I want to get the meta data of the document when open..
so i have used "documentAfterActive" event and get meta data of the opened document in indesign..
but if font missing dialog/any other dialog shown then that function returns the following error..
I have also tried with user interaction level but did not worked..
Pls help
Did you try InDesign's afterOpen event ?
Apart from that this dialog should be discarded by user interaction levels, which syntax did you use ?
yes... i have tried with afterOpen
but i have found the solution with beforeOpen event..
function beforeOpen(eve){
eve.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
if you have any other solutions.. please share with me
