Hi. If I have two files about a game, a main flash file and a monster class "class" file, can I have the monster class code interact with the main flash file's properties by way of typeing in the line.
(this.parent as MainFileClass).characterHP -= 10
or
attackProcess((this.parent as MainFileClass.character),
the way I would the opposite direction using (enemyMonsterBox[0] as Monster).monsterType= "ice".
Hi.
You have to instantiate your characters first. Assuming that your class is in the same folder as the FLA:
var hero:Hero = new Hero();
hero.hp -= 10;
addChild(hero);
OR
addChild(hero);
var monster:Monster = new Monster();
monster.type = "ice";
addChild(monster);
monster.attack(hero); // hero loses 10 HP points
And, yeah, if you have an array holding references to monster instances, you would have to do like you did here:
(enemyMonsterBox[0] as Monster).type= "ice";
Please tell u
...Copy link to clipboard
Hi.
hero.hp -= 10;
addChild(hero);
OR
addChild(hero);
addChild(monster);
Please tell us if this is what you wanted to know.
Regards,
JC
What I wanted to know is if you could put in the Monster Class code something to interact with the character thats located as a variable in the main class code. The answer is either, yes, you can do it but you would do it by referring to "this"'s "parent" as mainflashcode class, or no flash does not allow. get me? As in I want the Monster class to handle a portion of coding calculations for hit penalties and stuff, and I want the monster class code to come "come get" the variable for the characters hp from the main class code, the main flash
You don't have to use this.parent because your Main class becomes the root.
I have an example here.
[Main.as // document class]
package
import flash.display.MovieClip;
public class Main extends MovieClip
public var hero:Hero;
public function Main()
hero = new Hero();
addChild(hero);
[Hero.as]
package
public class Hero extends MovieClip
public var hp:int = 0;
public function Hero()
[Monster.as]
package
public class Monster extends MovieClip
public var attackForce:uint = 10;
public function Monster()
public function attack(target:Hero):void
target.hp -= attackForce;
trace("Monster attack! Hero's HP is now " + target.hp + ".");
[FLA code in the first frame of the main timeline]
addChild(monster);
I hope this helps clarifying things.
Regards,
JC
