I have a set of photos, a table of LrPhotos, scattered around the catalog. What's the best way of programmatically showing them all in a grid view. I've messed with Catalog:setViewFilter() but if that's the way it's lack of documentation is defeating me. And thoughts?
There are two straightforward methods, setting a view filter and using a collection.
To figure out how to set a view filter, set a sample filter in the user interface. Then dump out the results of catalog:getCurrentViewFilter() to see how the filter is represented. I have several plugins that set view filters, and that's how I figured out how to do it. For this approach, you need some way of uniquely identifying the photos to be displayed. If that can't be done using existing metadata fields, then you'll have to set a custom metadata field to have a unique value (e.g. LrDate.currentTime()) and then set the view filter to have that custom field as a column, with the unique value selected. (See my Any Filter plugin for an example of this.)
To create a collection, use catalog:createCollection() and collection:addPhotos(). Use catalog:setActiveSources() to change the current source to that collection and cause it to be displayed to the user.
The methods have their pros and cons. View filters let the user "intersect" the filter with different sources (folders and collections), but I know from long experience with my Any Filter plugin that many users don't really understand view filters and get confused when they see the Library Filter bar in action.
While users generally understand collections, it's not easy for most users to "intersect" a collection with another collection or folder (if that's important here). Also, LR has long had a performance bug, where the time for a plugin to create or delete a collection is proportional to the square of the number of photos it contains -- this only becomes noticeable when you have very large collections with thousands of photos. With the view-filter method, the time to display N photos is strictly proportional to N, whereas it's N^2 for collections.
Here's a previous post explaining the bad n-squared behavior for deleting photos from a collection:
