2 Replies Latest reply on Mar 21, 2008 7:08 AM by Cathacour
    Back from an attached .pdf
    Cathacour Level 1
      Help!
      I insered a button which opens a .pdf document. It works!
      But, when closing, how to program to come back into the swf at the screen we were before :
      - if I close the pdf window, the whole swf closes
      - if I use the "back button" of the navigator, the swf starts at the beginning.
      Any idea?
      PS : I have only the captivate.1 version
        • 1. Re: Back from an attached .pdf
          Hi Cathacour and welcome to our community
          Where you are setting the options for opening the PDF, look to the right and you should see a down arrow button. Click that button and you should see an option titled New. Choose that option and your PDF should then open in a new browser instance.
          This next bit is important, so don't stop reading yet. Before closing the dialog, click that down arrow button again. (Yes, I know you already clicked it once) This time through, DE-select the bottom option of "Continue playing movie".
          Give that a go and it should work.
          Cheers... Rick
          • 2. Re: Back from an attached .pdf
            Cathacour Level 1
            2 clicks and one publish later, I attest it works!
            Thank you for my saver!
