3 Replies Latest reply on Jan 11, 2019 11:46 AM by wodnicki
    How to create a well-defined SOAP method definition?
    lukkyluke Level 1
      Hi all,
      So far we have been defining complex method responses as DOMElements.
      Example:
      <method library="xxx:customFunction.js" name="getEntity" static="true">
        <parameters>
         <param inout="in" label="Target ID" name="targetId" type="string"/>
         <param inout="in" label="Max count to be returned" name="maxCount" type="byte"/>
         <param inout="out" label="Response Xml" name="response" type="DOMElement"/>
        </parameters>
      </method>
      However, it would be much more convenient to be able to write a more well-defined response. For example when other third parties want to automatically generate classes from the Adobe Campaign wsdl. The usage of DOMElement (above) does not give us a well-defined response about the following information:
      <SOAP-ENV:Envelope xmlns:xsd="http://www.w3.org/2001/XMLSchema"
      xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
      xmlns:ns="urn:nms:propositionRcp" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
         <SOAP-ENV:Body>
            <getEntityResponse SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"
            xmlns="urn:nms:propositionRcp">
               <response xsi:type="ns:Element"
               SOAP-ENV:encodingStyle="http://xml.apache.org/xml-soap/literalxml">
                  <entities>
                     <entity id="1">
                        <title>TestTitle</title>
                        <shortText/>
                        <text>TestText</text>
                        <icon>2</icon>
                     </entity>
                     <entity id="2">
                        <shortText/>
                        <icon>1</icon>
                     </entity>
                  </entities>
               </response>
            </getEntityResponse>
         </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      I am thinking of something like this:
            <parameters>
              <param inout="in" label="Max count" name="maxCount" type="byte"/>
              <param inout="out" label="entities" name="entities" type="DOMElement">
                <param inout="out" label="entity" name="entity" type="DOMElement">
                  <param inout="out" label="title" name="title" type="string"/>
                  <param inout="out" label="shortText" name="shortText" type="string"/>
                  <param inout="out" label="text" name="text" type="string"/>
                  <param inout="out" label="icon" name="icon" type="string"/>
                </param>
             </param>
            </parameters>
          </method>
      Has anyone been able to accomplish this?
      Looking forward to your response
