracks. A web service can not always report the same
            level of detail about an error as a component called locally can.
            • 3. Re: web service
              mikey999 Level 1
              well i am getting this error maybe this will help some
              Could not perform web service invocation "listBooks".
              Here is the fault returned when invoking the web service operation:
              AxisFault
              faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server.userException
              faultSubcode:
              faultString: coldfusion.xml.rpc.CFCInvocationException:
              [coldfusion.tagext.sql.QueryTag$DatabaseQueryException : Error Executing Database Query.][java.sql.SQLException : [Macromedia][SQLServer JDBC Driver][SQLServer]Incorrect syntax near the keyword 'AND'.]
              faultActor:
              faultNode:
              faultDetail:
              { http://xml.apache.org/axis/}stackTrace:coldfusion.xml.rpc.CFCInvocationException: [coldfusion.tagext.sql.QueryTag$DatabaseQueryException : Error Executing Database Query.][java.sql.SQLException : [Macromedia][SQLServer JDBC Driver][SQLServer]Incorrect syntax near the keyword 'AND'.]
              at coldfusion.xml.rpc.CFComponentSkeleton.__createCFCInvocationException(CFComponentSkeleton .java:714)
              at coldfusion.xml.rpc.CFComponentSkeleton.__invoke(CFComponentSkeleton.java:660)
              at login.test.listBooks(D:\login\test.cfc)
              at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
              at sun.reflect.NativeMethodAcce...
              The error occurred in D:\login\test2.cfm: line 6
              4 : webservice=" http://www.resourcesaver.com/login/test.cfc?wsdl">
              5 :
              6 : <cfinvokeargument name="category" value="123">
              7 : </cfinvoke>
              8 :
              • 4. Re: web service
                Level 7
                FROM FileTool
                that is a very wrong sql statement, which is what your webservice is
                trying to tell you with the error...
                see what and WHERE you are missing in your sql?
                Azadi Saryev
                Sabai-dee.com
                http://www.sabai-dee.com/
                • 5. Re: web service
                  mikey999 Level 1
                  i fixed that error in my query you are right i missed out a where but still getthis this error
                  i also noticed in side the cfm admin there is a place for web service but this example does not talk about this at all. Do i need to do anything in that cfm admin on this for this to work?
                  AxisFault
                  faultSubcode:
                  [coldfusion.tagext.sql.QueryTag$DatabaseQueryException : Error Executing Database Query.][java.sql.SQLException : [Macromedia][SQLServer JDBC Driver][SQLServer]Invalid column name 'UrlLink'.]
                  faultActor:
                  faultNode:
                  faultDetail:
                  { http://xml.apache.org/axis/}stackTrace:coldfusion.xml.rpc.CFCInvocationException: [coldfusion.tagext.sql.QueryTag$DatabaseQueryException : Error Executing Database Query.][java.sql.SQLException : [Macromedia][SQLServer JDBC Driver][SQLServer]Invalid column name 'UrlLink'.]
                  at sun.reflect.NativeMethodAccessorImpl.invoke(Nati...
                  The error occurred in D:\web\getfsites\getf\test2.cfm: line 6
                  5 :
                  7 : </cfinvoke>
                  8 :
                  Resources:
                  Check the ColdFusion documentation to verify that you are using the correct syntax.
                  Search the Knowledge Base to find a solution to your problem.
                  Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1)
                  Remote Address 64.243.182.132
                  Referrer
                  Date/Time 26-Mar-08 03:41 PM
                  • 6. Re: web service
                    Level 7
                    just READ the error you get:
                    *Invalid column name 'UrlLink'*
                    you apparently still have your query wrong...
                    Azadi Saryev
                    Sabai-dee.com
