I was trying to open up a file that ends with ".SWF" via Flash Player on my new MacBook Pro.
For some reason, I keep getting a blank screen and it looks as if the application is trying to play the file but you don't see or hear anything.
I also get an error message with Flash Player that says, "PREFERENCES ERROR, COULD NOT LOAD FLASH PLAYER PREFERENCE PANE" and it shows another message that says, "LOADING FLASH PLAYER".
Does anyone know how I can get Flash working?
Message was edited by: Jeromie Clark - I updated the title to make this a little easier to find for other Captivate users that might be running into this
Are you attempt to use the browser plugin or the Flash Projector?
If you're trying to use the browser plugin, try using the Flash Projector instead. It's available for download at Adobe Flash Player - Debug Downloads​. Scroll down to Macintosh section and then click on the 'Download the Flash Projector' link.
If the file is saved locally on your computer, see the 'Disabling local-with-filesystem access in Flash Player by default' section of the Flash Player 23 Release Notes for information on allowing Flash to load local content.
If you're still experiencing issues, post a screenshot of any message (error or otherwise) that is displayed
- If replying by email, email attachments are blocked. Log onto the forums to post the screenshot.
Thank you Maria.
Looks like Flash Player finally loaded or updated (see screenshot). The file is on my desktop and after following the instructions you sent, I still can't get it to open them (The blank screen keeps showing up when I try to open the file.)
Here are some additional screenshots (attached). I've also attached the error report if this helps...Open to any other suggestions you might have.
Can you cut and paste the contents of the text window in that crash report? All the good stuff is below the fold.
If it's really long, you might need to break it up into two posts, or you could put it on pastebin or something.
Oh, can you just copy and paste the text? I can't process images of text in the way that I need to.
You can just click in the text box and hit Command-A to select all, and Command-C to copy. You should then be able to paste the text here with Command-V.
Here ya go.
ERROR REPORT INFO:
Process: Flash Player [1855]
Path: /Applications/Adobe Captivate 2019/*/ProjectorApp.app/Contents/MacOS/Flash Player
Identifier: com.macromedia.Flash Player.app
Version: 11.1.102.55 (11.1)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Flash Player [1855]
User ID: 502
Date/Time: 2018-12-11 15:04:03.899 -0800
OS Version: Mac OS X 10.14.1 (18B75)
Report Version: 12
Bridge OS Version: 3.0 (14Y667)
Anonymous UUID: 2D385751-7B6D-4E5A-EB3F-40095D9B5392
Sleep/Wake UUID: 5D091F1A-9C59-4772-A3E0-57547407C819
Time Awake Since Boot: 9600 seconds
Time Since Wake: 790 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000010620c140
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [1855]
VM Regions Near 0x10620c140:
MALLOC_TINY 0000000106100000-0000000106200000 [ 1024K] rw-/rwx SM=PRV
MALLOC_TINY 0000000107200000-0000000107400000 [ 2048K] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.macromedia.Flash Player.app 0x0000000100530e10 main + 283312
1 com.apple.CoreFoundation 0x00007fff4dd063f2 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 12
2 com.apple.CoreFoundation 0x00007fff4dd0636c ___CFXRegistrationPost_block_invoke + 63
3 com.apple.CoreFoundation 0x00007fff4dd0628d _CFXRegistrationPost + 398
4 com.apple.CoreFoundation 0x00007fff4dd0e6d9 ___CFXNotificationPost_block_invoke + 87
5 com.apple.CoreFoundation 0x00007fff4dc75e8a -[_CFXNotificationRegistrar find:object:observer:enumerator:] + 1633
6 com.apple.CoreFoundation 0x00007fff4dc7524d _CFXNotificationPost + 742
7 com.apple.Foundation 0x00007fff4fffd98b -[NSNotificationCenter postNotificationName:object:userInfo:] + 66
8 com.apple.AppKit 0x00007fff4bb0df15 -[NSWindow _finishClosingWindow] + 181
9 com.apple.AppKit 0x00007fff4b57d22c -[NSWindow _close] + 364
10 com.apple.AppKit 0x00007fff4b5e295f -[NSWindow _closeForTermination] + 22
11 com.apple.CoreFoundation 0x00007fff4dd3f4c2 -[NSArray makeObjectsPerformSelector:] + 296
12 com.apple.AppKit 0x00007fff4b52f48b -[NSApplication _deallocHardCore:] + 343
13 com.apple.AppKit 0x00007fff4b3fe7e7 -[NSApplication terminate:] + 1543
14 com.apple.Foundation 0x00007fff50052015 __NSFireDelayedPerform + 433
15 com.apple.CoreFoundation 0x00007fff4dcc1bbd __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
16 com.apple.CoreFoundation 0x00007fff4dcc1770 __CFRunLoopDoTimer + 859
17 com.apple.CoreFoundation 0x00007fff4dcc12b0 __CFRunLoopDoTimers + 333
18 com.apple.CoreFoundation 0x00007fff4dca24fb __CFRunLoopRun + 2176
19 com.apple.CoreFoundation 0x00007fff4dca1a28 CFRunLoopRunSpecific + 463
20 com.apple.HIToolbox 0x00007fff4cf3ab35 RunCurrentEventLoopInMode + 293
21 com.apple.HIToolbox 0x00007fff4cf3a86b ReceiveNextEventCommon + 618
22 com.apple.HIToolbox 0x00007fff4cf3a5e8 _BlockUntilNextEventMatchingListInModeWithFilter + 64
23 com.apple.AppKit 0x00007fff4b1f6eb7 _DPSNextEvent + 997
24 com.apple.AppKit 0x00007fff4b1f5c56 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1362
25 com.apple.AppKit 0x00007fff4b1efcb9 -[NSApplication run] + 699
26 com.apple.AppKit 0x00007fff4b1df3f7 NSApplicationMain + 780
27 com.macromedia.Flash Player.app 0x00000001000022d4 0x100000000 + 8916
Thread 1:
0 libsystem_pthread.dylib 0x00007fff7b070428 start_wqthread + 0
1 ??? 0x0000000054485244 0 + 1414025796
Thread 2:
Thread 3:
Thread 4:
Thread 5:
0 libsystem_kernel.dylib 0x00007fff7afbb1b2 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff7b0745cb _pthread_cond_wait + 724
2 com.macromedia.Flash Player.app 0x00000001004bf43b 0x100000000 + 4977723
3 com.macromedia.Flash Player.app 0x000000010001a4fe 0x100000000 + 107774
4 com.macromedia.Flash Player.app 0x00000001004bf551 0x100000000 + 4978001
5 com.macromedia.Flash Player.app 0x00000001004bf5d3 0x100000000 + 4978131
6 libsystem_pthread.dylib 0x00007fff7b071339 _pthread_body + 126
7 libsystem_pthread.dylib 0x00007fff7b0742a7 _pthread_start + 70
8 libsystem_pthread.dylib 0x00007fff7b070445 thread_start + 13
Thread 6:
Thread 7:
Thread 8:
Thread 9:
2 com.macromedia.Flash Player.app 0x00000001004bf3f2 0x100000000 + 4977650
3 com.macromedia.Flash Player.app 0x0000000100205e2c 0x100000000 + 2121260
Thread 10:
3 com.macromedia.Flash Player.app 0x00000001003bffc3 0x100000000 + 3932099
Thread 11:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x00007fff7afb7c2a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff7afb8174 mach_msg + 60
2 com.apple.CoreFoundation 0x00007fff4dca2da2 __CFRunLoopServiceMachPort + 337
3 com.apple.CoreFoundation 0x00007fff4dca22f1 __CFRunLoopRun + 1654
4 com.apple.CoreFoundation 0x00007fff4dca1a28 CFRunLoopRunSpecific + 463
5 com.apple.AppKit 0x00007fff4b1ffadd _NSEventThread + 160
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x000000010620c130 rbx: 0x00007ffeefbfc4f0 rcx: 0x0000000101217a10 rdx: 0x0000600000d04120
rdi: 0x0000000101217a10 rsi: 0x00007fff4bdfbdee rbp: 0x00007ffeefbfc4b0 rsp: 0x00007ffeefbfc380
r8: 0x0000000000000001 r9: 0x0000000000000001 r10: 0x0000000100f84fe0 r11: 0x000000010285f4e0
r12: 0x0000000101217a10 r13: 0x0000600001744bc0 r14: 0x0000600000c1e910 r15: 0x0000000000000000
rip: 0x0000000100530e10 rfl: 0x0000000000010206 cr2: 0x000000010620c140
Logical CPU: 2
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x100000000 - 0x100f80fcf +com.macromedia.Flash Player.app (11.1.102.55 - 11.1) <AF9A5C06-E1FF-66C4-E1E4-2B61FADAB2BC> /Applications/Adobe Captivate 2019/*/ProjectorApp.app/Contents/MacOS/Flash Player
0x10553c000 - 0x105540fff com.apple.audio.AppleHDAHALPlugIn (282.10 - 282.10) <94DDF962-09E0-3B3E-B887-9A0301022190> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x105546000 - 0x105585fff com.apple.cmio.DAL.VDC-4 (810.0 - 193.200.13) <561AA900-DDB3-34DC-8F41-3B9156962DB4> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/MacOS/VDC
0x107d08000 - 0x107d866a7 dyld (635.2) <1780094A-8FE2-3EAA-B4A3-C4CF14BC5196> /usr/lib/dyld
0x1094f1000 - 0x1094f4047 libobjc-trampolines.dylib (750.1) <EAFE392F-7BD6-3988-9C6F-DFD359AE0AD3> /usr/lib/libobjc-trampolines.dylib
0x7fff4645e000 - 0x7fff4723ffff com.apple.driver.AppleIntelKBLGraphicsGLDriver (12.2.17 - 12.0.2) <826FF099-E6EF-3471-8907-36748D5DCE59> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
0x7fff47240000 - 0x7fff474c9ff7 com.apple.driver.AppleIntelKBLGraphicsMTLDriver (12.2.17 - 12.0.2) <7A76F267-8822-36C8-87C1-90C949048A80> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
0x7fff49bc6000 - 0x7fff49bcafff com.apple.agl (3.3.2 - AGL-3.3.2) <6A6986E0-B527-3E1E-8833-246C40D16C58> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x7fff49bcb000 - 0x7fff49db9fff com.apple.avfoundation (2.0 - 1542.10.104.1) <A3A0B581-CA6E-31E1-AE67-5DB8EABFEA04> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff49dba000 - 0x7fff49e89fff com.apple.audio.AVFAudio (1.0 - ???) <6FB8FD22-713D-347C-8278-9170077EE8AD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x7fff49f97000 - 0x7fff49f97fff com.apple.Accelerate (1.11 - Accelerate 1.11) <A09CB6D5-3F8A-3E05-B0EB-63878296A059> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff49f98000 - 0x7fff49faefef libCGInterfaces.dylib (506.19.1) <8A894DB4-A48B-31A0-9316-DC41061D9549> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff49faf000 - 0x7fff4a64ffe3 com.apple.vImage (8.1 - ???) <DB23E2A0-EA06-3073-AA7E-2873556714A9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff4a650000 - 0x7fff4a8c7fd7 libBLAS.dylib (1243.200.4) <76710990-AE2B-300E-88BB-797ABAD74956> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff4a8c8000 - 0x7fff4a93afe7 libBNNS.dylib (38.200.5) <5F3A4021-8FF8-30E8-B84A-AA2BD70F4151> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff4a93b000 - 0x7fff4ace1fff libLAPACK.dylib (1243.200.4) <45722A8A-5788-3C4C-ADD9-1812763FA635> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff4ace2000 - 0x7fff4acf7ffb libLinearAlgebra.dylib (1243.200.4) <E923DA33-B142-3A73-A80A-642878D19099> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff4acf8000 - 0x7fff4acfdff3 libQuadrature.dylib (3.200.2) <6FFAC142-415D-3AF0-BC09-336302F11934> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff4acfe000 - 0x7fff4ad7bffb libSparse.dylib (79.200.5) <0D7E71A4-10D2-3979-B386-D2426ADAF6D7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x7fff4ad7c000 - 0x7fff4ad8fffb libSparseBLAS.dylib (1243.200.4) <00D6FC17-B739-3259-90A4-92AC8BBE03D6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff4ad90000 - 0x7fff4af74ff3 libvDSP.dylib (671.220.1) <2F576522-08B1-3C65-8F00-3427E938ADDA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff4af75000 - 0x7fff4b02aff3 libvMisc.dylib (671.220.1) <29F59097-A256-38E9-9D55-BF56E9139CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff4b02b000 - 0x7fff4b02bfff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <221E4FEF-0431-3316-8281-22B6F8315A09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff4b1dc000 - 0x7fff4bffcff3 com.apple.AppKit (6.9 - 1671.10.106) <179A5F4A-6467-31BD-93F2-CC27E046221E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff4c04e000 - 0x7fff4c04efff com.apple.ApplicationServices (50.1 - 50.1) <470C0943-30AD-3BA2-AFCE-EB7DD26E1709> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff4c04f000 - 0x7fff4c0baff7 com.apple.ApplicationServices.ATS (377 - 453.11) <7599E619-EE21-3EB7-875B-AE3B8D3E13BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff4c153000 - 0x7fff4c272fff libFontParser.dylib (228.6) <E800074F-62CF-340A-A5A7-B8BE5B560045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff4c273000 - 0x7fff4c2befff libFontRegistry.dylib (228.12) <480D472D-C8FB-321D-86EC-2EA6927A97AD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff4c31d000 - 0x7fff4c350ff7 libTrueTypeScaler.dylib (228.6) <D23BFDE4-8664-335A-B43B-A13A8EF29E40> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff4c3ba000 - 0x7fff4c3beff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <90641B6B-D07B-3577-B594-965825544B60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x7fff4c45b000 - 0x7fff4c4adff3 com.apple.HIServices (1.22 - 627.14.2) <01F309D6-32E7-3C4F-A38B-8206EE3076CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff4c4ae000 - 0x7fff4c4bcff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <67BC5855-B7A3-39E6-B5DD-52B287EB1532> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff4c4bd000 - 0x7fff4c509fff com.apple.print.framework.PrintCore (14.0 - 503.7) <C13BC56A-65F4-35B1-9E33-51FE6F3B06FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff4c50a000 - 0x7fff4c545ff7 com.apple.QD (3.12 - 407.2) <94A30038-C545-327A-B1C0-E19C79D62BAB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff4c546000 - 0x7fff4c552ff7 com.apple.speech.synthesis.framework (8.1.0 - 8.1.0) <823830AC-62A6-36CC-A659-6BC10F2AC6F5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff4c553000 - 0x7fff4c7efff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <F56518BA-B21B-32D8-B077-40A989815F46> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff4c7f1000 - 0x7fff4c7f1fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B0F229C4-E8AF-3EB3-8241-7576A115D69F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff4cb55000 - 0x7fff4cf16ff7 com.apple.CFNetwork (975.0.3 - 975.0.3) <99BD4FA0-8BD3-35E5-8FB1-C757D439716C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff4cf2b000 - 0x7fff4cf2bfff com.apple.Carbon (158 - 158) <BF1EC28F-CBA8-3B2F-B9FA-E583BC2D6C1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff4cf2c000 - 0x7fff4cf2fffb com.apple.CommonPanels (1.2.6 - 98) <F1E1C47B-FD1A-30A4-B41B-87BD8B178B56> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff4cf30000 - 0x7fff4d237ff7 com.apple.HIToolbox (2.1.1 - 917.2) <0B91F11C-0895-3A7B-9A3B-2B6B1267EA1A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff4d238000 - 0x7fff4d23bffb com.apple.help (1.3.8 - 66) <4392A63F-9B58-3248-BF73-B46AD3744E6E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff4d23c000 - 0x7fff4d241ff7 com.apple.ImageCapture (9.0 - 1530.1) <47915C3C-DED4-3E0C-9155-6B130FFF89BB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff4d242000 - 0x7fff4d2d6ff3 com.apple.ink.framework (10.9 - 225) <D6503F37-7EBC-32C1-95CC-A35EFC54E7ED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff4d2d7000 - 0x7fff4d2f1fff com.apple.openscripting (1.7 - 179) <BDE14D25-4D82-3EBC-8EF2-D1F6BC957B07> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff4d312000 - 0x7fff4d313fff com.apple.print.framework.Print (14.0 - 267.3) <5CD250DF-98AD-30B8-A5D5-47634FF9E74D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff4d314000 - 0x7fff4d316ff7 com.apple.securityhi (9.0 - 55006) <C5308CBC-6736-31A7-905B-C635C6D43FDE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff4d317000 - 0x7fff4d31dff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <1C38B9CB-DD45-3A7B-9D4C-631855A4EE32> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff4d444000 - 0x7fff4d444fff com.apple.Cocoa (6.11 - 23) <4D5D4968-E233-3598-B434-E1009D48A628> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff4d452000 - 0x7fff4d51efff com.apple.ColorSync (4.13.0 - 3340) <0618DA46-5A5E-339D-BB2F-ED66A2BFCCF9> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff4d6b9000 - 0x7fff4d749fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A7F8E168-AB1D-36F4-9693-CFEF12BC197D> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff4d7af000 - 0x7fff4d7daff7 com.apple.CoreBluetooth (1.0 - 1) <61235BEA-BF5F-31B2-B9C1-DE722E15840F> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff4d7db000 - 0x7fff4db7cfef com.apple.CoreData (120 - 866.1) <B74013FA-621B-30F9-8CFE-3290FF63C2B8> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff4db7d000 - 0x7fff4dc66ff7 com.apple.CoreDisplay (101.3 - 104.4) <52C96B6A-B119-3BE2-B47D-65F12E987609> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff4dc67000 - 0x7fff4e0b4fe7 com.apple.CoreFoundation (6.9 - 1560.12) <B5BDC307-6C89-3DE0-B4B9-4C2C650E4528> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff4e0b6000 - 0x7fff4e743ff7 com.apple.CoreGraphics (2.0 - 1247.4.1) <D2F1DD53-09BD-307B-8B80-46B259530ED8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff4e745000 - 0x7fff4ea6efff com.apple.CoreImage (14.1.0 - 710.2.240) <CAEE3AAA-0781-311A-B987-72C7332C1A3F> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff4eb50000 - 0x7fff4edbeff7 com.apple.CoreML (1.0 - 1) <A6C41E33-935A-3C1A-9FC3-0372E580A5D7> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x7fff4edbf000 - 0x7fff4eec0ff3 com.apple.CoreMedia (1.0 - 2282.19.104.4) <2FF4819F-0D06-38D5-9403-4DA3F6F37D76> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff4eec1000 - 0x7fff4ef23fff com.apple.CoreMediaIO (900.0 - 5025) <A9CC940A-9E7C-35A4-A1E6-DADD66200378> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff4ef24000 - 0x7fff4ef24fff com.apple.CoreServices (934 - 934) <EBA4A3BF-0B07-3E1B-9C14-8E6879453C6C> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff4ef25000 - 0x7fff4efa3ffb com.apple.AE (771 - 771) <BBFEAB6C-B1F9-3D22-934E-8298155AC459> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff4efa4000 - 0x7fff4f27cff7 com.apple.CoreServices.CarbonCore (1178.11 - 1178.11) <9FBE7BFB-3A81-37AC-8E15-E6F7932BBDC0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff4f27d000 - 0x7fff4f2c7ff7 com.apple.DictionaryServices (1.2 - 284.16.3) <D9388630-E7F2-321E-81FF-EBD5F3B47A52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff4f2c8000 - 0x7fff4f2d0ffb com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <E40A3C4A-79C7-37D8-999B-D1169A06870B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff4f2d1000 - 0x7fff4f49cfff com.apple.LaunchServices (934 - 934) <FD3D313D-997B-388B-B208-29774CDDF897> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff4f49d000 - 0x7fff4f53ffff com.apple.Metadata (10.7.0 - 1191.52) <5A758D93-4BBD-3C6D-861B-000536ED9B2D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff4f540000 - 0x7fff4f58bff7 com.apple.CoreServices.OSServices (934 - 934) <1D2AC09A-653F-3C2D-B5B9-F9ABA307E51C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff4f58c000 - 0x7fff4f5faff7 com.apple.SearchKit (1.4.0 - 1.4.0) <C6A34D09-9707-3F28-838F-63B59B8A12D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff4f5fb000 - 0x7fff4f61fffb com.apple.coreservices.SharedFileList (71.27 - 71.27) <B46A15E0-4C10-3616-BE49-58E07EC463FE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff4f967000 - 0x7fff4faccffb com.apple.CoreText (352.0 - 584.25) <AC3B4909-564A-3C26-B055-7687E5DE1697> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff4facd000 - 0x7fff4fb0afff com.apple.CoreVideo (1.8 - 0.0) <C7BB7D0F-3AF2-3046-A387-A802BCA52A3A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff4fb0b000 - 0x7fff4fba1ffb com.apple.framework.CoreWLAN (13.0 - 1370.8) <735EEBA3-C63B-38C8-A1A7-23B12C2E9550> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff4fd31000 - 0x7fff4fd3cffb com.apple.DirectoryService.Framework (10.14 - 207.200.4) <222097B7-D721-3F27-9798-ACC95E73F233> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff4fd3d000 - 0x7fff4fdf7ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <9F007E61-83AD-3DB5-B3D5-CB4F1EDF746A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff4fe1e000 - 0x7fff4fe23fff com.apple.DiskArbitration (2.7 - 2.7) <C53C1905-9BCF-3AE8-8BB3-C8A2C7DB7D25> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff4ffec000 - 0x7fff503bafff com.apple.Foundation (6.9 - 1560.12) <B5DC275C-12C9-320A-A117-C8FE9034931A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff5042b000 - 0x7fff5045bff3 com.apple.GSS (4.0 - 2.0) <721B6FEF-9E0E-311B-8CAF-93ADEE2AE548> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff50575000 - 0x7fff5067fff3 com.apple.Bluetooth (6.0.9 - 6.0.9f2) <0EDECAF3-FF86-3F7D-B916-2D7E67FF67AE> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff506e1000 - 0x7fff50773ff7 com.apple.framework.IOKit (2.0.2 - 1483.220.15) <B58031DE-A6B7-3685-840F-361670C06836> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff50775000 - 0x7fff5077fff7 com.apple.IOSurface (255.1 - 255.1) <538F0257-A408-36AF-AB1E-1D7037D6359E> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff50780000 - 0x7fff507d5ff3 com.apple.ImageCaptureCore (1.0 - 1530.1) <C053A62A-AA27-3E5F-97EE-8781E75028EB> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff507d6000 - 0x7fff50974fff com.apple.ImageIO.framework (3.3.0 - 1821.6.4.1) <00BF9654-021D-33C7-B681-461F3EF357FD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff50975000 - 0x7fff50979ffb libGIF.dylib (1821.6.4.1) <032CA0C2-8AAA-3D3F-8E61-25CE9267C2A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff5097a000 - 0x7fff50a5ffef libJP2.dylib (1821.6.4.1) <FED43EEB-2B6C-32FC-94A2-297DA8CE4D87> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff50a60000 - 0x7fff50a85ff7 libJPEG.dylib (1821.6.4.1) <DD334010-2B8D-3A5E-BC17-39A9D94AC92D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff50d58000 - 0x7fff50d7efe7 libPng.dylib (1821.6.4.1) <EBAAB8C0-33A7-3C13-B96C-8B6AB8287C7A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff50d7f000 - 0x7fff50d81ff7 libRadiance.dylib (1821.6.4.1) <E9BCF8B3-DA07-3F80-B51F-5793BD38AE4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff50d82000 - 0x7fff50dd0fff libTIFF.dylib (1821.6.4.1) <C432D21E-2DA5-3B69-BD04-BA7B6DBEAE2F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff510d2000 - 0x7fff51e55fff com.apple.JavaScriptCore (14606 - 14606.2.104.1.1) <3313A815-BFC9-3DED-B778-FCE6F8367A7C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff51e6d000 - 0x7fff51e86fff com.apple.Kerberos (3.0 - 1) <8BE3D524-257D-3663-A937-F1AC76BDF4D9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff51e87000 - 0x7fff51ebcffb com.apple.LDAPFramework (2.4.28 - 194.5) <DC361FB9-4B59-311E-8CC5-07FF9A9C673F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff52144000 - 0x7fff5214efff com.apple.MediaAccessibility (1.0 - 114.4) <29D89F2B-6254-3D0D-BD0C-8472FCA373F4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff52208000 - 0x7fff528a5fff com.apple.MediaToolbox (1.0 - 2282.19.104.4) <7603C180-8050-3355-A851-A67B6A4197AD> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff528a7000 - 0x7fff5293afff com.apple.Metal (157.60 - 157.60) <B38C577A-CD24-30AD-A396-219945949F39> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff5293c000 - 0x7fff52956ff3 com.apple.MetalKit (1.0 - 113) <8949A0FA-337E-3C28-94D1-35853D69761B> /System/Library/Frameworks/MetalKit.framework/Versions/A/MetalKit
0x7fff52957000 - 0x7fff52977ff7 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <A9E87429-4788-3B2F-B970-4052F16C5961> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x7fff52978000 - 0x7fff529f6ff7 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <80DE2FD1-85DB-3E98-98BD-F22A2600DD25> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
0x7fff529f7000 - 0x7fff52a1ffff com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <49039DEE-D0EC-33FF-BE10-997A520D2E38> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
0x7fff52a20000 - 0x7fff52b52ff7 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <425D1FA4-17A3-3D00-8BE4-7A682FF279B5> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
0x7fff52b53000 - 0x7fff52b6eff7 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <BB1651A0-05CD-3F97-8355-39CD326C0AFD> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
0x7fff52b6f000 - 0x7fff52b6fff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <3910EC50-5B16-3695-B867-741E3B54FA8B> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fff53d6e000 - 0x7fff53d7affb com.apple.NetFS (6.0 - 4.0) <529E29A9-5E77-3A8C-A982-CF55F949FE5D> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff56831000 - 0x7fff56839fe7 libcldcpuengine.dylib (2.10.3) <B8E5266D-999E-341C-A0CF-1571DD961669> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff5683a000 - 0x7fff56892ff7 com.apple.opencl (2.12.7 - 2.12.7) <CCAC9774-C4BF-33C1-AC87-F2AEB972632F> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff56893000 - 0x7fff568afff7 com.apple.CFOpenDirectory (10.14 - 207.200.4) <7E4EFF02-2596-31E6-88DE-29C89E2837E4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff568b0000 - 0x7fff568bcffb com.apple.OpenDirectory (10.14 - 207.200.4) <52A3918E-0F7A-33FD-87EE-21A37B37D13B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff5721f000 - 0x7fff57221fff libCVMSPluginSupport.dylib (17.0.37) <E47B2819-913A-3588-A3F5-CE3EDA8551A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff57222000 - 0x7fff57227ff3 libCoreFSCache.dylib (163.20) <BF8F04DD-C1A1-3D2A-BF3F-639FE907E28D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff57228000 - 0x7fff5722cfff libCoreVMClient.dylib (163.20) <45A2C724-F3D1-316A-9A41-CAB8E2A390EC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff5722d000 - 0x7fff57235ffb libGFXShared.dylib (17.0.37) <C26CA5C7-8DFC-3BE9-9873-C7A51F139FB0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff57236000 - 0x7fff57241fff libGL.dylib (17.0.37) <8DCB2714-ECB1-39EC-931D-C58D9E91B51C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff57242000 - 0x7fff5727cfef libGLImage.dylib (17.0.37) <B64C775F-C64F-35D7-8179-1E4F20E76BA3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff5727d000 - 0x7fff573efff3 libGLProgrammability.dylib (17.0.37) <7439D424-E469-33B4-9C6D-CABFDA5C3F95> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff573f0000 - 0x7fff5742dfff libGLU.dylib (17.0.37) <B0D434EF-F5AC-3C0A-84DF-FFAFC57F3759> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff57ddd000 - 0x7fff57decff3 com.apple.opengl (17.0.37 - 17.0.37) <6BCCA53E-5621-32ED-BA9A-38B1C2499ED5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff57ded000 - 0x7fff57f83ff7 GLEngine (17.0.37) <1FB756FE-A614-3044-B2BA-155FAC2F2E35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff57f84000 - 0x7fff57facff7 GLRendererFloat (17.0.37) <A0A86C7A-60B3-3900-AA0C-7CC6A4BF0D86> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff5816e000 - 0x7fff582b8fff com.apple.QTKit (7.7.3 - 3034) <D612DC6C-0AA8-3D41-9E17-E8219984FC65> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff582b9000 - 0x7fff58514fff com.apple.imageKit (3.0 - 1067) <A43B90AB-8FCB-35BF-996A-CEB28B67EEB5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff58515000 - 0x7fff58601fff com.apple.PDFKit (1.0 - 737.3) <F6981903-7259-3D89-B70E-855F970D84E7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff58602000 - 0x7fff58b18ff7 com.apple.QuartzComposer (5.1 - 370) <AA2ED670-1970-3888-B7DB-D11192EBF6BB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff58b19000 - 0x7fff58b3fff3 com.apple.quartzfilters (1.10.0 - 83) <06F25528-5474-39BF-BCD4-DD6B3203EA3C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff58b40000 - 0x7fff58c46ff7 com.apple.QuickLookUIFramework (5.0 - 775) <41F1FDD0-C99A-36D3-AC3A-A5E604D77F63> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff58c47000 - 0x7fff58c47fff com.apple.quartzframework (1.5 - 23) <EB8812C6-F126-3262-9B6A-A7A440DFBF8A> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff58c48000 - 0x7fff58ea0fff com.apple.QuartzCore (1.11 - 694.22.4.1) <1F5A49A9-370C-311B-B67C-DEA6DF6D2983> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff58ea1000 - 0x7fff58efaff7 com.apple.QuickLookFramework (5.0 - 775) <A4CA709A-2828-3F04-8786-7FAC8A95B98B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff590c1000 - 0x7fff590d9ffb com.apple.SafariServices.framework (14606 - 14606.2.104.1.1) <189C4DE0-5B88-388F-9CD1-AC15C3936CC2> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff596ee000 - 0x7fff59a14ff7 com.apple.security (7.0 - 58286.220.15) <6725D63D-378F-3751-8602-3122016E4AA4> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff59a15000 - 0x7fff59aa4fff com.apple.securityfoundation (6.0 - 55185.200.14) <236BACD7-163F-3F35-B710-2C62988AA251> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff59ad6000 - 0x7fff59adaff3 com.apple.xpc.ServiceManagement (1.0 - 1) <C200EC23-CAFB-33E8-AF3D-5B36420A21B1> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff59e97000 - 0x7fff59f07ff3 com.apple.SystemConfiguration (1.17 - 1.17) <EED5BC9B-CE8D-343C-BCDC-04A79F704828> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff5a168000 - 0x7fff5a4caff7 com.apple.VideoToolbox (1.0 - 2282.19.104.4) <AA64D2D5-B992-301C-B39E-90852E2DFC95> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff5d16e000 - 0x7fff5d213fe7 com.apple.APFS (1.0 - 1) <E00222C4-E8CF-302A-8AF3-E8BB9B1C3B0E> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fff5dc5d000 - 0x7fff5dc5eff3 com.apple.AggregateDictionary (1.0 - 1) <1DEBBE36-8945-3AD8-BD48-2850AD845711> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
0x7fff5e00b000 - 0x7fff5e154ff3 com.apple.AnnotationKit (1.0 - 232.3.27) <6CDA223B-CBDF-3960-AC34-BAD648CB580B> /System/Library/PrivateFrameworks/AnnotationKit.framework/Versions/A/AnnotationKit
0x7fff5e155000 - 0x7fff5e171ff7 com.apple.AppContainer (4.0 - 360.220.2) <C5B94E74-A1C6-3C89-969F-90B3B682A36C> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff5e172000 - 0x7fff5e17fff7 com.apple.AppSandbox (4.0 - 360.220.2) <B418C2E2-E553-34A7-A132-5E2B472A0359> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff5e25a000 - 0x7fff5e286ff7 com.apple.framework.Apple80211 (13.0 - 1376.2) <821DE2A3-1CAD-3A7D-A2DD-41EBA3A6FEF3> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff5e562000 - 0x7fff5e571fcf com.apple.AppleFSCompression (96.200.3 - 1.0) <E093776E-C367-3CCF-BFD5-623476A89E9A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff5e66f000 - 0x7fff5e67afff com.apple.AppleIDAuthSupport (1.0 - 1) <5362D9AD-A2AE-3436-97CE-C353124504E5> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fff5e6bb000 - 0x7fff5e704ff3 com.apple.AppleJPEG (1.0 - 1) <9A690E6E-F987-3660-BED6-B1A4D1906B6C> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff5e951000 - 0x7fff5e955ff7 com.apple.AppleSRP (5.0 - 1) <B8E2BEC9-FAFB-3E26-BF26-E2E58C545006> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff5e956000 - 0x7fff5e97eff7 com.apple.applesauce (1.0 - ???) <60BB16D6-DE7E-356A-B9DE-F73EE179934A> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
0x7fff5ea45000 - 0x7fff5ea48ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <A2EE39BD-C721-33BD-8549-E087C04CF784> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff5ea49000 - 0x7fff5ea99fff com.apple.AppleVAFramework (5.0.44 - 5.0.44) <A7D2AD26-D52A-39E0-8296-1ADDDB6B6CED> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff5eae4000 - 0x7fff5eafaffb com.apple.AssertionServices (1.0 - 1) <8FB0D908-6C46-3399-92D6-4E7D4B5F4F19> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
0x7fff5ee36000 - 0x7fff5f0d9ffb com.apple.AuthKit (1.0 - 1) <8920796A-C818-3163-B6D0-FD05D1A6ADF5> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fff5f2aa000 - 0x7fff5f2b3ff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <972F41B3-7DF7-3BF1-ACCA-A093A4328ADF> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0x7fff5f2b4000 - 0x7fff5f356ff7 com.apple.backup.framework (1.10 - ???) <46534B04-DD0E-357B-9CB5-F88AAC6AF4ED> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff5f357000 - 0x7fff5f3c8ffb com.apple.BaseBoard (360.24 - 360.24) <AC0E4924-994E-3B54-869C-C831B4DE0136> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x7fff5f3d1000 - 0x7fff5f3d7ff3 com.apple.BezelServicesFW (317 - 317) <44601C3E-4808-38A4-A554-71F36000B003> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
0x7fff6026c000 - 0x7fff602b9fff com.apple.ChunkingLibrary (194 - 194) <13F1F769-E8E7-372A-8F0B-2BB4B7753248> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff60f6c000 - 0x7fff60f78fff com.apple.CommerceCore (1.0 - 708.1.4) <8149AFE0-69D5-3CD0-8639-42B80043C851> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff60f79000 - 0x7fff60f82fff com.apple.CommonAuth (4.0 - 2.0) <93CF1D80-A3A8-378B-9DF7-BF17A206C57D> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff61442000 - 0x7fff61819fef com.apple.CoreAUC (273.0.0 - 273.0.0) <288EC7ED-A86A-30D0-ADE2-56C33CD93AA8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff6181a000 - 0x7fff6184bfff com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <507AC58B-4527-353B-99CB-67FF183BD4D5> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff618e3000 - 0x7fff61935ffb com.apple.corebrightness (1.0 - 1) <1AE1A7AE-506D-3A52-B710-9CFB16414EDC> /System/Library/PrivateFrameworks/CoreBrightness.framework/Versions/A/CoreBrightness
0x7fff61a79000 - 0x7fff61a82fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <8D971ACD-6A26-30A9-9C5B-BCBF60A661F1> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff61c94000 - 0x7fff61ca8fff com.apple.CoreEmoji (1.0 - 69.19.8) <E909BE8D-AE0C-327E-BE0A-D60B1F4012A4> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fff61e6e000 - 0x7fff61f62ff7 com.apple.CoreHandwriting (161 - 1.2) <0BD558D9-387B-34BA-8FAA-F1F75F1F9F01> /System/Library/PrivateFrameworks/CoreHandwriting.framework/Versions/A/CoreHandwriting
0x7fff62125000 - 0x7fff6213bffb com.apple.CoreMediaAuthoring (2.2 - 958) <FD761818-0B54-3DA6-B41C-20263BC2EDAE> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff6227e000 - 0x7fff622f0ff7 com.apple.CoreNLP (1.0 - 130.15.22) <401F5284-A984-32A1-A547-CC8156381070> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0x7fff62478000 - 0x7fff62505ff7 com.apple.CorePDF (4.0 - 414) <28DEBFFB-BABE-3493-8230-12CE3E5EC1E3> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff625ab000 - 0x7fff625b3ffb com.apple.CorePhoneNumbers (1.0 - 1) <F47CA56F-6760-3282-BFD8-C8C8D2C33ECF> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
0x7fff62742000 - 0x7fff62773fff com.apple.CoreServicesInternal (357 - 357) <2D012EB3-83BF-3E51-A2BE-41AF26F2DDF0> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff62b3d000 - 0x7fff62bcbff7 com.apple.CoreSymbolication (10.1 - 64460.6) <F985088F-5323-3D84-80FE-3A3135C4A320> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff62c5b000 - 0x7fff62d87fff com.apple.coreui (2.1 - 498.46) <7637C723-B16D-3001-B3AC-0612349D1CC5> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff62d88000 - 0x7fff62f0dfff com.apple.CoreUtils (5.7.4 - 574.17) <CA6C08FE-319A-30C6-9F07-68D12A9FA04E> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fff62f64000 - 0x7fff62fc7ffb com.apple.framework.CoreWiFi (13.0 - 1370.8) <B44C1B90-3642-3108-96EC-5E3A8FA158E7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff62fc8000 - 0x7fff62fd9ffb com.apple.CrashReporterSupport (10.13 - 938.23) <36754BB2-680F-36AE-A5DE-548B4F41F0AE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff6305c000 - 0x7fff6306bff3 com.apple.framework.DFRFoundation (1.0 - 211) <B11AD3BE-42D3-3274-912E-153C015D72EE> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fff6306c000 - 0x7fff63070ff7 com.apple.DSExternalDisplay (3.1 - 380) <B6B26BB3-2DC9-34D0-817E-EB612432EC96> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fff630f3000 - 0x7fff6316affb com.apple.datadetectorscore (7.0 - 590.24) <1C9AC888-8B75-3CF3-AD70-42D40C435E67> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff631b8000 - 0x7fff631f9fff com.apple.DebugSymbols (185 - 185) <12419E0F-BC7A-3F3A-AA53-5F068DAED725> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff631fa000 - 0x7fff63353ff7 com.apple.desktopservices (1.13.1 - ???) <D63561E0-6153-33AD-9689-E0B9167D82C8> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff63485000 - 0x7fff63557ff7 com.apple.DiskImagesFramework (480.220.2 - 480.220.2) <9921E083-1159-3671-92E5-868A88A11B1B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff63558000 - 0x7fff6361cfff com.apple.DiskManagement (12.0 - 1530) <F844A618-613A-3609-9C31-621D92FB75DD> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0x7fff6361d000 - 0x7fff63621ff7 com.apple.DisplayServicesFW (3.1 - 380) <511645F4-94EB-33A0-A076-66402F52581A> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff636c5000 - 0x7fff636c8fff com.apple.EFILogin (2.0 - 2) <8FCA68D2-CEA5-39F6-B222-AC31FCF79D1D> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff63ead000 - 0x7fff641e0fff com.apple.vision.EspressoFramework (1.0 - 120) <7B2CB758-7FD9-3D6B-9BD4-AFD254008BEF> /System/Library/PrivateFrameworks/Espresso.framework/Versions/A/Espresso
0x7fff6439b000 - 0x7fff647c3fff com.apple.vision.FaceCore (3.3.4 - 3.3.4) <CCBC466A-1AD4-3B0B-80B2-D6CFCBB37FC0> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff647cd000 - 0x7fff647efff7 com.apple.framework.familycontrols (4.1 - 410) <5C0ECAF5-4DDC-38BC-8876-8B7EBC4A5C72> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff680e5000 - 0x7fff680e6fff libmetal_timestamp.dylib (902.1.60) <16F3973E-20CB-3FFA-9C8B-A2287AF03AA0> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
0x7fff6977f000 - 0x7fff6978aff7 libGPUSupportMercury.dylib (17.0.37) <C064C162-B99E-3027-986D-9BAF7B979C5F> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff6978b000 - 0x7fff69790ff7 com.apple.GPUWrangler (3.25.6 - 3.25.6) <F65BC9B4-77AB-3254-8432-9F7D3B0E169E> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
0x7fff69b40000 - 0x7fff69b65ff7 com.apple.GenerationalStorage (2.0 - 285.101) <089301DF-60C9-3BED-9357-2F91336C1579> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff6a5f6000 - 0x7fff6a605fff com.apple.GraphVisualizer (1.0 - 5) <C7040CD7-6CAB-3878-B29E-21F1665341D0> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
0x7fff6a756000 - 0x7fff6a7cbfff com.apple.Heimdal (4.0 - 2.0) <D3A3285B-A45D-38A9-A4E9-D58D76674071> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff6bbb7000 - 0x7fff6bbbeffb com.apple.IOAccelerator (400.27 - 400.27) <6FA8A133-57A7-3C35-BF94-8469B09885FB> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff6bbc2000 - 0x7fff6bbdbfff com.apple.IOPresentment (1.0 - 42.6) <C115E88F-5E16-3804-8ACD-29C0F8895EFA> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fff6bff0000 - 0x7fff6c01fff7 com.apple.IconServices (379 - 379) <0A25D75C-35A7-3ED5-8900-EBC05522B5A9> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff6c14a000 - 0x7fff6c14efff com.apple.InternationalSupport (1.0 - 10.15.6) <F0E300AD-1E67-3D57-B179-C2212F7CD00C> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
0x7fff6c2be000 - 0x7fff6c2d1fff com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <1DB4E862-C010-38BA-B535-5DAD679FEADA> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fff6c2ec000 - 0x7fff6c3e3fff com.apple.LanguageModeling (1.0 - 159.15.15) <E524CC46-42C7-3046-AD6C-5D5D768EA478> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff6c3e4000 - 0x7fff6c425ff7 com.apple.Lexicon-framework (1.0 - 33.15.10) <90C1CFE1-9935-3F4F-8A9B-1DD697F2FF3D> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x7fff6c42c000 - 0x7fff6c432ff7 com.apple.LinguisticData (1.0 - 238.15.29) <A8DEE139-5D20-3BAC-AF5E-4E5E0C42C795> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0x7fff6c52b000 - 0x7fff6c530ffb com.apple.LoginUICore (4.0 - 4.0) <2528E230-11E9-3436-ADCF-ED149F50A264> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff6cc90000 - 0x7fff6cc93fff com.apple.Mangrove (1.0 - 25) <8744DBF9-3375-392C-8EE6-24373E0D19E8> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff6cd21000 - 0x7fff6cd48ffb com.apple.MarkupUI (1.0 - 232.3.27) <B78BC7CF-A267-3E53-A876-6F5C02BB2AB8> /System/Library/PrivateFrameworks/MarkupUI.framework/Versions/A/MarkupUI
0x7fff6cdb1000 - 0x7fff6cde4ff3 com.apple.MediaKit (16 - 906) <15D4EDA2-AAAC-3CF3-BB2B-3A92AECC932D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff6d18e000 - 0x7fff6d1b6ffb com.apple.spotlight.metadata.utilities (1.0 - 1191.52) <38A9B11A-9D5C-3CCA-A163-EC17242FDC68> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x7fff6d1b7000 - 0x7fff6d249fff com.apple.gpusw.MetalTools (1.0 - 1) <5B86F005-D12D-3B0B-8906-808926D3DA12> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x7fff6d3f3000 - 0x7fff6d40eff3 com.apple.MobileKeyBag (2.0 - 1.0) <6E36F030-D7E8-341D-A493-414F5E13B1E9> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fff6d41f000 - 0x7fff6d49bff7 com.apple.Montreal (1.0 - 42.15.8) <F7AAEEC2-B981-30C4-995F-4D98FB808984> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x7fff6d49c000 - 0x7fff6d4c6ff7 com.apple.MultitouchSupport.framework (2410.5 - 2410.5) <8D87A3ED-4CBD-300F-92E3-B1B79D7E0BF3> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff6d739000 - 0x7fff6d743fff com.apple.NetAuth (6.2 - 6.2) <55DC741A-A01A-380C-B2D3-244241DA1F2C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff6e00f000 - 0x7fff6e065fff com.apple.OTSVG (1.0 - ???) <5F2E7A0E-384E-3545-A9D5-EC4406E92AF4> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0x7fff6f0c4000 - 0x7fff6f1caff7 com.apple.PencilKit (1.0 - 1) <188DB13A-53B4-3F3C-8433-193AEAFDF17D> /System/Library/PrivateFrameworks/PencilKit.framework/Versions/A/PencilKit
0x7fff6f1cb000 - 0x7fff6f1daff3 com.apple.PerformanceAnalysis (1.217 - 217) <8560F263-31F4-3CCA-84B1-30C296DC1A7D> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff71142000 - 0x7fff71199ff7 com.apple.ProtectedCloudStorage (1.0 - 1) <C37D89CF-707A-3151-A37B-911AF6BF3B23> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff7119a000 - 0x7fff711b8ff7 com.apple.ProtocolBuffer (1 - 263) <C5AC21FB-74AD-3FC2-B231-B1376751BBAE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff7134c000 - 0x7fff7134fff3 com.apple.QuickLookNonBaseSystem (1.0 - 1) <ABB9436A-7E52-3232-ACE8-45083130C82A> /System/Library/PrivateFrameworks/QuickLookNonBaseSystem.framework/Versions/A/QuickLookNonBaseSystem
0x7fff71350000 - 0x7fff71366ff3 com.apple.QuickLookThumbnailing (1.0 - 1) <AAF7A93C-5553-3476-B2F2-B8B1DA2BEF54> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0x7fff71367000 - 0x7fff713bff0f com.apple.ROCKit (24 - 24) <5437F6F7-453F-3D75-9E87-D2A090D82D25> /System/Library/PrivateFrameworks/ROCKit.framework/Versions/A/ROCKit
0x7fff714bb000 - 0x7fff714c7ff3 com.apple.xpc.RemoteServiceDiscovery (1.0 - 1336.220.5) <79F17D52-38B4-360E-88AC-CF1E3944CA7E> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
0x7fff714da000 - 0x7fff714fdffb com.apple.RemoteViewServices (2.0 - 128) <68530B4D-B2C0-3271-941B-D9EA62095727> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff714fe000 - 0x7fff71512fff com.apple.xpc.RemoteXPC (1.0 - 1336.220.5) <D258016E-4FE2-3E99-9699-33D56BADD619> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
0x7fff72d05000 - 0x7fff72d08ff7 com.apple.SecCodeWrapper (4.0 - 360.220.2) <763BAC4A-DC1A-3C0F-BFF4-88D0E0A3804F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff72e6d000 - 0x7fff72f8bfff com.apple.Sharing (1214.9 - 1214.9) <2A377CA5-C66F-3913-8401-951A3AE4D299> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff73d3e000 - 0x7fff73fefff3 com.apple.SkyLight (1.600.0 - 336.81.5) <DE7FD278-A178-3A5B-8A26-7295340A54BE> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fff747bf000 - 0x7fff747ccfff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <816EC315-3E76-37B7-A495-B4AE031DA439> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff7562c000 - 0x7fff756b9ff7 com.apple.Symbolication (10.1 - 64460.8) <1B488612-4C7F-3D9D-B6DC-64CF8D2CB3D6> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff75915000 - 0x7fff75941fff com.apple.framework.SystemAdministration (1.0 - 1.0) <E41D573A-C356-344E-9E67-809F30D9DEF4> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff75bc2000 - 0x7fff75bcfffb com.apple.TCC (1.0 - 1) <B84E7234-A993-328C-A054-EFEB0402C55C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff75e41000 - 0x7fff75f08ff7 com.apple.TextureIO (3.8.4 - 3.8.1) <F9D5F55D-9A33-326E-8B2F-B533CC91DD64> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fff75fc2000 - 0x7fff75fc3fff com.apple.TrustEvaluationAgent (2.0 - 31.200.1) <BD0BE410-E172-3585-82B2-869A1FE43092> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff75fc9000 - 0x7fff76183fff com.apple.UIFoundation (1.0 - 551) <7B73C4E0-256B-3C59-8E18-475A42BE0B12> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff76e72000 - 0x7fff76f5bff7 com.apple.ViewBridge (401.1 - 401.1) <B93A89EB-4421-3FF1-AA28-EBC3AC5076FE> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff7777b000 - 0x7fff7777efff com.apple.dt.XCTTargetBootstrap (1.0 - 1) <697834E4-FEFD-305C-80EE-5052E61573FA> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x7fff77baf000 - 0x7fff77bb1ff3 com.apple.loginsupport (1.0 - 1) <5F1E000D-0674-3413-AB3E-83F7974666FB> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff77e6b000 - 0x7fff77ea3fff libCRFSuite.dylib (41.15.4) <62EDD39F-6D1B-334B-A9A2-5800714255BB> /usr/lib/libCRFSuite.dylib
0x7fff77ea6000 - 0x7fff77eb1ff7 libChineseTokenizer.dylib (28.15.3) <8CD1C213-7F62-3F02-BFB1-D0A5EFF92AB0> /usr/lib/libChineseTokenizer.dylib
0x7fff77eb2000 - 0x7fff77f3eff7 libCoreStorage.dylib (546.50.1) <F56AD958-416C-38EA-9829-DEAAB1F0C155> /usr/lib/libCoreStorage.dylib
0x7fff77f42000 - 0x7fff77f43ff7 libDiagnosticMessagesClient.dylib (107) <C542CB3C-AA44-3D7F-B88C-79CC31B481AB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff77f7a000 - 0x7fff7813dff7 libFosl_dynamic.dylib (18.3.2) <6EF1CB2A-2BDA-3458-B631-F794D72660FD> /usr/lib/libFosl_dynamic.dylib
0x7fff7815e000 - 0x7fff78165fff libMatch.1.dylib (31.200.1) <20216A5F-C625-3D87-9D95-C577F8687F6F> /usr/lib/libMatch.1.dylib
0x7fff78193000 - 0x7fff781b2fff libMobileGestalt.dylib (645.220.9) <F303B3D9-C6AD-30B9-9414-09DB34357E12> /usr/lib/libMobileGestalt.dylib
0x7fff781b3000 - 0x7fff781b3fff libOpenScriptingUtil.dylib (179) <0664670D-C7E1-3D27-814B-B9C445AAF0DC> /usr/lib/libOpenScriptingUtil.dylib
0x7fff782f4000 - 0x7fff782f5ffb libSystem.B.dylib (1252.200.5) <D5AFCC78-2AC2-37EB-B0EF-BB00FD38ED00> /usr/lib/libSystem.B.dylib
0x7fff7837f000 - 0x7fff78380fff libThaiTokenizer.dylib (2.15.1) <A8235B04-F541-3856-BE2E-B58EE0483AD9> /usr/lib/libThaiTokenizer.dylib
0x7fff78393000 - 0x7fff783a9ffb libapple_nghttp2.dylib (1.24.1) <B8D45114-3868-3154-BC35-22597E3E7D8A> /usr/lib/libapple_nghttp2.dylib
0x7fff783aa000 - 0x7fff783d3ffb libarchive.2.dylib (54.200.3) <B47C54A0-3A30-374A-BD99-2304B9B0EC82> /usr/lib/libarchive.2.dylib
0x7fff783d4000 - 0x7fff78453fef libate.dylib (1.13.8) <C647A80F-6F80-3FDA-A9B4-92800999F963> /usr/lib/libate.dylib
0x7fff78457000 - 0x7fff78457ff3 libauto.dylib (187) <01824E49-F2EF-3FC1-ABF3-782EFDF6CA17> /usr/lib/libauto.dylib
0x7fff7852e000 - 0x7fff7853eff3 libbsm.0.dylib (39.200.18) <5E5098D0-F7B2-32A1-8038-E709F6718D4E> /usr/lib/libbsm.0.dylib
0x7fff7853f000 - 0x7fff7854dfff libbz2.1.0.dylib (38.200.3) <4EE3C5E8-BEF3-3910-A231-B1AE2B437E01> /usr/lib/libbz2.1.0.dylib
0x7fff7854e000 - 0x7fff785a5ff7 libc++.1.dylib (400.9.4) <D4AB366F-48A9-3C7D-91BD-41198F69DD57> /usr/lib/libc++.1.dylib
0x7fff785a6000 - 0x7fff785bbfff libc++abi.dylib (400.17) <BA948A32-9024-3E55-98D4-18E31F6AED25> /usr/lib/libc++abi.dylib
0x7fff785bc000 - 0x7fff785bcff3 libcharset.1.dylib (51.200.6) <D998A58B-E4A8-3685-9A6A-43AFC28100EB> /usr/lib/libcharset.1.dylib
0x7fff785bd000 - 0x7fff785cdffb libcmph.dylib (6.15.1) <5D776FF6-DF7F-3EDD-B920-C07ED76C672B> /usr/lib/libcmph.dylib
0x7fff785ce000 - 0x7fff785e6ffb libcompression.dylib (52.200.13) <EA767836-CBDC-318D-AC14-963C90D6CC67> /usr/lib/libcompression.dylib
0x7fff78891000 - 0x7fff788a7fff libcoretls.dylib (155.220.1) <3F98C144-397C-36A2-84F1-BB0D841D3D89> /usr/lib/libcoretls.dylib
0x7fff788a8000 - 0x7fff788a9ff3 libcoretls_cfhelpers.dylib (155.220.1) <0C190169-8EB8-3BA2-89BB-60265BB502F9> /usr/lib/libcoretls_cfhelpers.dylib
0x7fff78a48000 - 0x7fff78bd8ff3 libcrypto.35.dylib (22.200.4) <B4F83304-FB35-3CA5-8949-DE7D75B8A9D9> /usr/lib/libcrypto.35.dylib
0x7fff78d73000 - 0x7fff78f0bff7 libcrypto.42.dylib (22.200.4) <EFCEE49A-759B-3A9A-A164-ECD1A98D40F9> /usr/lib/libcrypto.42.dylib
0x7fff78f0c000 - 0x7fff78f17ff7 libcsfde.dylib (546.50.1) <65E8F1F1-665A-381E-8932-D7CBA451991B> /usr/lib/libcsfde.dylib
0x7fff78f20000 - 0x7fff78f76ffb libcups.2.dylib (462.9) <51E06E95-891F-3B88-A8C3-35B514C57239> /usr/lib/libcups.2.dylib
0x7fff78fa0000 - 0x7fff78ff4ff3 libcurl.4.dylib (105.200.2) <607613FE-3D84-3035-9C79-C6F72AF287D7> /usr/lib/libcurl.4.dylib
0x7fff790ae000 - 0x7fff790aefff libenergytrace.dylib (17.200.1) <D62ED169-B91C-3CCB-ADF5-E66AE4007B51> /usr/lib/libenergytrace.dylib
0x7fff790e0000 - 0x7fff790e5ff7 libgermantok.dylib (17.15.2) <9CBF0658-E83B-32E6-B674-3EE72D22C041> /usr/lib/libgermantok.dylib
0x7fff790e6000 - 0x7fff790ebff7 libheimdal-asn1.dylib (520.220.2) <5302394C-ECF0-3C3B-BA67-4830EEF3CC40> /usr/lib/libheimdal-asn1.dylib
0x7fff79117000 - 0x7fff79208ff7 libiconv.2.dylib (51.200.6) <3240A278-F537-3EC8-BE0C-983797520A50> /usr/lib/libiconv.2.dylib
0x7fff79209000 - 0x7fff7946cffb libicucore.A.dylib (62108.0.1) <969815D4-A345-31BB-82B7-0C3B58CA7E90> /usr/lib/libicucore.A.dylib
0x7fff794b9000 - 0x7fff794bafff liblangid.dylib (128.15.1) <F79B6250-C0B1-3E8E-851F-6CA33B4311A3> /usr/lib/liblangid.dylib
0x7fff794bb000 - 0x7fff794d3fff liblzma.5.dylib (10.200.3) <3ADDFA63-F37A-3C9C-91E4-58EE3113B9A1> /usr/lib/liblzma.5.dylib
0x7fff794eb000 - 0x7fff7959bfff libmecab.1.0.0.dylib (779.19.2) <314FE1B9-3B4E-3B89-A101-33CE7B78FCE6> /usr/lib/libmecab.1.0.0.dylib
0x7fff7959c000 - 0x7fff797d9fff libmecabra.dylib (779.19.2) <0ECEC3FC-935D-3EA5-8B3D-5CBD4E80AB78> /usr/lib/libmecabra.dylib
0x7fff799b1000 - 0x7fff79d09fff libnetwork.dylib (1229.221.1) <CE7ACD18-109F-382E-963B-C68419E301A1> /usr/lib/libnetwork.dylib
0x7fff79d9a000 - 0x7fff7a520fe7 libobjc.A.dylib (750.1) <9CE27EC3-3A12-35D1-8F2F-3550B9668259> /usr/lib/libobjc.A.dylib
0x7fff7a521000 - 0x7fff7a522fff libodfde.dylib (24.50.1) <B948D85A-165F-3E58-A8DD-24CF6454380A> /usr/lib/libodfde.dylib
0x7fff7a533000 - 0x7fff7a537ffb libpam.2.dylib (22.200.1) <8C419238-675A-3C41-B8D4-95E391CA630F> /usr/lib/libpam.2.dylib
0x7fff7a53a000 - 0x7fff7a570ff7 libpcap.A.dylib (79.200.4) <5939AB23-B2A9-3C03-B6C1-4F0E5A21D9FC> /usr/lib/libpcap.A.dylib
0x7fff7a68a000 - 0x7fff7a6a2ffb libresolv.9.dylib (65.200.2) <0FEAEB01-B926-37FA-AB47-99BAC481C10B> /usr/lib/libresolv.9.dylib
0x7fff7a6a4000 - 0x7fff7a6e0ff7 libsandbox.1.dylib (851.220.9) <99DBBAFF-AF3A-31D6-ACAA-D9B63A599E08> /usr/lib/libsandbox.1.dylib
0x7fff7a6e1000 - 0x7fff7a6f3ff7 libsasl2.2.dylib (211) <205CC13E-4ED7-3CE9-987F-12B28C6115A7> /usr/lib/libsasl2.2.dylib
0x7fff7a6f4000 - 0x7fff7a6f5ff7 libspindump.dylib (267.1) <528373EB-C7E9-3682-80CC-0EFCE0F3391D> /usr/lib/libspindump.dylib
0x7fff7a6f6000 - 0x7fff7a8cdfe7 libsqlite3.dylib (274.20) <4434B695-BC65-30D6-AFED-1B6488DB3D2E> /usr/lib/libsqlite3.dylib
0x7fff7a9d0000 - 0x7fff7aa1dfff libssl.44.dylib (22.200.4) <CF4931A6-5928-3E2B-8E31-1854F36B0C19> /usr/lib/libssl.44.dylib
0x7fff7aa1e000 - 0x7fff7aa6fff7 libstdc++.6.dylib (104.1) <0E48A478-4CFD-3111-8027-1047508A1D73> /usr/lib/libstdc++.6.dylib
0x7fff7ab5a000 - 0x7fff7ab5dffb libutil.dylib (51.200.4) <91EE9BF4-FB06-3260-B502-7EFDAD5AF59B> /usr/lib/libutil.dylib
0x7fff7ab5e000 - 0x7fff7ab6bfff libxar.1.dylib (404) <4B4D0206-0B62-3E89-AD07-E7BB9E4DFA68> /usr/lib/libxar.1.dylib
0x7fff7ab70000 - 0x7fff7ac53fff libxml2.2.dylib (32.8) <1CE77741-2E67-34B6-BB9F-B8E043966FCE> /usr/lib/libxml2.2.dylib
0x7fff7ac54000 - 0x7fff7ac7cff3 libxslt.1.dylib (16.1) <F191E8B9-7530-30CA-873B-2FA2BF2D6374> /usr/lib/libxslt.1.dylib
0x7fff7ac7d000 - 0x7fff7ac8fffb libz.1.dylib (70.200.4) <99A3D725-8388-38B4-B66C-5E9006E6F072> /usr/lib/libz.1.dylib
0x7fff7ad00000 - 0x7fff7ad04ff3 libcache.dylib (81) <FE21A7E9-DBEB-33AC-836B-785AD036ACF4> /usr/lib/system/libcache.dylib
0x7fff7ad05000 - 0x7fff7ad0fff3 libcommonCrypto.dylib (60118.220.1) <1099E427-6E81-3059-87AF-6F5FD81CA998> /usr/lib/system/libcommonCrypto.dylib
0x7fff7ad10000 - 0x7fff7ad17fff libcompiler_rt.dylib (63.4) <A4D9CF37-D076-3CE9-95F1-DA89DA1601B6> /usr/lib/system/libcompiler_rt.dylib
0x7fff7ad18000 - 0x7fff7ad21ff3 libcopyfile.dylib (146.200.3) <4BCDADBF-79F5-3829-B47D-64DA0D44BCBF> /usr/lib/system/libcopyfile.dylib
0x7fff7ad22000 - 0x7fff7ada6fdf libcorecrypto.dylib (602.220.6) <E1046E01-A2FD-35B4-B018-ACC372F3880E> /usr/lib/system/libcorecrypto.dylib
0x7fff7ae2d000 - 0x7fff7ae67ff7 libdispatch.dylib (1008.220.2) <D8B56783-152A-34A8-94E9-8E6BAE049384> /usr/lib/system/libdispatch.dylib
0x7fff7ae68000 - 0x7fff7ae97fff libdyld.dylib (635.2) <1B79A5CE-125F-301F-A441-C1869573AED0> /usr/lib/system/libdyld.dylib
0x7fff7ae98000 - 0x7fff7ae98ffb libkeymgr.dylib (30) <A73AA788-C35C-3284-BFCA-95B1BBDF0CF3> /usr/lib/system/libkeymgr.dylib
0x7fff7ae99000 - 0x7fff7aea5ff7 libkxld.dylib (4903.221.2) <16D75C5C-584A-3848-84C0-3BFB312AEB92> /usr/lib/system/libkxld.dylib
0x7fff7aea6000 - 0x7fff7aea6ff7 liblaunch.dylib (1336.220.5) <95EB6EAF-2DC5-344F-BADB-CA4E35E4E503> /usr/lib/system/liblaunch.dylib
0x7fff7aea7000 - 0x7fff7aeacfff libmacho.dylib (921) <ECC4E97C-575E-3A08-8191-BF02D7D4E637> /usr/lib/system/libmacho.dylib
0x7fff7aead000 - 0x7fff7aeafffb libquarantine.dylib (86.220.1) <6AE5AEEC-A9FD-3CF8-92DD-12B5AFBE12DE> /usr/lib/system/libquarantine.dylib
0x7fff7aeb0000 - 0x7fff7aeb1ff3 libremovefile.dylib (45.200.2) <D74A307B-3DC7-3992-B16C-DACB8207BE13> /usr/lib/system/libremovefile.dylib
0x7fff7aeb2000 - 0x7fff7aec9ff3 libsystem_asl.dylib (356.200.4) <EC9D8AD4-E5CB-3765-804A-9E1E9DC045D2> /usr/lib/system/libsystem_asl.dylib
0x7fff7aeca000 - 0x7fff7aecafff libsystem_blocks.dylib (73) <26419398-C30C-30F1-B656-A92AFA9560F6> /usr/lib/system/libsystem_blocks.dylib
0x7fff7aecb000 - 0x7fff7af53fff libsystem_c.dylib (1272.200.26) <3DEEE96E-6DF6-35AD-8654-D69AC26B907B> /usr/lib/system/libsystem_c.dylib
0x7fff7af54000 - 0x7fff7af57ff7 libsystem_configuration.dylib (963.200.27) <02CC3996-B34E-333C-8806-AE2699D34424> /usr/lib/system/libsystem_configuration.dylib
0x7fff7af58000 - 0x7fff7af5bff7 libsystem_coreservices.dylib (66) <254B6849-2C8F-302C-8616-B8324A11AB30> /usr/lib/system/libsystem_coreservices.dylib
0x7fff7af5c000 - 0x7fff7af62ffb libsystem_darwin.dylib (1272.200.26) <974E9EF7-DE72-34B7-B056-0A81C10DF8EB> /usr/lib/system/libsystem_darwin.dylib
0x7fff7af63000 - 0x7fff7af69ff7 libsystem_dnssd.dylib (878.200.35) <FFC665AA-B257-35AD-BD8B-32FD42C2EEC1> /usr/lib/system/libsystem_dnssd.dylib
0x7fff7af6a000 - 0x7fff7afb6ff3 libsystem_info.dylib (517.200.9) <0707C387-D7DE-372E-8FF1-3DE5C91932D6> /usr/lib/system/libsystem_info.dylib
0x7fff7afb7000 - 0x7fff7afdeff7 libsystem_kernel.dylib (4903.221.2) <0E882078-7330-3B49-AA5D-3CDB5645A4E5> /usr/lib/system/libsystem_kernel.dylib
0x7fff7afdf000 - 0x7fff7b02aff7 libsystem_m.dylib (3158.200.7) <43D1796B-954F-37D6-B1AC-9D80DF0655A2> /usr/lib/system/libsystem_m.dylib
0x7fff7b02b000 - 0x7fff7b04fff7 libsystem_malloc.dylib (166.220.1) <3B196122-4E0D-3E3F-AA3E-5115B976DE26> /usr/lib/system/libsystem_malloc.dylib
0x7fff7b050000 - 0x7fff7b05bff3 libsystem_networkextension.dylib (767.220.1) <C54EB8F6-F305-3452-8DB1-F7DA6859AF8C> /usr/lib/system/libsystem_networkextension.dylib
0x7fff7b05c000 - 0x7fff7b063fff libsystem_notify.dylib (172.200.21) <BCCB222F-DC64-3954-A836-DCCE6659CA5A> /usr/lib/system/libsystem_notify.dylib
0x7fff7b064000 - 0x7fff7b06dfef libsystem_platform.dylib (177.200.16) <B75B04AD-69FE-3ADE-84D2-C17972FC8F49> /usr/lib/system/libsystem_platform.dylib
0x7fff7b06e000 - 0x7fff7b078fff libsystem_pthread.dylib (330.220.2) <4958273C-4273-3501-8137-E44249E10D9C> /usr/lib/system/libsystem_pthread.dylib
0x7fff7b079000 - 0x7fff7b07cff7 libsystem_sandbox.dylib (851.220.9) <4D6433A8-C703-3ED9-82EB-B9E481A0FD2F> /usr/lib/system/libsystem_sandbox.dylib
0x7fff7b07d000 - 0x7fff7b07fff3 libsystem_secinit.dylib (30.220.1) <6C681113-8C48-3256-BEF6-0C3723DEB926> /usr/lib/system/libsystem_secinit.dylib
0x7fff7b080000 - 0x7fff7b087ff7 libsystem_symptoms.dylib (820.227.2) <3147D594-F41F-35FD-BF0B-6B8B66A407DE> /usr/lib/system/libsystem_symptoms.dylib
0x7fff7b088000 - 0x7fff7b09dff7 libsystem_trace.dylib (906.220.1) <D5045DC5-A165-3238-A470-1796F12BF84F> /usr/lib/system/libsystem_trace.dylib
0x7fff7b09f000 - 0x7fff7b0a4ffb libunwind.dylib (35.4) <41222EF6-2233-3CF4-947A-15D48CB8C030> /usr/lib/system/libunwind.dylib
0x7fff7b0a5000 - 0x7fff7b0d5fff libxpc.dylib (1336.220.5) <B2137772-E202-3656-A089-F6DD517007D5> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 6083
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=465.3M resident=0K(0%) swapped_out_or_unallocated=465.3M(100%)
Writable regions: Total=629.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=629.2M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 2
Activity Tracing 256K 2
CG backing stores 22.5M 5
CoreGraphics 8K 2
CoreImage 24K 2
CoreUI image data 808K 10
CoreUI image file 208K 5
Foundation 4K 2
Kernel Alloc Once 8K 2
MALLOC 206.6M 40
MALLOC guard page 32K 9
MALLOC_NANO (reserved) 384.0M 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
OpenGL GLSL 128K 2
STACK GUARD 56.0M 13
Stack 13.6M 13
VM_ALLOCATE 212K 20
__DATA 35.3M 319
__FONT_DATA 4K 2
__GLSLBUILTINS 5176K 2
__LINKEDIT 216.3M 7
__TEXT 249.0M 320
__UNICODE 564K 2
mapped file 55.9M 29
shared memory 756K 15
TOTAL 1.2G 804
TOTAL, minus reserved VM space 863.4M 804
Model: MacBookPro14,2, BootROM 184.0.0.0.0, 2 processors, Intel Core i7, 3.5 GHz, 16 GB, SMC 2.44f1
Graphics: Intel Iris Plus Graphics 650, Intel Iris Plus Graphics 650, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
Memory Module: BANK 1/DIMM0, 8 GB, LPDDR3, 2133 MHz, 0x802C, 0x4D5435324C31473332443450472D30393320
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x171), Broadcom BCM43xx 1.0 (7.77.61.1 AirPortDriverBrcmNIC-1305.2)
Bluetooth: Version 6.0.9f2, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi 2, AirPort, en0
USB Device: USB 3.0 Bus
USB Device: iBridge
Thunderbolt Bus: MacBook Pro, Apple Inc., 39.2
Based on what I'm seeing in the crash dump, it looks like the version of the Flash Player Projector that's getting launched is super old, and is most likely incompatible with current versions of MacOS.
I'm not really sure what's going on there. I'm downloading Captivate at the moment to see what version they bundle, but it will take a while.
You can get a current version of the Flash Player projector from here:
Adobe Flash Player - Debug Downloads
I'm not exactly sure if that will fix it, or if you'll need to do some additional work to get Captivate to use it.
Once I get it installed, I'll update the thread with what I figure out.
Thanks!
Ok. I tried downloading the current Adobe Flash Player and still got the error messages but will try again.
Thanks.
Flash Player is not the same thing as Flash Projector.
Right. I meant to say that I downloaded flash player projector and Flash Player. Perhaps I missed a step somewhere.
I played around with this, and I can reproduce the issue that you're describing.
I'm not a Captivate expert. My hope was that you could drop the current standalone player (we use "standalone player" and "projector" interchangeably, in case I slip and call it the wrong thing again) into the correct location in Captivate and it would just work, but that doesn't appear to be the case. Captivate actually includes a little built-in player, which uses Flash Player as a component under the hood. It doesn't look like I can just swap that out without breaking the parent application.
Have you talked to Captivate support at this point? They may have an answer already.
In the meantime, I've sent an email to the Captivate team to let them know that we're getting reports of this, and to see if they have a workaround that will resolve this for you quickly.
I'll update the thread as soon as I know more.
No, I have not contacted anyone at captivate because I thought the instructions on the ADOBE website said to post questions in the forum .
I will wait to hear back from you .
Thank you .
Flash Player is a free product, and Adobe doesn't offer technical support for free products. If you were looking for support on Flash Player, it would definitely direct you to the forums, but in this instance, it's really a Captivate problem because they're bundling Flash as an underlying technology component. It's not the Flash Player on your system that's crashing, but the one baked into Captivate.
Captivate is a paid product, and you should be entitled to direct support. That said, I totally get it if you want to wait for a response. It seems like a relatively new issue, and I don't see any indications that it's generating a lot of support traffic at the moment. I don't see evidence that the support team has a handy solution ready at this point.
I don't expect to hear back from the right people on the Captivate engineering team until the morning (at the earliest), just FYI.
Just for completeness, if you do want to talk to support about Captivate, the contact information is on the page below:
Ok. Thank you For the feedback and suggestions. I won’t be able to get to Customer Support until Friday because I’m doing a training all day.
I don’t know how to export to HTML or SWF (The latter Is the current format of the files I can’t open now.)
Also, I don't fully know what the workflow you're using is, but if you can export the project to HTML or SWF, then you should be able to open the HTML with the current Flash Player version hosted in your browser, or you could open the resulting SWF with the current Projector version that you downloaded.
That probably doesn't help much with the built-in preview (I imagine this is where this is getting used), but hopefully it helps you work around the issue a little while it gets sorted out.
Hi Nya Flores,
When I download the latest standalone Flash Player from Adobe Flash Player - Debug Downloads and try to open the SWF, it worked fine. someone from Captivate Support will contact you and resolve the issue.
If this doesn't get resolved. Please write to me at sankaram@adobe.com.
Sankaram
Adobe Captivate Team.
Ok. Thank you for the update.
