1 Reply Latest reply on Mar 18, 2010 9:53 AM by DigitalArchitectCanada
    Is it possible to use attachMovie with a variable ID reference?
    gbowhall
      Hello:
      I am trying to write an attachMovie statement with a variable feeding the ID parameter. Is that possible?
      For Example:
      fadeInVar = '"LS_body_home_ID"';
      _level0.LS_hitArea_body.attachMovie([fadeInVar], "attached_LS_body", 1);
      I can't quite figure out how to write this. I tried an eval function as well...
      If you have any ideas, please let me know.
      Thank you!
      - Garrett
        • 1. Re: Is it possible to use attachMovie with a variable ID reference?
          DigitalArchitectCanada Level 3
          I'm not so sure that this will even work but off the top of my head I can say remove the [] from around [fadeInVar].
          AS2... not sure if this will work. I know in AS3 it wouldn't. It would for sure work if you externalized your images/swfs from the library and used a moviecliploader to load in a swf/image from a URL.
          function loadFile(fileURL:String):Void
               var mcl:MovieClipLoader = new MovieClipLoader();
               mcl.load(fileURL, container); //Where container would be the display object (movieclip or Bitmap) that you wanted to load the item into.
               //To dynamically create something you can add the image into, do this
               var mcContainer:MovieClip = stage.createEmptyMovieClip("containerClip" + stage.getNextHighestDepth()");
               mcl.load(fileURL, mcContainer); //Where container would be the  display object (movieclip or Bitmap) that you wanted to load the item  into.
          Use of the above function would be:
          loadFile("images/image1.jpg");
          Let me know if that helps.
