I was working on a project for my corp tax class and decided to download and use Adobe fill-able PDF files to input the data onto the right forms. Unfortunately, I got excited and signed the return but am not finished. I need to know how to delete the signature so I can move forward. I am tire and this is due Monday. It is now 1:30am on Sunday morning and HELP!
Thank you! K
Hi Karenh,
Once you add a signature to the PDF form, it is not possible to make any changes to that PDF.
If you have added the signature using the Fill & Sign, you will not be able to make any changes to the already filled form fields.
However, you can fill in the remaining form fields.
If you have added the Digital Signature, the PDF is locked and you will not be able to make any change to it.
You will need to download the form again and fill it again.
There is no other option.
Hope that answers your
...Copy link to clipboard
Hi Karenh,
Hope that answers your query.
Let us know if you have any questions.
Regards,
Meenakshi
That's not accurate. If you signed the form using a Digital Signature field you can right-click the field and select Clear Signature, which will return the document to an editable state. It will even "un-lock" any form fields that were set to be locked when the signature was applied.
na moim dokumencie opcja "usuń podpis" nie dział, klikam ale dokument dalej jest zablkowany i podpisany, prawa musza nei mam opcji odblokuj, usuń podpis ani nic takiego
Thank you. I had a feeling this was the case, but was hoping not. I need to make changes and now and don't have a blank one.
