Expand my Community achievements bar.
SOLVED
Server Calls Metrics
Avatar
Level 8
Hi all,
We are trying to create a calculated metric for "Server Calls" as we have started to see a rapid growth in server calls but cannot place what is causing it.
Is there any logic that that anybody knows of that to make this in workspace?
Dave
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
Sum of Server Calls = Page Views + Exit Links Instances + Download Links Instances + Custom Links Instances.
see here: What constitutes a server call?
add all metrics to a table and invedtigate it by dimensions as needed (must be done for each report suite on its own)
View solution in original post
Avatar
Community Advisor
The server call is a report onto its own.
What I would first do to try and find growth cause is I would  start with looking at a key metrics report...
Look at base KPIs PVs, UVs, Visits to identify trend and see when spike started.
Once you have timeline then look at a pages report to see if that gives you any indication to a specific page or page(s)
Once you identify key pages, look at them to see if things like double beacon firing is a culprit...
Avatar
Correct answer by
Community Advisor
Avatar
Level 1
For server calls usage investigation/visualization in Workspace, you can create calculated metric as:
ROW SUM metrics (Page Views + Exit Links Instances + Download Links Instances + Custom Links Instances)
or just easily use Occurrences metric.
