• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Running H/F 10 is blank
Explorer ,
Dec 12, 2018 Dec 12, 2018
Hello.
I recently inherited a library of FM books and I am using FM 2017; it is the first time I am using FM on a regular, in-depth basis.
In one of the books, Table of Contents does not appear in the header on the table of contents pages, even though the Running H/F 10 variable appears in the header for the master pages used on these pages. When I manually define the Running H/F 10 variable as Table of Contents, that text appears fine in the header.
Before I changed it, the Running H/F 10 variable definition was:
<Default ¶ Font><$paratext[TOC_Title,AppendixHeadingRepeat,AppendixHeading 1,Heading 1]>
Which I believe is consistent with the other books.
As the Running H/F 10 variable is not used anywhere else, manually defining the variable with static text is an acceptable workaround with no negative consequences, as far as I can tell. Nonetheless, I am curious as to why this is happening and how to resolve it.
Any advice would be appreciated.
Views
286
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Dec 16, 2018 Dec 16, 2018
That is what I was asking. That Running H/F string was looking for a Title_TOC tag (tag and styles are synonyms) to pull into the footer. Until you had a Title_TOC tag in the file—or one of the other tags listed—it was going to remain blank. I can see why the white color would have thrown you off.
Glad you are back on track.
~Barb
Votes
Translate
Translate
Community Expert ,
Dec 13, 2018 Dec 13, 2018
Hi Jay:
What is the paragraph tag name for the Table of Contents title on page one of that file?
The footer is looking for TOC_Title and it must match exactly. Any variation on the spelling/spaciing/capitalization and it won't find a match.
~Barb
Votes
Translate
Translate
Report
Report
Explorer ,
Thank you for your answer, Barb.
I don't think I understand what you are asking.
In any case, what you wrote did spur me to continue poking around, and I believe I have resolved the issue.
I discovered:
  • TOC_Title is a paragraph style. I had not realized this. I had thought it might be a variable, but it did not appear in the list of variables.
  • In the table of contents of the other books, the TOC_Title paragraph style has been applied to a string of text (Table of Contents) that exists on the first table of contents body page, but whose color is white (which kind of shocked me).
So, I believe that making sure that the Table of Contents string is on the first table of contents of body page and that the TOC_Title paragraph style is applied to that string, resolves the issue.
Thanks, again.
Votes
Translate
Translate
Report
Report
Community Expert ,
~Barb
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks again, Barb. I appreciate it.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
We are always happy to help.
~Barb
Votes
Translate
Translate
Report
Report
