So I've been working on a project for work as of late and have noticed these grey boxes appearing on my renderings. They seem to be in almost a grid like pattern, but they only show up in 2019. I take the same obj file and render it out in a similar scene in 2018 and these boxes are nowhere to be found. I've attached an image showing the boxes as they are circled with a red circle, and one image just as it was without circles. Until this is fixed I will just use 2018 for rendering.
I'm using a freshly updated Photoshop CC 2019 20.0.1
System is as follows
Mac Pro: (Late 2013)
Processor: 3.7 GHz Quad-Core Xeon E5
Memory: 16 GB 1866 MGz DDR3
Graphics: AMD FirePro D300 2048 MB
Hi
I've not noticed anything like that here, I have reported an issue with 3D volume but nothing on surface texture renders.
If you want to share an example file where you get the issue, I'd be happy to try it here and see if I get the same (I have both CC2018 and CC2019 installed)
Dave
Hi Dave,
I'm getting this problem with all of my OBJs, but this one is the one I'm referencing.
http://https://drive.google.com/file/d/1A3ij9xLHwe6xMl2ltD5FTU4ziAkfrmTK/view?usp=sharing
Hi
Sorry for the delay. I opened your file in CC2019 v20.0.1 and without touching any setting just hit render. The result is in the screenshot below. I can't see any of those artifacts.
So it looks like the issue is not in your file or in CC2019 generally but something on your system with CC2019
Changing the camera view and repeating also gave no sign of those dots.
This was on an i7 3930k with 64GB RAM and Nvidia GTX1080 8GB GPU. My 3D preferences are shown below:
Dave
looks like his system gpu is running out of ram... they are low specs and if he is also trying to run something in the background?
I have the same issue. When I 3d render, the top right corner of the render box creates these squares. You can see one below the A and then two on the X. If anyone can help, I'm pretty new to photoshop and using a late 2014 macbook pro.
That looks like a GPU issue. What version of Photoshop are you using?
Please go to Help >System info and press copy. Then paste the info here.
Dave
Adobe Photoshop Version: 20.0.4 20190227.r.76 2019/02/27: 1205725 x64
Number of Launches: 1
Operating System: Mac OS 10.14.5
System architecture: Intel CPU Family:6, Model:5, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2400 MHz
Built-in memory: 8192 MB
Free memory: 3710 MB
Memory available to Photoshop: 6654 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Touch Bar Property Feedback: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Main Display
High DPI Monitor
Display Bounds: top=0, left=0, bottom=800, right=1280
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=1
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=1536
glgpu[0].GLName="Intel Iris OpenGL Engine"
glgpu[0].GLVendor="Intel Inc."
glgpu[0].GLVendorID=32902
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel Iris OpenGL Engine"
glgpu[0].GLRendererID=16925953
glgpu[0].HasGLNPOTSupport=1
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[60]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 (Apr 7 2019 18:38:19)"
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1536
clgpu[0].CLName="Iris"
clgpu[0].CLVendor="Intel"
clgpu[0].CLVendorID=16925952
clgpu[0].CLDriverVersion="1.2(May 3 2019 17:47:17)"
clgpu[0].CLBandwidth=1.60232e+10
clgpu[0].CLCompute=234.47
nativegpu[0].NativeName="Intel Iris Graphics"
License Type: Subscription
Serial number: 96040509025149747597
GUIDBucket:Composite Core (enable_composite_core): onComposite Core UI (comp_core_ui): offDocument Graph (enable_doc_graph): off
Application folder: /Applications/Adobe Photoshop CC 2019/
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 233.6G, 19.2G free
Required Plug-ins folder: /Applications/Adobe Photoshop CC 2019/Adobe Photoshop CC 2019.app/Contents/Required/Plug-Ins/
Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2019/Plug-Ins/
Installed components:
dvametadata.framework dvametadata 12.1.0.0
AdobeXMPScript.framework AdobeXMPScript 79.163499 79.163499
ICUUnicode.framework ICUUnicode 3.61 "gtlib_11.0" "." "22995"
ICUConverter.framework ICUConverter 3.61 "gtlib_11.0" "." "22995"
AdobeCrashReporter.framework AdobeCrashReporter 7.7.2
boost_system.framework boost_system 12.1.0.0
AdobeACE.framework AdobeACE 2.20.02.42314 79.603421
AdobeOwl.framework AdobeOwl 5.3.0
mediacoreif.framework mediacoreif 12.1.0.0
dvascripting.framework dvascripting 12.1.0.0
dvaappsupport.framework dvaappsupport 12.1.0.0
dvaunittesting.framework dvaunittesting 12.1.0.0
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.8.0.41336 79.598424
k2.framework k2 1
AIDE.framework AIDE 1.5.0.41688 79.600470
dynamiclink.framework dynamiclink 12.1.0.0
dvaaccelerate.framework dvaaccelerate 12.1.0.0
dvametadataUI.framework dvametadataUI 12.1.0.0
AdobeExtendScript.framework AdobeExtendScript 4.5.9.1 81.1157194
boost_filesystem.framework boost_filesystem 12.1.0.0
AdobeBIB.framework AdobeBIB 1.2.03.41706 79.600623
AdobeXMPFiles.framework AdobeXMPFiles 79.163499 79.163499
AdobeLinguistic.framework 23636
dvaplayer.framework dvaplayer 12.1.0.0
PlugPlugOwl.framework PlugPlugOwl 9.2.1.39
AdobeAGM.framework AdobeAGM 4.30.87.41706 79.600623
adobe_caps.framework adobe_caps 11.0.0.14 1.584361
AdobeSVGRE.framework AdobeSVGRE 6.0 79.600623
AdobePDFL.framework AdobePDFL 15.0.0.41785 79.301181
dvacore.framework dvacore 12.1.0.0
AdobePIP.framework AdobePIP 8.0.0.52.48027
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.8.0.41336 79.598424
dvatransport.framework dvatransport 12.1.0.0
Cg.framework NVIDIA Cg
AdobeXMP.framework AdobeXMPCore 79.163499 79.163499
AdobeJP2K.framework AdobeJP2K 1.2.2.41336 79.271024
dvaaudiodevice.framework dvaaudiodevice 12.1.0.0
LogSession.framework LogSession 8.0.0.52.48027
PlugPlugExternalObject.framework 9.2.1.39
AdobeScCore.framework AdobeScCore 4.5.9.1 81.1157194
AdobeSVGAGM.framework AdobeSVGAGM 1.0.41706 79.600623
dvametadataapi.framework dvametadataapi 12.1.0.0
CITThreading.framework
WRServices.framework
AdobeBIBUtils.framework AdobeBIBUtils 1.1.41706 79.600623
boost_threads.framework boost_threads 12.1.0.0
aif.framework aif 6.0.00.1 1.
AdobeCoolType.framework AdobeCoolType 5.17.00.41706 79.600623
dvamediatypes.framework dvamediatypes 12.1.0.0
AdbePM.framework AdbePM 3.0.00.377262 1.601805
boost_date_time.framework boost_date_time 12.1.0.0
opencv2.framework opencv2 3.2.0
AdobeMPS.framework AdobeMPS 5.8.1.41653 79.600183
dvaui.framework dvaui 12.1.0.0
ahclient.framework ahclient 4.0.0.0
ICUData.framework ICUData 3.61 "gtlib_11.0" "." "22995"
dvamarshal.framework dvamarshal 12.1.0.0
Required plug-ins:
3D Studio 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Accented Edges 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 20.0.4, © 2014-2018 Adobe. All rights reserved. - from the file “Adaptive Wide Angle.plugin”
Angled Strokes 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Average 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “Average.plugin”
Bas Relief 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
BMP 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Camera Raw 11.3.1 (198), Copyright © 2019 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Camera Raw Filter 11.3.1 (198), Copyright © 2019 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Chrome 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Cineon 20.0 © 2002-2018 Adobe. All rights reserved. - from the file “Cineon.plugin”
Clouds 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
Collada DAE 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Color Halftone 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Colored Pencil 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Conté Crayon 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Craquelure 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 20.0 © 2003-2018 Adobe. All rights reserved. - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Crosshatch 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Crystallize 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Cutout 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Dark Strokes 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
De-Interlace 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Dicom 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “dicom.plugin”
Difference Clouds 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “Clouds.plugin”
Diffuse Glow 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Displace 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Dry Brush 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Eazel Acquire 20.0 © 2007-2018 Adobe. All rights reserved. - from the file “EazelAcquire.plugin”
Entropy 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Export Color Lookup Tables 20.0 © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
Extrude 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
FastCore Routines 20.0 © 1990-2018 Adobe. All rights reserved. - from the file “FastCore.plugin”
Fibers 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Film Grain 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Filter Gallery 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Flash 3D 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Fresco 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Glass 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Glowing Edges 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Google Earth 4 KMZ 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Graphic Pen 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Halftone Pattern 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Halide Bottlenecks 20.0 © 2018 Adobe. All rights reserved. - from the file “HalideBottlenecks.plugin”
HDRMergeUI 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “HDRMergeUI.plugin”
HSB/HSL 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
IFF Format 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
IGES 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Ink Outlines 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
JPEG 2000 20.0 © 2001-2018 Adobe. All rights reserved. - from the file “JPEG2000.plugin”
Kurtosis 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Lens Blur 20.0.4, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Blur.plugin”
Lens Correction 20.0.4, © 2002-2018 Adobe. All rights reserved. - from the file “Lens Correct.plugin”
Lens Flare 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Liquify 20.0.4, © 2001-2018 Adobe. All rights reserved. - from the file “Liquify.plugin”
Matlab Operation 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
Maximum 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Mean 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Measurement Core 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “MeasurementCore.plugin”
Median 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Mezzotint 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Minimum 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
MMXCore Routines 20.0 © 1990-2018 Adobe. All rights reserved. - from the file “MMXCore.plugin”
Mosaic Tiles 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Multiprocessor Support 20.0 © 1990-2018 Adobe. All rights reserved. - from the file “MultiProcessor Support.plugin”
Neon Glow 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Note Paper 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
NTSC Colors 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “NTSC Colors.plugin”
Ocean Ripple 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
OpenEXR 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Paint Daubs 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Palette Knife 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Patchwork 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Paths to Illustrator 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
PCX 20.0 © 1989-2018 Adobe. All rights reserved. - from the file “PCX.plugin”
Photocopy 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Picture Package Filter 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “ChannelPort.plugin”
Pinch 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Pixar 20.0 © 1989-2018 Adobe. All rights reserved. - from the file “Pixar.plugin”
Plaster 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Plastic Wrap 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
PLY 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Pointillize 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Polar Coordinates 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Portable Bit Map 20.0 © 1989-2018 Adobe. All rights reserved. - from the file “PBM.plugin”
Poster Edges 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
PRC 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Radial Blur 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Radiance 20.0 © 2003-2018 Adobe. All rights reserved. - from the file “Radiance.plugin”
Range 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Render Color Lookup Grid 20.0 © 2012-2018 Adobe. All rights reserved. - from the file “Export3DLUT.plugin”
Reticulation 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Ripple 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Rough Pastels 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Save for Web 20.0.4, © 1999-2018 Adobe. All rights reserved. - from the file “Save for Web.plugin”
ScriptingSupport 20.0, © 2002-2018 Adobe. All rights reserved. - from the file “ScriptingSupport.plugin”
Shake Reduction 20.0.4, © 2014-2018 Adobe. All rights reserved. - from the file “Shake Reduction.plugin”
Shear 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Skewness 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Smart Blur 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Smudge Stick 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Solarize 20.0 © 1993-2018 Adobe. All rights reserved. - from the file “Solarize.plugin”
Spaces 20.0, © 2015-2018 Adobe. All rights reserved. - from the file “Spaces.plugin”
Spatter 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Spherize 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Sponge 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Sprayed Strokes 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Stained Glass 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Stamp 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Standard Deviation 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
STL 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Sumi-e 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Summation 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Targa 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Texturizer 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Tiles 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Torn Edges 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Twirl 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
U3D 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Underpainting 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Vanishing Point 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “VanishingPoint.plugin”
Variance 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “statistics.plugin”
Virtual Reality Modeling Language | VRML 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Water Paper 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Watercolor 20.0.4, © 1991-2018 Adobe. All rights reserved. - from the file “Filter Gallery.plugin”
Wave 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Wavefront|OBJ 20.0 © 2006-2018 Adobe. All rights reserved. - from the file “U3D.plugin”
Wind 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 20.0 © 1989-2018 Adobe. All rights reserved. - from the file “WBMP.plugin”
ZigZag 20.0.4, © 2003-2018 Adobe. All rights reserved. - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_2_108/purchaseStock.html”
com.adobe.Butler.backend 2.1.1 - from the file “/Applications/Adobe Photoshop CC 2019/Adobe Photoshop CC 2019.app/Contents/Required/CEP/extensions/com.adobe.Butler.backend/index.html”
Libraries 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_2_108/index.html”
com.adobe.stock.panel.licensing 0.1.0 - from the file “/Applications/Adobe Photoshop CC 2019/Adobe Photoshop CC 2019.app/Contents/Required/CEP/extensions/com.adobe.stock.panel.licensing/index.html”
New Document 2.5.1 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.fnft-2.5.1/fnft.html?v=2.5.1.8”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/CC_LIBRARIES_PANEL_EXTENSION_3_2_108/purchaseTypekit.html”
Home 2.7.0 - from the file “/Library/Application Support/Adobe/CEP/extensions/com.adobe.ccx.start-2.7.0/index.html?v=2.7.0.66”
Adobe Color Themes 6.1.0 - from the file “/Applications/Adobe Photoshop CC 2019/Adobe Photoshop CC 2019.app/Contents/Required/CEP/extensions/com.adobe.KulerPanel.html/index.html”
Export As 4.6.7 - from the file “/Applications/Adobe Photoshop CC 2019/Adobe Photoshop CC 2019.app/Contents/Required/CEP/extensions/com.adobe.photoshop.crema/index.html”
Installed TWAIN devices: NONE
Hi
According to your system data you are using an integrated graphics card (intel Iris) rather than a dedicated GPU so your system may struggle with 3D. The integrated system shares VRAM with teh main system.
I don't know if you can update GPU drivers on a MAC or whether they are built into teh OS. I use Windows so can't advise on that.
You could go to Preferences >Performance > and enable "Use Legacy Compositing" then restart Photoshop to see if that makes a difference.
Dave
Unfortunately Use Legacy Compositing is grayed out and i'm unable to check that box. Even after unchecking the other boxes. Thanks for the help so far!!! I will look more into updating my GPU on this mac.
you can't upgrade drivers in a Mac... it boils down to Adobe sniffer detecting the card which is very much a dice roll
I always thought that, but someone in another thread posted a couple of days ago that you could update drivers. Not having a Mac I can't test or argue either way.
Dave
Hi
I have the same problem when rendering and this is the only thread of help I can find. I'm not sure this is a lack of hardware power because I'm using an iMac Pro with 3 GHz Intel Xeon Processor, 64 GB of DDR4 Memory and the Radeon Pro Vega 64 with 16 GB of Video Memory.
Hector
I have the same problem. It has been happening over the past several PS versions. I tried changing settings in preferences, nothing works. When rendering I get the pattern of small square Boxes. I have been removing them as if they were dust spots but that is painful.
MacBook Pro 15 inch mid 2015, 16 GB AMD Radeon R9 2 GB
Mike
