Hello,
My plugins rename param on cmd PF_Cmd_UPDATE_PARAMS_UI
PF_ParamDef param_copy = *params[id];
strcpy( param_copy.name, parameter.name );param_copy.uu.change_flags = PF_ChangeFlag_CHANGED_VALUE;
ERR( suites.ParamUtilsSuite3()->PF_UpdateParamUI( in_data->effect_ref,
id,
¶m_copy ) )
but, if I close and open solution, name of param return to default, and don't call cmd PF_Cmd_UPDATE_PARAMS_UI.
Maybe as it is possible to force this event?
Thanks!
indeed, param names don't save with the project and get reset when a
project is loaded.
technically, you can change param names during USER_CHANGED_PARAM, however,
conceptually, it should be done during UPDATE_PARAMS_UI.
the latter, is sent when in instance is either created or loaded (and a
bunch of other occasions).
if you can't deduce the correct name changing during "update params" and
can only do so during "user changed param", consider storing the relevant
data in sequence_data during "user change param", where you can access it
later during "update params ui". sequence data can also be stored with the
project, and therefore will be available when the saved project is loaded.
On Sun, Dec 9, 2018 at 6:30 PM yuriy_levchenko <forums_noreply@adobe.com>
The problem is that after creating and calling PF_Cmd_SEQUENCE_RESETUP I set the flag
out_data-> out_flags | = PF_OutFlag_REFRESH_UI
but the PF_Cmd_UPDATE_PARAMS_UI is not called.
do you have PF_OutFlag_SEND_UPDATE_PARAMS_UI set on global setup?
in any case, UPDATE_PARAMS_UI will be sent on the first time the effect
instance is visible on the ECW, and not necessarily right after
SEQUENCE_RESETUP.
point being, you should get a "update params ui" call at the relevant time.
On Sun, Dec 9, 2018 at 9:56 PM yuriy_levchenko <forums_noreply@adobe.com>
Yes, I have PF_OutFlag_SEND_UPDATE_PARAMS_UI,
But, until I click on the effect, this event will not be sent and I see the default name.
The task is to transfer data from the plugin to the script, I need to pass a string. And I decided to change the name of one and attributes, and read it in the script
when and how is the script triggered?
On Mon, Dec 10, 2018 at 8:54 PM yuriy_levchenko <forums_noreply@adobe.com>
My effect add shader on layer, and I need to get some data from the shader to script export. I put this data to param name. I already understand that this is not the right way. But maybe you know how to get to the internal data of the effect from the script, such as the string name of the shader?
the simplest way to pass data to a script is to define an argument in the
javascript function, and call that function using AEGP_ExecuteScript(),
with a string containing the function name and arg. (for example:
"myFunction('string arg');")
alas, i don't what triggers that script, and does that component have
access to the relevant data to determine the correct value.
so: what determines that string's value? you mentioned it's happening
during USER_CHANGED_PARAM. can the same decision making happen at other
times?
On Mon, Dec 10, 2018 at 9:22 PM yuriy_levchenko <forums_noreply@adobe.com>
need the opposite, from script get access to effect internal data. how am i doing now, I collect data and call AEGP_ExecuteScript where app.settings.saveSetting I save my data. But I need to know the key by which I saved. So I’m trying to keep this key in the param name
we seem to miss the mark with our dialogue...
if the param name is being determined during USER_CHANGED_PARAM, can it not
be determined at some other time, such as when ExecuteScript is being
called?
(when you said you keep effect instance data stored in the app settings i
got that i don't understand your process at all)
On Mon, Dec 10, 2018 at 10:00 PM yuriy_levchenko <forums_noreply@adobe.com>
Hello,
"in any case, UPDATE_PARAMS_UI will be sent on the first time the effect
SEQUENCE_RESETUP."
But i don't catch PF_Cmd_UPDATE_PARAMS_UI cmd after SEQUENCE_RESETUP.
I try call PF_UpdateParamUI in PF_Cmd_SEQUENCE_RESETUP cmd, but without result
help find a way to solve this problem
Thanks!
UPDATE_PARAMS_UI should indeed be called after SEQUENCE_RESETUP, but in the
sense of "never before", not in the sense of "always follows".
UPDATE_PARAMS_UI is called when AE thinks an update may be needed, as in
the case of a project being loaded from disk.
sometimes SEQUENCE_RESETUP is called for benign reasons, such as render
thread syncing with ui thread, or even if the effect was copied regardless
of being pasted). in such cases AE might not call UPDATE_PARAMS_UI after
SEQUENCE_RESETUP.
On Tue, Mar 26, 2019 at 8:26 PM yuriy_levchenko <forums_noreply@adobe.com>
Is there a way to ask force for it?
suites.AdvAppSuite2()->PF_RefreshAllWindows()
it's pretty violent, but if you don't call it every other second you should
be ok.
On Tue, Mar 26, 2019 at 9:54 PM yuriy_levchenko <forums_noreply@adobe.com>
I call suites.AdvAppSuite2()->PF_RefreshAllWindows()
but, nothing happened.
Cmd PF_Cmd_UPDATE_PARAMS_UI don't call
do you get that call at all? did you set PF_OutFlag_SEND_UPDATE_PARAMS_UI
in global setup?
On Wed, Mar 27, 2019 at 8:09 PM yuriy_levchenko <forums_noreply@adobe.com>
Yes, I setup PF_OutFlag_SEND_UPDATE_PARAMS_UI
out_data->out_flags = PF_OutFlag_PIX_INDEPENDENT |
PF_OutFlag_SEQUENCE_DATA_NEEDS_FLATTENING |
PF_OutFlag_SEND_UPDATE_PARAMS_UI |
PF_OutFlag_USE_OUTPUT_EXTENT |
PF_OutFlag_DEEP_COLOR_AWARE |
PF_OutFlag_WIDE_TIME_INPUT;
and I call in SequenceResetup
suites.AdvAppSuite2()->PF_RefreshAllWindows();
but cmd PF_Cmd_UPDATE_PARAMS_UI don't call, Only if I click on a layer, I catch this cmd in EntryPointFunc
is the effect fully visible in the ECW and you still don't get an
UPDATE_PARAMS_UI call?
On Wed, Mar 27, 2019 at 8:52 PM yuriy_levchenko <forums_noreply@adobe.com>
This I see after load project
And, this I see after click on layer
I also tried, AEGP_SetStreamValue in SequenceResetup, but I get AE error
"After Effects warning: A plugin is attempting to do an invalid operation: using wrong thread to access project
( 1 :: 0 )"
as for using SetStreamValue during sequence resetup, that's indeed an
invalid operation.
the sequence resetup can happen before AE associates the effect with a
layer, so param streams are not yet available for access.
On Wed, Mar 27, 2019 at 8:55 PM yuriy_levchenko <forums_noreply@adobe.com>
This is not true according to SDK Manual it is the other way around..
I am confused too - this is by far the most complicated SDK ever written. (For something as simple as rendering a few pixels)
I quote
Only cosmetic changes may be made in response to this command. Don’t change parameter values while responding to PF_Cmd_UPDATE_PARAMS_UI; do so during PF_Cmd_USER_CHANGED_PARAM instead.
actually that quote says exactly what i have said.
the changing of param names is a "cosmetic" operation, and therefore
belongs in PF_Cmd_UPDATE_PARAMS_UI.
changing param VALUE is not "cosmetic" and therefore doesn't belong
in PF_Cmd_UPDATE_PARAMS_UI, but instead should be done during
PF_Cmd_USER_CHANGED_PARAM.
suggesting it should be done in UPDATE_PARAMS_UI which according to SDK Manual is not legal
that is exactly what i suggested.
where does it say that param names can't be changed during UPDATE_PARAMS_UI?
(hey, i might be wrong, but to the best of my knowledge this is the way
it's supposed to be done)
