Expand my Community achievements bar.
SOLVED
AEM 6.4.2 sidegrade upgrade
Avatar
Level 3
Hi all,
I am performing a upgrade from 6.2 to 6.4.2 through sidegrade.
process,
1. install venilla 6.4
2. install 6.4.2 SP2
3. repo migration from 6.2 to 6.4.2 through oak-upgrade.
I would like to know if there are any issues that might arise using oak-upgrade, as far as I used in lower environment,I didnt find any issues.
to use crx2oak the official migration tool, what should be the version I use  in CRX2OAK Migration Tool  ?
the latest is  1.8.6 and the document says use oak 1.8.4, however 6.4.2 repository is with oak 1.8.7.
is that ok If I use 1.8.6 jar  for 6.4.2 migration from 6.2 which uses repo 1.8.7?
Rajesh.
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
The version of the oak-upgrade/crx2oak tool does not have to correspond to the oak version used. Using the latest 1.8.x version of crx2oak should be ok.
View solution in original post
Avatar
Correct answer by
Employee Advisor
Avatar
Level 3
Hi Jorg,
thanks for your reponse.
any difference you see using oak-upgrade from crx2oak ?
anything I need to do additionally for using oak-upgrade instead of crx2oak ?
Thank you,
regards,
Rajesh
Avatar
Employee Advisor
Just follow the documented procedure, it should give you a clear indication which one to use.
Jörg
