Hi, I was wondering if anyone could tell me where PS saves brushes you have created yourself. I see them in my brush panel but I cannot find them in my C:/ drive anywhere. I wanted to share them with the .abr extension but cannot seem to locate them.
Thanks so much in advance!
Julie
It turns out you are completely right, and we shouldn't assume stuff just because it appears to work.
I made a new preset; gave it a searchable name, and searched the entire boot drive. It was not there.
I did the same with a new brush group with the same negative result.
I shut Photoshop and tried again. Still noting.
Si it appears that unless you put new presets in a new set and save with the Preset Manager, they are not there in either of the preset folders.
Thinking back to some of the presets
...Copy link to clipboard
Hi Julie
Have you checked this location
C:\Users\yourname\AppData\Roaming\Adobe\Adobe Photoshop CC 2019\Presets
Hi Ged,
I just checked and it is not there.
Julie
It sounds like you are using Windows, in which case, your new brushes will probably be here
C:\Program Files\Adobe\Adobe Photoshop CC 2019\Presets\Brushes
But if you make set and drag your new presets into it, I am pretty sure the resulting file will be in folder Ged indicated.
C:\Users\[your user name]\AppData\Roaming\Adobe\Adobe Photoshop CC 2019\Presets\brushes
Thanks but that is the first place I checked.
Custom brushes I have downloaded I put there. However the ones I actually
make myself I cannot find anywhere except in my brush panel.
And yes, I am using Windows PS CC 2019. Sorry, I should have clarified.
Julie
On Tue, Dec 18, 2018 at 3:01 PM Trevor.Dennis <forums_noreply@adobe.com>
Hmmmm....Have you tried using the Preset Manager and saving them as a set? Doing that would at least allow you to control where the ABR files are saved to
I don’t believe I have done that.
I edit, define brush preset and the brush is at the bottom of my brush
panel. I made a folder inside the brush panel with my name and put them in
there.
Is that what you’re talking about? I am not in front of my pc at the
moment.
Thanks!
On Tue, Dec 18, 2018 at 3:55 PM DaveJCummings <forums_noreply@adobe.com>
Thinking back to some of the presets I've made over the years, I have just checked and I don't still have them, which is a sign of sloppy work and laziness. I enjoy the process of making presets. The chain in this watch illustration (it's 100% Photoshop) is a brush preset, and I have made similar presets for rope and other types of chain. It's all a learning process, and I think we do a better job each time we remake a preset, but I will thank you for pointing this out, and try to improve my asset management so I don't have to reorganise stuff with every upgrade.
Thank you so much, at least I know I can now save them.
3 times PS crashed on me & I lost my brushes I made. I will do as you
suggested.
BTW your watch is very cool! Love the chain.
Julie
On Tue, Dec 18, 2018 at 5:59 PM Trevor.Dennis <forums_noreply@adobe.com>
