• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
7
FullTrustNotifier.exe
Community Beginner ,
Dec 17, 2018 Dec 17, 2018
I keep getting the attached error every day, I have search for a resolution and can not find one.  I have uninstalled, reinstalled.  Did the full uninstall and reinstall, it even popup after that before I reinstalled.  Just want to fix/stop it.
Adobe Acrobat Pro DC
2019.010.20064
Any help would be great.
TOPICS
Install update and subscribe to Acrobat
Views
90.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Dec 20, 2018 Dec 20, 2018
Thank you for the quick response.
Based on the details shared by you, please follow the steps below:
Step 1:  Uninstall "Notification Manager for Adobe Acrobat"
     Click on start menu -> Search for above app -> Right click-> Uninstall.
Step 2:  Delete the following registry key
     HKEY_CURRENT_USER\Software\Adobe\Adobe Acrobat\DC\Installer\NotificationAppx
This should resolve the issue.
Regards,
Rohit
Votes
Translate
Translate
Adobe Employee ,
Hi doug.allison,
As per the issue description mentioned above, you are getting above mentioned error on your windows machine, is that correct?
Could you check if an update is available for Acrobat using "Check for updates" option under "Help" menu,  You may also download updates from here:  Adobe software and product updates
Reboot the machine after installing update and check.
Also, check if full trust notifier.exe exists under C/program files/windows apps/acrobat notification client,....
Shivam
Votes
Translate
Translate
Report
Report
There are no updates available.
yes the FullTrustNotifier.exe exists in that location.
Votes
Translate
Translate
Report
Report
I was contacted via https://forums.adobe.com/collaboration/XXXXXX?et=notification.direct.message (seem legit) and asked for my Skype or Hangout ID ( a bit shaky) .  I gave them the Hangout id, and then wanted want my Adobe Username and password, this seem very strange and out of the norm, is this the way Adobe operates?  I ended the conversation.
I still this original issue resolved.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
No, Adobe doesn't do that. Likely a scam.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 10, 2020 Jul 10, 2020
try to delete this key instead:
HKEY_CURRENT_USER\Software\Adobe\Acrobat Reader\DC\Installer\NotificationAppx
you can always go to edit then find and look for "Notificationappx"
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi doug.allison
Can you please share the following details to help us resolve this issue:
1. What is the OS version running on your machine. (See link to get exact version)
2. Open Command prompt (Cmd) and run the command mentioned below.
          powershell.exe Get-AppxPackage -Name *AcrobatNotificationClient*
    Look for "Version” entry in the command output and share the version number with us.
3. What is the frequency of this error message
4. Since when did the error start popping up
Regards,
Rohit
Votes
Translate
Translate
Report
Report
Dec 18, 2018 Dec 18, 2018
Editons Windows 10 Pro
Version 1803
OS Build 17134.471
Adobe Version  1.0.4.0
Its seems to happen every day just after boot up.  But today it did not.
Happen since I first install adobe.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Regards,
Rohit
Votes
Translate
Translate
Report
Report
Dec 21, 2018 Dec 21, 2018
so far so good
Votes
Translate
Translate
Report
Report
New Here ,
Mar 09, 2023 Mar 09, 2023
Hi. How did you complete step 2? I haven't figured out how to dele that registry key... I would appreciate both of your help, thank you.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Mar 13, 2023 Mar 13, 2023
Hi Cristian2854545258gd,
Thank you for reaching out.
Could you please confirm the Acrobat version you are using?
Share the OS version number as well.
Do you get the same error message as mentioned in this post?
Would you mind sharing more information on this?
Meenakshi
Votes
Translate
Translate
Report
Report
New Here ,
Jun 27, 2019 Jun 27, 2019
hello! i'm having a similar issue... can you help me? I recently uninstalled a trial version of the Adobe Acrobat Pro DC and since then this ~app~ "Notification Manager for Adobe Acrobat" simply doesn't go away from my star menu. I tried so many times to uninstall it but I can't, it remains every time. I looked for the key u guys talked about and I could not find it on my PC. it's really annoying... do you have some idea of what can I do about it?
thank u,
Votes
Translate
Translate
Report
Report
New Here ,
Jul 03, 2019 Jul 03, 2019
When I run powershell.exe Get-AppxPackage -Name *AcrobatNotificationClient*
I get no response.
Also, I don't have "Notification Manager for Adobe Acrobat" installed  and I don't have that registry key you mentioned.
But, I still get the message.  I'm running Windows Home v 1809 build 17763.557.
How do I stop the message?  Should I install "Notification Manager for Adobe Acrobat" and then delete it?
Votes
Translate
Translate
Report
Report
Feb 12, 2020 Feb 12, 2020
You need to run Get-AppxPackage -AllUsers -Name *AcrobatNotificationClient* as I'm guessing you are running PowerShell as a different user than the user who has installed the application.
Votes
Translate
Translate
Report
Report
Feb 13, 2020 Feb 13, 2020
I have a similar issue. I have Notification Manager for Adobe Creative Cloud installed alongside my Creative Cloud application. When I uninstall the Notification Manager, it goes away, but once I relaunch Creative Cloud app, it reappears.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 05, 2022 Jun 05, 2022
Apparently Adobe suggests modifying the registry to fix this annoying problem.  If this is the kind of expertise needed to fix an Adobe product, Adobe is  obviously not for the average user.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 23, 2023 Oct 23, 2023
I just want to say what I have done to get it fixed:
We had several users who had the same error and found that if nothing of these options helped, a re-installation of the PC is necessary (win 11)  and running all update for that too AND then we had to install Adobe first and then install MS 365 after.
That was our solution to fix it.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 11, 2023 Nov 11, 2023
LATEST
  1. Go to start/search menu;
  2. Search for "Notification Manager for Adobe Acrobat";
  3. Right click and uninstall "Notification Manager for Adobe Acrobat";
  4. Press the Windows key + R on your keyboard to open the Run dialog box;
  5. Type regedit in the Open field and click OK;
  6. In the Registry Editor window, navigate to the following location:
HKEY_CURRENT_USER\Software\Adobe\Adobe Acrobat\DC\Installer\NotificationAppx​
  • Right-click on the NotificationAppx key and select Delete;
  • Confirm the deletion by clicking Yes.
Please take note that changing the Registry Editor window can be risky, and should be done with caution when working on it.
If you don't have any type of help or guidance, or you don't know what you are doing, it is recommended doing a backup and ask for help on your subject.
If you do ask for help on someone you don't know, please be aware of scammers and false negleted people.
If you find anything that they are requesting is weird, just cancel the process with that person, and try a different method with someone/something else.
If the steps above still didn't fix your issue, you can try the following:
  2. Search for "Add or remove programs";
  3. Seach for "Adobe Acrobat" on the search bar;
  4. Click on Modify;
  5. Click Next on the first page;
  6. Select Repair on the second page and click Next;
  7. Click Update on the third and final page, and let it update.
If all of this was done, you most likely won't encounter this issue anymore.
The best,
notNelo
quote
2019.010.20064
By @Doug_Allison
Votes
Translate
Translate
Report
Report
