Hello,
I have a MacBook Pro (MacOS mojave version 10.14.2). I also have Adobe Acrobat Pro XI (Version 11.0.23). When I open adobe and try to go to the "help" tab, "check for updates," I get the error message: "Cannot connect to adobe update server." I am connected to the internet and have no issues updating other programs. I tried to google this and look on the adobe forums, and could not find an applicable solution to adobe acrobat pro XI. Any assistance would be appreciated! Thank you in advance. (I am trying to update because my mac keeps giving me pop-ups that soon my current version of adobe will not work with my version of OS.)
The pop ups should say it won’t work with the NEXT Mac OS. 11.0.23 is the final update to Acrobat XI, which is out of support and will never be updated to work with the next Mac OS. Acrobat Pro DC (subscription) and Acrobat Pro 2017 (perpetual license, not recommended) are available.
Hello. After I upgraded to Mojave 10.14.2, my Acrobat Pro XI stopped working. Nothing happens when I tried opening a pdf. So I uninstalled and reinstalled with the latest XI download. It failed to install. Now I have no Acrobat to use. I have no need to upgrade to DC. Is this failure to install a know issue with Mojave 10.14.2?
If an existing install is made unusable by a Mac operating system upgrade work through the below steps
-https://www.businessinsider.com/apple-macos-mojave-apps-compability-fix-2018-10
-https://www.macworld.co.uk/how-to/mac-software/open-apps-wont-work-mojave-photoshop-3684425/
-https://helpx.adobe.com/x-productkb/global/install-or-run-applications-new.html
Hi. So now I have uninstalled everything (all things adobe), then tried installing pro DC trial, FAILED during install. Made several more failed attempts. Then uninstalled everything again and tried installing 2017, FAILED everytime again. Then tried reinstalling XI pro and it also failed every time. I have used Time Machine to restore the original XI pro and I am back where I started. The app is there, click on it, nothing. Dbl-click on a pdf file, nothing happens. Preview with spacebar or Preview app and I can read the file fine. This is driving me bonkers. I sent the crash log file to Apple, and they got nothing. Anyone here recognize the problem from the following crash log?
Process: AdobeAcrobat [77782]
Path: /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
Identifier: com.adobe.Acrobat.Pro
Version: 11.0.23 (11.0.23)
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: AdobeAcrobat [77782]
User ID: 501
Date/Time: 2019-02-03 11:51:54.012 +0100
OS Version: Mac OS X 10.14.2 (18C54)
Report Version: 12
Anonymous UUID: 7FDB107E-57F7-03AD-D271-FABD07B8B093
Sleep/Wake UUID: 71DB9D54-B0D6-4EFE-A72A-0AE213C82CAD
Time Awake Since Boot: 330000 seconds
Time Since Wake: 65000 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x4] Symbol missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Symbol not found: _kFigAssetTrackProperty_QuickTimeMetadata
Referenced from: /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
Expected in: /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
in /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
Binary Images:
0xeb000 - 0xebfff +com.adobe.Acrobat.Pro (11.0.23 - 11.0.23) <604B4046-8AEE-312A-B70C-0CB5E9AB36BA> /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
0xf1000 - 0xf2ffb libSystem.B.dylib (1252.200.5) <BD0BACAA-668D-3945-8C95-A458B71AAC22> /usr/lib/libSystem.B.dylib
0xf8000 - 0x107fff libz.1.dylib (70.200.4) <94051A6F-41F7-3F3D-A62F-C6B266F40DA5> /usr/lib/libz.1.dylib
0x10d000 - 0x12bff3 +com.adobe.BIB (AdobeBIB 1.2.08.1 - 1.2.08.1) <AE752C0B-DE38-3A48-971F-A501361FB8C1> /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x130000 - 0x130fff com.apple.ApplicationServices (50.1 - 50.1) <1759BDFA-5B4C-3B69-927B-138075ABFFE8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x139000 - 0x139fff com.apple.Carbon (158 - 158) <61DBE459-229D-3A02-9689-CF145F351E34> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x13d000 - 0x13dfff com.apple.CoreServices (941 - 941) <88971927-736F-3411-9FB1-AF4D6FB50C22> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x147000 - 0x15effb com.apple.ScriptingBridge (1.4 - 77) <A0899AB8-B778-33C2-835A-F16B1143F060> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
0x170000 - 0x170fff com.apple.quartzframework (1.5 - 23) <ED3392FD-0776-307C-B23E-1F014B7AFB2F> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x174000 - 0x178fff libcache.dylib (81) <66174C6B-8382-3A8A-AF5E-ADE30570E629> /usr/lib/system/libcache.dylib
0x17e000 - 0x1c2c8f dyld (640.2) <B477B0C6-A565-3320-A1E6-3309D8A525DE> /usr/lib/dyld
0x203000 - 0x2384ff7 +com.adobe.Acrobat.framework (11.0.23 - 11.0.23) <105B8A58-3B91-328C-950B-363A491A44B9> /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
0x252b000 - 0x32cbff7 com.apple.AppKit (6.9 - 1671.20.108) <0D48C3E7-BE20-3A1C-9704-C4130971E13D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x3a0f000 - 0x3a5fff3 libstdc++.6.dylib (104.1) <A105B058-97F1-3C1D-9231-C681D3DB0665> /usr/lib/libstdc++.6.dylib
0x3ac1000 - 0x4236ffb libobjc.A.dylib (750.1) <99CFC28C-4B7B-3DAB-BC3F-C2A4657A5472> /usr/lib/libobjc.A.dylib
0x4324000 - 0x46a4ffb com.apple.Foundation (6.9 - 1561) <FF255A47-6196-3851-B66F-683C08521450> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x48b1000 - 0x4a03fe7 +com.adobe.ACE (AdobeACE 2.20.06.1 - 2.20.06.1) <F057F900-96E3-3C6A-8AFD-7A24C44B3C91> /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x4a0f000 - 0x4fe6ffb +com.adobe.AGM (AdobeAGM 4.28.152.1 - 4.28.152.1) <3851CC30-E732-3305-BC9D-64AC4D2A8C35> /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x5050000 - 0x534effb +com.adobe.CoolType (AdobeCoolType 5.11.152.1 - 5.11.152.1) <48AEE4F9-ED8F-3490-8DA6-E4D1C87B01E7> /Applications/Adobe Acrobat XI Pro/Adobe Acrobat Pro.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x537f000 - 0x57c0fff com.apple.CoreFoundation (6.9 - 1561) <47517C64-CE45-3CEF-ABAC-6F2AD86CBE44> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x59b3000 - 0x5a4cff7 com.apple.framework.IOKit (2.0.2 - 1483.230.1) <73C792DB-768E-386B-95F6-C7B42C9EABD0> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x5a8d000 - 0x5cd5ffb com.apple.QuartzCore (1.11 - 695.4) <832BE9CE-C8B2-3745-BEFD-68D3AEC96CB7> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x5dab000 - 0x5e02ff3 com.apple.QuickLookFramework (5.0 - 775.3) <4FA22DD6-2BEF-3FBA-B22B-F9ED95CDCBD9> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x5e39000 - 0x614dfff com.apple.security (7.0 - 58286.230.21) <1C9C573D-2C15-3FD9-93F5-95830FCC7E0B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x62aa000 - 0x66adff7 com.apple.WebKit (14606 - 14606.3.4) <9E57C63B-EC12-3E56-931A-7A59CBA02A79> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x6ac1000 - 0x6b31fff com.apple.SystemConfiguration (1.17 - 1.17) <16DE8E76-30AA-3ABE-A108-E601EF995A32> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x6b63000 - 0x6b6dfff libcommonCrypto.dylib (60118.220.1) <298ECBFF-7B34-34DC-9033-E6E508F58CAF> /usr/lib/system/libcommonCrypto.dylib
0x6b7a000 - 0x6b81fff libcompiler_rt.dylib (63.4) <54311736-0192-3B3A-99D5-5BCD44ED1FDB> /usr/lib/system/libcompiler_rt.dylib
0x6b8e000 - 0x6b98fff libcopyfile.dylib (146.200.3) <AE89A344-0558-3267-B577-8AD895CA5CCF> /usr/lib/system/libcopyfile.dylib
0x6b9f000 - 0x6c06ffb libcorecrypto.dylib (602.230.1) <AD22F970-BBF3-38CC-954E-CE61D4A8D282> /usr/lib/system/libcorecrypto.dylib
0x6c20000 - 0x6c57ff3 libdispatch.dylib (1008.220.2) <F00631B4-567A-3D36-B9F6-79F3BD92FCAC> /usr/lib/system/libdispatch.dylib
0x6c84000 - 0x6cb3fff libdyld.dylib (640.2) <BC3839EF-40F2-3643-B229-2866673DB386> /usr/lib/system/libdyld.dylib
0x6cd2000 - 0x6cd2ffb libkeymgr.dylib (30) <E8D09E0A-3292-3AA9-8C3A-2D552C3CD44C> /usr/lib/system/libkeymgr.dylib
0x6cd7000 - 0x6cd7fff liblaunch.dylib (1336.220.5) <D7973275-02E8-3BD7-A7E2-501560B71C55> /usr/lib/system/liblaunch.dylib
0x6cde000 - 0x6ce3ff3 libmacho.dylib (921) <01DEAF85-E76F-35A6-9DCC-46FD6F4A1795> /usr/lib/system/libmacho.dylib
0x6cea000 - 0x6cecffb libquarantine.dylib (86.220.1) <FB5702D3-7AE0-3C53-B189-2DAA11B5D335> /usr/lib/system/libquarantine.dylib
0x6cf3000 - 0x6cf4ffb libremovefile.dylib (45.200.2) <51B12FA2-B4C2-3035-91D1-C8FF88305D4C> /usr/lib/system/libremovefile.dylib
0x6cfa000 - 0x6d11fff libsystem_asl.dylib (356.200.4) <BB0AB340-DD83-378E-BDE9-67F3BFBD1C14> /usr/lib/system/libsystem_asl.dylib
0x6d1d000 - 0x6d1dfff libsystem_blocks.dylib (73) <2A8CA766-7312-36E8-A043-7EC450750EEC> /usr/lib/system/libsystem_blocks.dylib
0x6d22000 - 0x6daeff3 libsystem_c.dylib (1272.200.26) <E7F4006B-C8BB-326E-BE06-A6D9F3E700DA> /usr/lib/system/libsystem_c.dylib
0x6dd5000 - 0x6dd8fff libsystem_configuration.dylib (963.200.27) <2F5D0B67-6855-39C7-909A-DFBC6AA40CCF> /usr/lib/system/libsystem_configuration.dylib
0x6ddf000 - 0x6de2fff libsystem_coreservices.dylib (66) <ED3F8BA3-C29A-30A9-956E-C6DD49A76407> /usr/lib/system/libsystem_coreservices.dylib
0x6de8000 - 0x6dedfff libsystem_darwin.dylib (1272.200.26) <D420D959-5C14-3F04-875A-1B25C55FDB17> /usr/lib/system/libsystem_darwin.dylib
0x6df7000 - 0x6dfdffb libsystem_dnssd.dylib (878.230.2) <9E86115A-610E-3FD1-A449-2298E4DB1E56> /usr/lib/system/libsystem_dnssd.dylib
0x6e03000 - 0x6e55ff7 libsystem_info.dylib (517.200.9) <DED74DB8-DFFB-3AC2-A9DB-0874F6DCEDA1> /usr/lib/system/libsystem_info.dylib
0x6e6a000 - 0x6eb8fdb libsystem_m.dylib (3158.200.7) <2A68A353-D3D6-3EDB-88C2-874BBA99B2E6> /usr/lib/system/libsystem_m.dylib
0x6ec7000 - 0x6ee3fff libsystem_malloc.dylib (166.220.1) <77B017D1-BCA4-3626-81E7-D783BCA5CBB7> /usr/lib/system/libsystem_malloc.dylib
0x6ef0000 - 0x6efbfff libsystem_networkextension.dylib (767.220.1) <ECD6A7B6-BD78-3E4C-9357-8E83F1551154> /usr/lib/system/libsystem_networkextension.dylib
0x6f07000 - 0x6f0dfff libsystem_notify.dylib (172.200.21) <D298DA4C-D152-3B0F-A853-7713CCFF570B> /usr/lib/system/libsystem_notify.dylib
0x6f13000 - 0x6f16ff7 libsystem_sandbox.dylib (851.230.3) <9EEF9F0F-701A-358D-9808-C071B075E8B6> /usr/lib/system/libsystem_sandbox.dylib
0x6f1d000 - 0x6f1ffff libsystem_secinit.dylib (30.220.1) <134F8AAF-3A69-31B5-8C77-9545BA80B7E0> /usr/lib/system/libsystem_secinit.dylib
0x6f25000 - 0x6f4dfff libsystem_kernel.dylib (4903.231.4) <E31D7BAD-27B9-3FF2-82A4-735FCFFB0E3A> /usr/lib/system/libsystem_kernel.dylib
0x6f67000 - 0x6f6effb libsystem_platform.dylib (177.200.16) <A71BC776-D4BA-3DFC-B63E-B4CF1E7EE96E> /usr/lib/system/libsystem_platform.dylib
0x6f77000 - 0x6f82ff3 libsystem_pthread.dylib (330.230.1) <4489415B-567F-3200-AF64-1FEF70533EB2> /usr/lib/system/libsystem_pthread.dylib
0x6f8c000 - 0x6f93fff libsystem_symptoms.dylib (820.237.2) <C492F02A-CC46-38F5-9673-FB4A3ACB3E76> /usr/lib/system/libsystem_symptoms.dylib
0x6f9a000 - 0x6faeffb libsystem_trace.dylib (906.220.1) <3C04AA0C-A2CA-38B9-9E81-F655F4317A55> /usr/lib/system/libsystem_trace.dylib
0x6fbd000 - 0x6fc3fff libunwind.dylib (35.4) <D5256A06-AEE7-35D3-A8D0-7193ED20E28A> /usr/lib/system/libunwind.dylib
0x6fcb000 - 0x6ffaffb libxpc.dylib (1336.220.5) <C45A6C19-501D-3500-BA74-794A34A788DD> /usr/lib/system/libxpc.dylib
0x7019000 - 0x702cffb libc++abi.dylib (400.17) <815652B1-4109-39FB-8E11-70586DA45932> /usr/lib/libc++abi.dylib
0x7040000 - 0x7099ff7 libc++.1.dylib (400.9.4) <AF96128B-4D35-3C0D-A211-634C27C7236C> /usr/lib/libc++.1.dylib
0x70f3000 - 0x70f3fff com.apple.Accelerate (1.11 - Accelerate 1.11) <511606EC-E003-3978-BB40-5F8F2D16C03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x70f7000 - 0x79eefd3 com.apple.vImage (8.1 - ???) <3A251C85-E640-3F67-9116-0EA526DCBDE2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7a60000 - 0x7a60fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <AA77F885-90D8-3637-AE3E-A0EEA31D45E9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7a64000 - 0x7a79feb libcompression.dylib (52.200.13) <6E9C086D-4630-32E5-80D7-94CDFC164B43> /usr/lib/libcompression.dylib
0x7a80000 - 0x7a98fff liblzma.5.dylib (10.200.3) <4FCFCF8F-DC9A-3BA9-9D35-2CF0E8FA02D9> /usr/lib/liblzma.5.dylib
0x7aa0000 - 0x7c65fe7 libvMisc.dylib (671.220.1) <3C4E100A-10AB-30B4-8BAD-EE84075479AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7c75000 - 0x7e09fcb libvDSP.dylib (671.220.1) <D32BD1F3-F9DD-3174-A11E-6A02FD60556B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7e19000 - 0x7f36fdb libBLAS.dylib (1243.200.4) <3436C097-00A2-3C6B-8FA2-9D32BA51734C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7f55000 - 0x82aaffb libLAPACK.dylib (1243.200.4) <E3D98EA1-8702-378B-97ED-5F20E524A4E5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x82fe000 - 0x8313ffb libLinearAlgebra.dylib (1243.200.4) <E7EE2A8C-67BE-37C3-A89B-8BCF64DE4E49> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x831d000 - 0x8336fff libSparseBLAS.dylib (1243.200.4) <D715A5FB-4252-3387-825D-FED40FA503DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x833e000 - 0x8378ffb libBNNS.dylib (38.200.5) <335951AF-5DD2-3A5A-AE33-CB44BD90340B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x8380000 - 0x8a37fff com.apple.CoreGraphics (2.0 - 1249.2) <D027EBA8-124C-3AFC-ADA5-758CC16CE166> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x8b59000 - 0x8cb4ffb com.apple.CoreText (352.0 - 584.26) <9F056434-6BAE-3D46-878A-B287A4AA384A> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x8d64000 - 0x8efcffb com.apple.ImageIO.framework (3.3.0 - 1822.1) <9D81FB31-F496-3995-912B-965177D6A36A> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x8fa5000 - 0x9078ff3 com.apple.ColorSync (4.13.0 - 3340) <29F6C080-6B7C-34D5-9B85-E8C5E6AB5504> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x90bc000 - 0x9127ff3 com.apple.ApplicationServices.ATS (377 - 453.11) <CA71DACB-55CD-395C-B39E-C27D013A8993> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9151000 - 0x9156fff com.apple.ColorSyncLegacy (4.13.0 - 1) <5893C007-C9C6-3EAA-98FC-AEA3ECBADF89> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
0x9160000 - 0x91b8fff com.apple.HIServices (1.22 - 627.14.2) <2B7533FE-92E0-3D83-8BBD-761AC6880136> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x91ef000 - 0x91fdfff com.apple.LangAnalysis (1.7.0 - 1.7.0) <665156BC-0ADC-3FAB-ABF4-5D7DC4EB358B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x920a000 - 0x9261fff com.apple.print.framework.PrintCore (14.2 - 503.8) <53D3B655-BCEC-3F3C-84EF-C5D0A59FE9AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x928e000 - 0x9329ffb com.apple.QD (3.12 - 407.2) <57873F95-5E0A-3846-A39E-F565C8DEF6EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x9358000 - 0x9364ff7 com.apple.speech.synthesis.framework (8.1.0 - 8.1.0) <C86E6750-5B21-37A9-A4EE-782B5535BBA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x9377000 - 0x9402fff com.apple.SkyLight (1.600.0 - 337.5) <63C08C79-C6B2-36D3-ABBF-A11245CF2349> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x943f000 - 0x9449ffb com.apple.IOSurface (255.1 - 255.1) <649D7795-6892-3F75-B3CA-D22FA5DC6876> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x9458000 - 0x9537ffb libxml2.2.dylib (32.8) <CE872CDA-C945-3655-93B9-F045F0E0BF6D> /usr/lib/libxml2.2.dylib
0x9568000 - 0x98fcff7 com.apple.CFNetwork (976 - 976) <BBA882EC-6FAD-34A0-B846-1A42EFF103A0> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9b67000 - 0x9b68fff libDiagnosticMessagesClient.dylib (107) <5465517A-76D0-3820-B9E2-F5F418CC4C88> /usr/lib/libDiagnosticMessagesClient.dylib
0x9b6e000 - 0x9b74fff com.apple.CoreDisplay (101.3 - 106.2) <C401A2FC-276F-3BCB-99E0-0CFC0C37A03B> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x9b7b000 - 0x9c06ffb com.apple.Metal (158.5 - 158.5) <107A7753-D659-3263-B059-7B8EF5C681C8> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x9cd5000 - 0x9d00ff7 com.apple.MultitouchSupport.framework (2410.5 - 2410.5) <5BE90437-BB0E-37EE-B107-2630804409D3> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9d12000 - 0x9d22fff libbsm.0.dylib (39.200.18) <2AF0980B-C50A-3218-A4A9-85464C245EDE> /usr/lib/libbsm.0.dylib
0x9d2b000 - 0x9d2bff3 libauto.dylib (187) <756FA0AB-695A-3E77-9638-C82609CFAD89> /usr/lib/libauto.dylib
0x9d31000 - 0x9d3affb com.apple.DiskArbitration (2.7 - 2.7) <5ED8941E-1F4D-3DF9-A232-BA736211622A> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x9d45000 - 0x9d70ffb libarchive.2.dylib (54.200.3) <472A7278-F99F-381B-87CC-24C525176524> /usr/lib/libarchive.2.dylib
0x9d7b000 - 0x9fd8ff3 libicucore.A.dylib (62109.0.1) <7690810E-9955-3F41-AA03-A562842EDC9D> /usr/lib/libicucore.A.dylib
0xa0ae000 - 0xa0affff liblangid.dylib (128.15.1) <CFAD0231-3728-3E36-B285-880BAD235B9A> /usr/lib/liblangid.dylib
0xa0b4000 - 0xa0eaff3 libCRFSuite.dylib (41.15.4) <26A2DB6D-ED9C-3BD4-9AE9-469E2E05B99A> /usr/lib/libCRFSuite.dylib
0xa103000 - 0xa103fff libenergytrace.dylib (17.200.1) <4A1A595C-4952-358F-B449-CCCACAD86A7F> /usr/lib/libenergytrace.dylib
0xa108000 - 0xa114ff3 libkxld.dylib (4903.231.4) <E5383FD7-16B6-3F94-AAD2-69495B7D11E8> /usr/lib/system/libkxld.dylib
0xa11a000 - 0xa124ffb com.apple.AppleFSCompression (96.200.3 - 1.0) <8CE4DDE4-9B0F-39D5-A7E6-7DDCC69BF109> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0xa12c000 - 0xa12cfff libOpenScriptingUtil.dylib (179) <A5FC5128-48B8-3403-8C50-AD4A40604D91> /usr/lib/libOpenScriptingUtil.dylib
0xa131000 - 0xa146fff libcoretls.dylib (155.220.1) <8EB651D0-BBB1-3BF4-870F-E80B2C0EA35D> /usr/lib/libcoretls.dylib
0xa151000 - 0xa152fff libcoretls_cfhelpers.dylib (155.220.1) <9393C4DC-E1B6-33E2-98C6-842782980F5B> /usr/lib/libcoretls_cfhelpers.dylib
0xa158000 - 0xa15cfff libpam.2.dylib (22.200.1) <8CF5E709-D0EC-3C53-B780-9F4EC010E670> /usr/lib/libpam.2.dylib
0xa162000 - 0xa32bfff libsqlite3.dylib (274.20) <BD31C6A3-BD0E-377C-AE5F-2A5E73D677DC> /usr/lib/libsqlite3.dylib
0xa350000 - 0xa35dffb libxar.1.dylib (404) <CAE3AB0D-3290-31F4-BDAD-F967E6C457AE> /usr/lib/libxar.1.dylib
0xa367000 - 0xa374ff3 libbz2.1.0.dylib (38.200.3) <92F506A6-680B-3DD4-853A-85DCBDE308F9> /usr/lib/libbz2.1.0.dylib
0xa379000 - 0xa6c1ff3 libnetwork.dylib (1229.230.4) <BE981096-F576-3AA9-839C-EE748DB5B80C> /usr/lib/libnetwork.dylib
0xa740000 - 0xa756ff3 libapple_nghttp2.dylib (1.24.1) <DB0F74A3-3B45-3E1A-B931-1B948CC02F7E> /usr/lib/libapple_nghttp2.dylib
0xa762000 - 0xa797ff3 libpcap.A.dylib (79.200.4) <8ECD3E35-A521-31B3-8836-187B4FF34F0B> /usr/lib/libpcap.A.dylib
0xa8a6000 - 0xa8aefff com.apple.CoreServices.FSEvents (1239.200.12 - 1239.200.12) <347F84CF-9D27-35F2-B3DD-4D4919B5E2EA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0xa8b6000 - 0xab96fff com.apple.CoreServices.CarbonCore (1178.16 - 1178.16) <2551A1D4-5E06-387E-830A-2F0CDF01ABDF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0xac09000 - 0xacaaffb com.apple.Metadata (10.7.0 - 1191.53) <2D644884-885E-304F-9F82-ACF42992D569> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0xad10000 - 0xad5cfff com.apple.CoreServices.OSServices (941 - 941) <3BF6DD37-F548-3210-BA7F-FA2C440A0779> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0xad9a000 - 0xae0affb com.apple.SearchKit (1.4.0 - 1.4.0) <CE530729-9100-370C-9AF7-FEC27BA3A0D9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0xae45000 - 0xaec2ff7 com.apple.AE (771 - 771) <3F072B98-5F41-3739-80BE-E70C2D194E66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0xaef2000 - 0xb058ff7 com.apple.LaunchServices (941 - 941) <B113033B-3920-33D5-8DC7-2F66945DBC48> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0xb10d000 - 0xb156fff com.apple.DictionaryServices (1.2 - 284.16.3) <E3B52154-42CF-3760-8290-E99B601EEA42> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0xb185000 - 0xb1a8fff com.apple.coreservices.SharedFileList (71.27 - 71.27) <08F1F9F3-03FC-34E8-9C58-0E59AD168E32> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0xb1c4000 - 0xb1d0fff com.apple.NetFS (6.0 - 4.0) <48B3D583-8AF3-3CAA-89D9-4B508033490E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0xb1db000 - 0xb1e6fff com.apple.NetAuth (6.2 - 6.2) <39890A71-DC08-35E2-B03E-847F7226C73C> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0xb1f2000 - 0xb1f4fff com.apple.loginsupport (1.0 - 1) <BCB26247-E8F7-302F-99A9-98BB9D92E36D> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0xb1fa000 - 0xb207fff com.apple.TCC (1.0 - 1) <8458F418-577D-37AD-8120-B9E38F41D98A> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0xb213000 - 0xb286ff7 com.apple.CoreNLP (1.0 - 130.15.22) <62558277-FC72-3C5B-AA45-2E8EFB9EF1A5> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
0xb2dd000 - 0xb303ff3 com.apple.spotlight.metadata.utilities (1.0 - 1191.53) <FDEF84CA-7530-3717-8E8D-1B7FBF5CCDDB> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0xb316000 - 0xb54bff3 libmecabra.dylib (779.24.1) <DFC75C94-9C21-37BA-BAD4-072C6104A40B> /usr/lib/libmecabra.dylib
0xb58b000 - 0xb63fff3 libmecab.1.0.0.dylib (779.24.1) <42FC6D51-3DE2-397F-A2BE-84FF9D856236> /usr/lib/libmecab.1.0.0.dylib
0xb65c000 - 0xb660ff3 libgermantok.dylib (17.15.2) <3343C4FC-D775-3F2A-8982-E9EE5E2CD5D2> /usr/lib/libgermantok.dylib
0xb665000 - 0xb666ffb libThaiTokenizer.dylib (2.15.1) <F8F574E9-1058-3239-B0A3-0DDF10F138D6> /usr/lib/libThaiTokenizer.dylib
0xb66c000 - 0xb676fff libChineseTokenizer.dylib (28.15.3) <87B214C1-7BF8-3CD3-9AC7-AF1DDEC44B90> /usr/lib/libChineseTokenizer.dylib
0xb684000 - 0xb773ff7 libiconv.2.dylib (51.200.6) <D17BAAD4-A7F1-3895-BB25-5F48F24DB30B> /usr/lib/libiconv.2.dylib
0xb782000 - 0xb782fff libcharset.1.dylib (51.200.6) <57F3A9E9-0A36-3014-A063-BFC6BEC8C5A8> /usr/lib/libcharset.1.dylib
0xb787000 - 0xb87cff3 com.apple.LanguageModeling (1.0 - 159.15.15) <F127DE7A-211D-395E-B2DF-63B3DCD1D5DC> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0xb89e000 - 0xb8b1fff com.apple.CoreEmoji (1.0 - 69.19.8) <6F55EDF4-ACCE-359E-AC1D-24C3FDF0961C> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0xb8bb000 - 0xb8fbfff com.apple.Lexicon-framework (1.0 - 33.15.10) <FBCCD420-1568-35E5-8F34-5347591B76A1> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0xb909000 - 0xb90fffb com.apple.LinguisticData (1.0 - 238.23.4) <578E3719-A729-3EF8-9306-26659DE16EA6> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
0xb917000 - 0xb928ff3 libcmph.dylib (6.15.1) <B905AE90-2B23-3A67-B4CB-0184F2C84BEC> /usr/lib/libcmph.dylib
0xb931000 - 0xbc38ff3 com.apple.CoreData (120 - 866.1) <567440D6-7C41-3E59-8FFC-A83A0263C7F0> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0xbd50000 - 0xbd6cfff com.apple.CFOpenDirectory (10.14 - 207.200.4) <D822AFC4-97E2-34CD-933E-3328B0208BF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0xbd89000 - 0xbe3eff3 com.apple.APFS (1.0 - 1) <0AABE0DC-E313-33B5-A4A6-A78AE5E508EF> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0xbe56000 - 0xbe59ffb libutil.dylib (51.200.4) <F9735FE6-55EF-3310-A643-F71BB055D158> /usr/lib/libutil.dylib
0xbe60000 - 0xbe64ffb com.apple.xpc.ServiceManagement (1.0 - 1) <47B301E4-2384-3182-A39B-898400FE85F5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0xbe6d000 - 0xbe76fff com.apple.coreservices.BackgroundTaskManagement (1.0 - 57.1) <21333FF3-B98F-3F83-8533-772642C79642> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
0xbe81000 - 0xbea9ff3 libxslt.1.dylib (16.1) <6E7F1310-3C21-3996-9CA2-03FD8E788522> /usr/lib/libxslt.1.dylib
0xbeb6000 - 0xbebdffb com.apple.IOAccelerator (404.2.2 - 404.2.2) <D07EA10B-C1C7-3E6F-B8E7-5A6609229BEC> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0xbec9000 - 0xbee3fff com.apple.IOPresentment (1.0 - 42.6) <80DDBB43-804E-31A1-9DDC-D4D05F32ECAB> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0xbefe000 - 0xbf02fff libCoreFSCache.dylib (163.20) <27BA7C15-7F6D-33AA-8E7C-C488D52578CA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0xbf0a000 - 0xc1bcff3 com.apple.CoreImage (14.2.0 - 720.0.130) <C4801C22-3A69-3E1A-A11D-0315283EC957> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0xc2da000 - 0xc317ffb com.apple.CoreVideo (1.8 - 0.0) <077CA75F-2E78-3585-8434-EF7B682DF134> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0xc33e000 - 0xc34dffb com.apple.opengl (17.3.1 - 17.3.1) <E1494834-712B-35D7-BA05-0F711054258C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0xc357000 - 0xc781ff7 com.apple.vision.FaceCore (3.3.4 - 3.3.4) <1EAA786A-9BB0-3958-B5C1-647E7DBF5112> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0xc984000 - 0xc9dafff com.apple.opencl (2.15.1 - 2.15.1) <BB0B1430-6F10-3ABE-8C59-367616ACDB13> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0xc9f2000 - 0xcbd1fff libFosl_dynamic.dylib (18.3.2) <261F99EE-EA89-3600-853D-658090F21518> /usr/lib/libFosl_dynamic.dylib
0xcbfb000 - 0xcc50ff3 com.apple.OTSVG (1.0 - ???) <36551FFA-4361-36DA-AC39-705256F0C14F> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
0xccbe000 - 0xcddeffb libFontParser.dylib (228.6) <E396DF8E-D9A3-364D-9DA2-C3763A9C1303> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0xce42000 - 0xce8ffff libFontRegistry.dylib (228.12) <0495BEF7-4CAF-3B19-AC97-F1A32A66A85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0xcebb000 - 0xcee0fff libJPEG.dylib (1822.1) <5C694B72-2212-380E-99DC-466305BBFA69> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0xcee9000 - 0xcf34ff7 libTIFF.dylib (1822.1) <CCE42D40-1413-38B3-B09C-D3F697A68879> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0xcf43000 - 0xcf69fff libPng.dylib (1822.1) <8BA9F9E2-1DB2-3392-8921-DFFC7F060D1B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0xcf74000 - 0xcf78ff3 libGIF.dylib (1822.1) <417C6E86-A8B9-34E7-BC09-5DB27B200A2B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0xcf7e000 - 0xd06dffb libJP2.dylib (1822.1) <9F36893E-47CC-3C7B-B7E0-5655A2CE41B9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0xd094000 - 0xd096ff7 libRadiance.dylib (1822.1) <8E87CC6C-4BCC-39BD-9777-50CE5C067B04> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0xd09b000 - 0xd0d9ff7 com.apple.AppleJPEG (1.0 - 1) <8517F00F-6C7A-3578-B032-5818F9F5681E> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0xd0e6000 - 0xd0eeff3 libGFXShared.dylib (17.3.1) <C2A02BE5-75BF-331A-9956-066D9F21504B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0xd0f6000 - 0xd134ff7 libGLU.dylib (17.3.1) <0FB7ED33-DF36-3408-A318-0FF7EDB34D8D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0xd144000 - 0xd150fff libGL.dylib (17.3.1) <42079985-DAE8-3DCC-B43B-BC0E5DE49EC7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0xd164000 - 0xd19efeb libGLImage.dylib (17.3.1) <8920933D-2071-37F9-8753-5C5AA1AFCD3D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0xd1a7000 - 0xd1a9fff libCVMSPluginSupport.dylib (17.3.1) <3F62B879-B5FA-345B-BB39-E4892C9F731F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0xd1af000 - 0xd1b3fff libCoreVMClient.dylib (163.20) <5C118C31-83E8-394C-BE8C-23A25574DDF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0xd1bd000 - 0xd216ff3 libcups.2.dylib (462.10) <5ADC14E7-DB26-345B-870F-F4842CAD7B22> /usr/lib/libcups.2.dylib
0xd22c000 - 0xd245fff com.apple.Kerberos (3.0 - 1) <6FCEF94D-206B-31BE-9B20-83DE394AE9A2> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0xd25e000 - 0xd28dff7 com.apple.GSS (4.0 - 2.0) <AC7A12B2-AB96-3CC4-A96D-7AB27C8806D5> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0xd2ab000 - 0xd2c3ff7 libresolv.9.dylib (65.200.2) <7111FB3C-2E53-3B13-B454-E156868661EF> /usr/lib/libresolv.9.dylib
0xd2cc000 - 0xd340fff com.apple.Heimdal (4.0 - 2.0) <3F84C15D-6E1E-315D-A2EA-FFE7496738C9> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0xd36c000 - 0xd370fff libheimdal-asn1.dylib (520.220.2) <04D8040A-7B69-3CC4-B2F5-5A0E1F99F3DB> /usr/lib/libheimdal-asn1.dylib
0xd377000 - 0xd382ffb com.apple.OpenDirectory (10.14 - 207.200.4) <B3E6C993-A7BF-38BC-AD80-F91CC9398793> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0xd392000 - 0xd39bff7 com.apple.CommonAuth (4.0 - 2.0) <EF77B7D4-2469-30F2-B011-71644A5AF219> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0xd3a3000 - 0xd415ffb com.apple.securityfoundation (6.0 - 55185.200.14) <299EAAA1-94B1-3869-ACEC-EC1BC5E69E22> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0xd448000 - 0xd4dfffb com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <7268E8ED-17EB-36DD-89C3-4833E35A90EF> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0xd509000 - 0xd754fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <E071D6CC-A016-3C17-93C6-B24666EE3852> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0xd824000 - 0xd82dff7 com.apple.audio.SoundManager (4.2 - 4.2) <5393BF3E-6834-32E3-BDA3-DEAB54A7F107> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0xd836000 - 0xd83aff3 com.apple.CommonPanels (1.2.6 - 98) <106AB5B2-CD58-32E3-BBB6-4E760C9A765C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0xd843000 - 0xd846fff com.apple.help (1.3.8 - 66) <E825DD87-2B38-3A1D-9FF0-5CD3986254AD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0xd84c000 - 0xdbe0ffb com.apple.HIToolbox (2.1.1 - 917.3) <1C768683-67E4-3B54-8BA2-79257DBBE197> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0xdd73000 - 0xddc8ff7 com.apple.htmlrendering (77 - 1.1.4) <1DC0507C-9770-3ADA-9711-BD2E4BE25417> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0xddf0000 - 0xddf5fff com.apple.ImageCapture (9.0 - 1530.1) <87BDE9EC-F444-30E5-849A-FF3C30D1257D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0xde03000 - 0xde9dff7 com.apple.ink.framework (10.9 - 225) <DDA1A93B-C6CB-32A7-AB84-05B3F036C8AC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0xdec8000 - 0xdf02ff7 com.apple.NavigationServices (3.8 - 227) <C022CA9F-9465-3CD3-BC49-522026215021> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0xdf29000 - 0xdf45ff7 com.apple.openscripting (1.7 - 179) <6AD64B36-8ADA-35AD-9785-0126C6431472> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0xdf59000 - 0xdf5bffb com.apple.securityhi (9.0 - 55006) <1CC9F765-E73B-39ED-AA60-069CFC392D4B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0xdf61000 - 0xdf67ffb com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <CA4C4090-DEAC-3FB7-8E77-3E3512A718BF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0xdf71000 - 0xe095ffb com.apple.coreui (2.1 - 498.46) <236A4292-E4CD-3CA6-913F-6EC3BC06CC4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0xe214000 - 0xe375ff7 com.apple.desktopservices (1.13.1 - ???) <31E2F016-F906-3324-867F-D6F878820140> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0xe427000 - 0xe434ff7 com.apple.PerformanceAnalysis (1.217 - 217) <E85D67D4-8CC1-3DFA-B60D-B7FF3D2B7015> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0xe448000 - 0xe45fffb com.apple.TextureIO (3.8.4 - 3.8.1) <12F5BF24-5A94-38E8-87AB-DF29176BDD55> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0xe474000 - 0xe5befef libate.dylib (1.13.8) <7C8175C5-40D4-3191-AD74-B290BB1C7005> /usr/lib/libate.dylib
0xe5cd000 - 0xe5defff com.apple.CrashReporterSupport (10.13 - 938.23) <6F5E5CAD-6E33-3D4C-B234-B643F479226D> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0xe5ef000 - 0xe60bff7 com.apple.Sharing (1214.18 - 1214.18) <9887351C-B0EB-359E-9479-FE1AA3B8FBAE> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0xe625000 - 0xe64effb com.apple.IconServices (379 - 379) <4C6BBD55-98F6-36D9-8C13-98360C0AFC31> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0xe66c000 - 0xe69bffb com.apple.framework.Apple80211 (13.0 - 1376.2) <6CB729D7-E03C-3AA9-AD78-A0B692C51AC1> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0xe6a9000 - 0xe77dfff com.apple.CoreUtils (5.7.4 - 574.17) <24E018F4-08AF-3E15-8977-47613BB82D39> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0xe7c2000 - 0xe856ff3 com.apple.framework.CoreWLAN (13.0 - 1370.8) <2C43E803-470B-30DC-A1C9-7BB004AFF8A9> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0xe8a2000 - 0xe9c0ffb com.apple.Bluetooth (6.0.9 - 6.0.9f2) <533F910A-ACB3-3633-9CD5-82C4DBFA9FF4> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0xea23000 - 0xea3fffb com.apple.ProtocolBuffer (1 - 263.1) <30EBCC82-D721-32C6-B3BF-7734116D0817> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0xea55000 - 0xeab2ffb com.apple.framework.CoreWiFi (13.0 - 1370.8) <AE1355B7-188A-3D87-A7FB-E43B6C8D3B82> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0xeaf2000 - 0xeaf7fff com.apple.CoreBluetooth (1.0 - 1) <CC083C81-8E4A-37C5-9D6B-6E032E209524> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0xeb07000 - 0xeb07fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <870149D6-4699-3526-B611-2BF612E74B86> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0xeb12000 - 0xeb53ff3 com.apple.DebugSymbols (185 - 185) <383F51CE-7A5D-3715-8731-539E7DF168AD> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0xeb70000 - 0xec02ff3 com.apple.CoreSymbolication (10.1 - 64460.6) <AE24DAA1-4240-31C6-AB70-0782E8170912> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0xec50000 - 0xecdbff3 com.apple.Symbolication (10.1 - 64460.8) <9FDAD63F-2CF1-3E54-916B-6C7BAFA80697> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0xed1a000 - 0xed27fff com.apple.SpeechRecognitionCore (5.0.21 - 5.0.21) <119F38DD-043D-3C14-8E46-66BDD7C81749> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0xed35000 - 0xed57fff com.apple.RemoteViewServices (2.0 - 128) <6E4A2579-AF29-357A-9DE6-93D1236859B6> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0xed75000 - 0xeefdff3 com.apple.UIFoundation (1.0 - 551) <98B10ECC-7ACD-3875-AF4E-D4E4AE4DB0A9> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0xef8b000 - 0xef98ffb com.apple.framework.DFRFoundation (1.0 - 211) <8284ABF2-AC59-37A5-A31E-2CC5BEB5FABB> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0xefa6000 - 0xf016ffb com.apple.datadetectorscore (7.0 - 590.24) <5E03164D-8E1B-3EE4-8B89-27DD4360DFDB> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0xf047000 - 0xf0ecff3 com.apple.backup.framework (1.10.2 - ???) <CD5999B9-0DDA-333B-8236-760C00B1C05A> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0xf160000 - 0xf224ffb com.apple.DiskManagement (12.0 - 1530) <46E75BCB-3B61-3CEA-AB07-8F3AD5B919CC> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
0xf258000 - 0xf26cffb com.apple.QuickLookThumbnailing (1.0 - 1) <87BC2B72-24E0-37F1-8A1A-7B92C7617DB1> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThumbnailing
0xf27c000 - 0xf2b2ff7 com.apple.MediaKit (16 - 906) <20999D1C-C244-3385-AA4C-90AB8DF4EBEB> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0xf2c3000 - 0xf380ff3 com.apple.DiscRecording (9.0.3 - 9030.4.5) <30F2B3EC-4934-3C1A-8BE0-C46BBF012984> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0xf3db000 - 0xf473ffb libCoreStorage.dylib (546.50.1) <223FBF9A-CBF0-31BA-9270-F607F71CD26F> /usr/lib/libCoreStorage.dylib
0xf49a000 - 0xf4a5ff3 libcsfde.dylib (546.50.1) <F24DE8EB-4B3B-31EE-A98E-76014B5DD682> /usr/lib/libcsfde.dylib
0xf4b0000 - 0xf4b3fff com.apple.EFILogin (2.0 - 2) <1E014838-F95A-3935-8E62-777F4F3B0E61> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0xf4bb000 - 0xf4f9ffb com.apple.ProtectedCloudStorage (1.0 - 1) <7936A711-40BC-30AC-BBA7-3F8FB566FA04> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0xf525000 - 0xf54bffb com.apple.GenerationalStorage (2.0 - 285.101) <B855AC08-AAAD-39E6-B194-11460D93E62C> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0xf55f000 - 0xf6eaff3 com.apple.WebKitLegacy (14606 - 14606.3.4) <DE16CFE2-133A-3350-9102-692539D25557> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0xf7f6000 - 0x10f9ffff com.apple.WebCore (14606 - 14606.3.4) <043CF540-E759-3FC9-ADDC-9B5BA9F4DC57> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x11c2e000 - 0x125edffb com.apple.JavaScriptCore (14606 - 14606.3.4) <0BEEB4E3-4D5A-3273-A6FF-06CE7BAEE6B6> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x12828000 - 0x12828fff com.apple.Cocoa (6.11 - 23) <92BD2E6F-3176-37E7-BEA0-D7A48CE4FD16> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x1282c000 - 0x12d44ff7 com.apple.QuartzComposer (5.1 - 370) <0CBD2B0B-E4D1-3B08-9CCF-99EEBB01C053> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x12fb2000 - 0x1308affb com.apple.PDFKit (1.0 - 737.3) <CBF23149-D721-33F4-BF94-85EDFE6FA342> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x130ed000 - 0x13112fff com.apple.quartzfilters (1.10.0 - 83) <273F7E39-407D-3281-97EF-79ED4FCE607F> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x13131000 - 0x1337dfff com.apple.imageKit (3.0 - 1067) <846C8DFE-623B-3600-834F-EBA4EE43DDB3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x1352e000 - 0x13624ff7 com.apple.QuickLookUIFramework (5.0 - 775.3) <18B28AF7-D1CB-3121-BB29-C6FBB061E042> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x136c3000 - 0x13817fff com.apple.QTKit (7.7.3 - 3034) <6F94E437-18B1-334D-8960-AA080F67A503> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x138ef000 - 0x138f2ff3 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <560EA215-3721-3254-BDF8-03B108479422> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x138f9000 - 0x13acaff3 com.apple.avfoundation (2.0 - 1544.5) <F8F412FE-FD3A-3E4E-874B-0B214942F3DA> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x13c42000 - 0x13d47fff com.apple.CoreMedia (1.0 - 2284.9) <AA21EBC9-CA8C-3F46-B16A-F274ECD54543> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x13de0000 - 0x144acff3 com.apple.MediaToolbox (1.0 - 2284.9) <86CB1948-A510-3556-ACE1-50EC00F6B0D9> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x14614000 - 0x149adff3 com.apple.VideoToolbox (1.0 - 2284.9) <F6888D29-CCA8-3088-B92C-C2F16C480F39> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x14a04000 - 0x14c5afe7 com.apple.QuickTime (7.7.3 - 3034) <DBDD8606-9461-3EB1-9725-CBDFE3C16F5F> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x14d05000 - 0x14d1cff7 com.apple.CoreMediaAuthoring (2.2 - 958) <B8D056E7-0AA4-3CB6-96A3-26DBC2B3FBF1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x14d33000 - 0x14d9affb com.apple.CoreMediaIO (900.0 - 5025) <8F75D515-1EFF-3BED-9F27-5DB713A68445> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x14dc0000 - 0x14e8dfff com.apple.audio.AVFAudio (1.0 - ???) <DF3402B0-D0FE-3BC5-9C9F-CDCFB71485C0> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
0x14ee9000 - 0x14f1aff3 com.apple.CoreAVCHD (6.0.0 - 6000.4.1) <74A89965-77B8-38FE-B006-09A2EAF01069> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x14f25000 - 0x14f30fff com.apple.MediaAccessibility (1.0 - 114.4) <EDC273A1-7A0E-35D1-8AAA-9D807F1EC8EE> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x14f3f000 - 0x15254fe7 com.apple.CoreAUC (273.0.0 - 273.0.0) <259CA3FC-D646-3807-BB35-6DAD0BCCBC92> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x15264000 - 0x152beff7 com.apple.AppleVAFramework (5.0.44 - 5.0.44) <CFF3C3A7-BAAD-390D-BFFC-4B9BE2FAD91C> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x152ca000 - 0x15351fff com.apple.CorePDF (4.0 - 414) <8668540D-9891-3B27-8649-90CBEC4BD3D5> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x15395000 - 0x15398fff com.apple.DisplayServicesFW (3.1 - 380) <52769A25-2DB5-3581-9383-8F5EC43044EE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x153a0000 - 0x153f4ff7 com.apple.ImageCaptureCore (1.0 - 1530.1) <53C5B3CD-DE0A-3642-98F9-8905B91C42A5> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x15428000 - 0x1542afff com.apple.SafariServices.framework (14606 - 14606.3.4) <A29D4699-D3E2-3CFE-A5DD-7143DD9EEB35> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x15431000 - 0x1550ffff com.apple.ViewBridge (401.1 - 401.1) <ADE6331C-BBF5-3539-BC97-84D3BE863D87> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x64b00000 - 0x64b05fff com.apple.print.framework.Print (14.2 - 267.4) <89387933-D438-357F-AE2A-42EE75B34DDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
You say you have no need to upgrade to DC... well, if you upgrade to Mac OS 10.15 later this year you ABSOLUTELY will need to upgrade to DC because XI will not work, Apple have decided it.
But for now: I guess you see "Acrobat" on the menu bar after trying to open the file, but no file? If so, use Window > Tile > Horizontal. Fixes it for many.
Thanks, I will be sure to hold off OS updates later.
