I use this Javascript to save Illustrator files to PDF. How can I tweak it to work with InDesign? "var dest" is a variable supplied by Keyboard Maestro, a macro builder for Mac.
// save as
var dest = "%Variable%DND_SaveLocal%/%Variable%proofName%";
saveFileToPDF(dest);
function saveFileToPDF (dest) {
var doc = app.activeDocument;
if ( app.documents.length > 0 ) {
var saveName = new File ( dest );
saveOpts = new PDFSaveOptions();
saveOpts.pDFPreset = "[Illustrator Default]";
//~ alert(saveName);
doc.saveAs( saveName, saveOpts );
Thank you for your help.
Lets take var dest as the path of the pdf that you wanna export, so the following code should work for you
...var dest = "Path to you pdf that is to be exported"
var pdfPreset = app.pdfExportPresets.itemByName("[Illustrator Default]")
if(!pdfPreset.isValid)
alert("Preset not found")
exit(
exit()
app.activeDocument.exportFile(ExportFormat.PDF_TYPE, saveName, false, pdfPreset)
-Manan
Thank you! I'll give it a try.
