2 Replies Latest reply on Mar 31, 2008 9:06 AM by TessandraFae
    Need to capture what has focus in a variable
    TessandraFae Level 1
      Hi everyone,
      The documentation is failing me here, but I'm sure you all know how to do this.
      I have an application that has several text areas and shape symbols. I have controls for the user to either: edit text in those textareas (fontfamily, fontsize, color, etc) or modify the shape properties(colors, rotation, scale, etc)
      My problem is that the controls don't know which textarea or shape to apply these changes to. I need a way to capture the focused item in a variable and then have the control buttons use that variable as a reference to the object they're changing.
      For example I borrowed this flex snippet on how to use Text Range:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      layout="absolute" width="331" height="389"
      viewSourceURL=
      "/files/Tutorials/Flex/TextRange/TextRangeTutorial.mxml">
      <mx:Script>
      <![CDATA[
      import mx.controls.textClasses.TextRange;
      import mx.events.ColorPickerEvent;
      private var textSelection:TextRange;
      private function initTextArea():void
      textSelection = new TextRange(txtSlate, true); <--- i want to change this to new TextRange({focusedobject}, true);
      private function increaseFontSize():void
      textSelection.fontSize++;
      But how do I capture the focus into some variable?
      I appreciate your help everyone!
      Tessy
        • 1. Re: Need to capture what has focus in a variable
          Ok, as an update, here's how I've modified the code, but I'm getting errors when I click on the textarea box. Look at this:
          layout="absolute" creationComplete="initTextArea(txtSlate)"
          viewSourceURL=
          <mx:Script>
          <![CDATA[
          import mx.core.UIComponent;
          private function initTextArea(target:UIComponent):void
          textSelection = new TextRange(target, true);
          private function decreaseFontSize():void
          textSelection.fontSize--;
          private function
          changeFontColor(eventObj:ColorPickerEvent):void
          textSelection.color = eventObj.color;
          private function changeFontBold():void
          if(textSelection.fontWeight == "bold")
          textSelection.fontWeight = "normal";
          else
          textSelection.fontWeight = "bold";
          private function changeFontItalic():void
          if(textSelection.fontStyle == "italic")
          textSelection.fontStyle = "normal";
          else
          textSelection.fontStyle = "italic";
          </mx:Script>
          <mx:Panel x="0" y="0" width="559" height="389"
          layout="absolute" title="Simple TextRange Usage">
          <mx:TextArea id="txtSlate" x="10" y="10" text="This is a test0"
          width="282" height="82" focusIn="initTextArea(this)" />
          <mx:TextArea id="txtSlate0" x="10" y="100" text="This is a test1"
          width="282" height="82" focusIn="initTextArea(this)"/>
          <mx:TextArea id="txtSlate1" x="10" y="190" text="This is a test"
          <mx:Button x="10" y="287" label="Increase Font Size"
          width="135" click="increaseFontSize()"/>
          <mx:Button x="10" y="317" label="Decrease Font Size"
          click="decreaseFontSize()"/>
          <mx:ColorPicker x="270" y="287"
          change="changeFontColor(event)"/>
          <mx:Label x="156" y="289" text="Choose Font Color:"/>
          <mx:Button x="241" y="317" label="Bold"
          click="changeFontBold()"/>
          <mx:Button x="177" y="317" label="Italic"
          click="changeFontItalic()"/>
          </mx:Panel>
          </mx:Application>
          The errors I'm getting are:
          ReferenceError: Error #1069: Property http://www.adobe.com/2006/flex/mx/internal::getTextField not found on TextRangeTutorial and there is no default value.
          at mx.controls.textClasses::TextRange()
          at TextRangeTutorial/initTextArea()
          at TextRangeTutorial/__txtSlate0_focusIn()
          at flash.display::Stage/set focus()
          at mx.core::UITextField/setFocus()
          at mx.controls::TextArea/setFocus()
          at mx.managers::FocusManager/setFocus()
          at mx.managers::FocusManager/mouseDownHandler()
          What did I do wrong?
          Tess
          • 2. Re: Need to capture what has focus in a variable
            Aha! Here's how you focus on any textarea without knowing it's ID:
            private function initTextArea(event:Event):void
            textSelection = new TextRange((event.currentTarget)as UIComponent, true);
            private function addToolListener(event:Event):void
            (event.currentTarget).addEventListener(MouseEvent.CLICK, initTextArea);
            Then on the textareas, add the following:
            creationComplete= “addToolListener(event)”
            Hope this helps!
