0 Replies Latest reply on Jan 9, 2019 11:36 PM by joelm3912738
    Error Building IOS App version
    joelm3912738 Level 1
      This is the error i get from the log
      Build Date: 2019-01-09 03:17:09 -0800
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-camera@~ 2.1. 1" via npm
      Installing "cordova-plugin-camera" at "1.2.0" for ios
      Fetching plugin "cordova-plugin-console@~ 1.0.2" via npm
      Installing "cordova-plugin-console" at "1.0.7" for ios
      Fetching plugin "cordova-plugin-device@~ 1.1.1" via npm
      Installing "cordova-plugin-device" at "1.1.7" for ios
      Fetching plugin "cordova-plugin-device-motion@~ 1.2.0" via npm
      Installing "cordova-plugin-device-motion" at "1.2.5" for ios
      Fetching plugin "cordova-plugin-device-orientation@~ 1.0.2" via npm
      Installing "cordova-plugin-device-orientation" at "1.0.7" for ios
      Fetching plugin "cordova-plugin-dialogs@~ 1.2.0" via npm
      Installing "cordova-plugin-dialogs" at "1.2.1" for ios
      Fetching plugin "cordova-plugin-file@~ 4.1.1" via npm
      Installing "cordova-plugin-file" at "4.1.1" for ios
      The Android Persistent storage location now defaults to "Internal". Please check this plugins README to see if you application needs any changes in its config.xml.
      If this is a new application no changes are required.
      If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
        "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
      to config.xml in order for the application to find previously stored files.
      Fetching plugin "cordova-plugin-file-transfer@~ 1.5.0" via npm
      Installing "cordova-plugin-file-transfer" at "1.5.1" for ios
      Plugin dependency "cordova-plugin-file@4.1.1" already fetched, using that version.
      Dependent plugin "cordova-plugin-file" already installed on ios.
      Fetching plugin "cordova-plugin-globalization@~ 1.0.3" via npm
      Installing "cordova-plugin-globalization" at "1.0.9" for ios
      Fetching plugin "cordova-plugin-inappbrowser@~ 1.3.0" via npm
      Installing "cordova-plugin-inappbrowser" at "1.3.0" for ios
      Fetching plugin "cordova-plugin-media-capture@~ 1.2.0" via npm
      Installing "cordova-plugin-media-capture" at "1.2.0" for ios
      Fetching plugin "cordova-plugin-network-information@~ 1.2.0" via npm
      Installing "cordova-plugin-network-information" at "1.2.1" for ios
      Fetching plugin "cordova-plugin-splashscreen@~ 3.2. 1" via npm
      Installing "org.apache.cordova.splashscreen" at "1.0.0" for ios
      Fetching plugin "cordova-plugin-statusbar@~ 2.1.2" via npm
      Installing "cordova-plugin-statusbar" at "2.1.3" for ios
      Fetching plugin "cordova-plugin-vibration@~ 2.1.0" via npm
      Installing "cordova-plugin-vibration" at "2.1.6" for ios
      Fetching plugin "cordova-plugin-whitelist@~ 1.2.1" via npm
      Installing "cordova-plugin-whitelist" at "1.2.2" for ios
      COMPILE OUTPUT
      Now using system ruby.
      Building project: /private/project/PWCApp.xcworkspace
      Configuration: Release
      Platform: device
      Adding xcodebuildArg: -UseModernBuildSystem=0
      User defaults from command line:
        IDEArchivePathOverride = /private/project/PWCApp.xcarchive
        UseModernBuildSystem = 0
      Build settings from command line:
        CONFIGURATION_BUILD_DIR = /private/project/build/device
        SHARED_PRECOMPS_DIR = /private/project/build/sharedpch
      Build settings from configuration file '/private/project/cordova/build-release.xcconfig':
        ARCHS = armv7 arm64
        CLANG_ALLOW_NON_MODULAR_INCLUDES_IN_FRAMEWORK_MODULES = YES
        CODE_SIGN_ENTITLEMENTS = /project/app.entitlements
        CODE_SIGN_IDENTITY = iPhone Developer
        CONFIGURATION_BUILD_DIR = /project/build
        CORDOVALIB = /project/CordovaLib
        DEVELOPMENT_TEAM = B9RVK38228
        ENABLE_BITCODE = false
        HEADER_SEARCH_PATHS = "$(TARGET_BUILD_DIR)/usr/local/lib/include" "$(OBJROOT)/UninstalledProducts/include" "$(OBJROOT)/UninstalledProducts/$(PLATFORM_NAME)/include" "$(BUILT_PRODUCTS_DIR)"
        IPHONEOS_DEPLOYMENT_TARGET = 8.0
        ONLY_ACTIVE_ARCH = NO
        OTHER_CODE_SIGN_FLAGS = --keychain /secure.keychain
        OTHER_LDFLAGS = -ObjC
        PROVISIONING_PROFILE = 51f1e39b-ea2e-40d2-9729-870690f4f513
        SWIFT_OBJC_BRIDGING_HEADER = $(PROJECT_DIR)/$(PROJECT_NAME)/Bridging-Header.h
        TARGETED_DEVICE_FAMILY = 1,2
      Prepare build
      note: Using legacy build system
      === BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
      Check dependencies
      Write auxiliary files
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
      /bin/mkdir -p /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
      /bin/mkdir -p /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
      /bin/mkdir -p /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl
      write-file /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch.pch.hash-criteria
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova.hmap
      write-file /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
      /bin/mkdir -p /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo
      write-file /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch.pch.hash-criteria
      SymLink /project/build/libCordova.a /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
        cd /project/CordovaLib
        /bin/ln -sfh /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a /project/build/libCordova.a
      CpHeader Classes/Public/CDVWebViewEngineProtocol.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVWebViewEngineProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVWebViewEngineProtocol.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDV.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDV.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDV.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegateImpl.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVCommandDelegateImpl.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVWhitelist.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVWhitelist.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVWhitelist.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVPlugin+Resources.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVPlugin+Resources.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPlugin+Resources.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVScreenOrientationDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVScreenOrientationDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVScreenOrientationDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVCommandQueue.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVCommandQueue.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandQueue.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVAppDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVAppDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAppDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVUIWebViewDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVAvailability.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVAvailability.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAvailability.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/NSMutableArray+QueueAdditions.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/NSMutableArray+QueueAdditions.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVPluginResult.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVPluginResult.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPluginResult.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVInvokedUrlCommand.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVInvokedUrlCommand.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/NSDictionary+CordovaPreferences.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/NSDictionary+CordovaPreferences.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVPlugin.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVPlugin.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVPlugin.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVURLProtocol.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVURLProtocol.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVURLProtocol.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVAvailabilityDeprecated.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVAvailabilityDeprecated.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVAvailabilityDeprecated.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVCommandDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVCommandDelegate.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVCommandDelegate.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVUserAgentUtil.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVUserAgentUtil.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVUserAgentUtil.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVTimer.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVTimer.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVTimer.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVViewController.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVViewController.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVViewController.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      CpHeader Classes/Public/CDVConfigParser.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova/CDVConfigParser.h
        builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -resolve-src-symlinks /project/CordovaLib/Classes/Public/CDVConfigParser.h /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/include/Cordova
      ProcessPCH /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch.pch CordovaLib_Prefix.pch normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c-header -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -MD -MT dependencies -MF /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch.d -c /project/CordovaLib/CordovaLib_Prefix.pch -o /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch.pch --serialize-diagnostics /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch.dia
      ProcessPCH /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch.pch CordovaLib_Prefix.pch normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c-header -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -MD -MT dependencies -MF /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch.d -c /project/CordovaLib/CordovaLib_Prefix.pch -o /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch.pch --serialize-diagnostics /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch.dia
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o Classes/Public/CDVViewController.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.dia -c /project/CordovaLib/Classes/Public/CDVViewController.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVViewController.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.dia -c /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSDictionary+CordovaPreferences.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.dia -c /project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVAppDelegate.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewDelegate.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.dia -c /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandDelegateImpl.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.dia -c /project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVJSON_private.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.dia -c /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVInvokedUrlCommand.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /project/CordovaLib
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.dia -c /project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVWhitelist.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o Classes/Public/CDVTimer.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.dia -c /project/CordovaLib/Classes/Public/CDVTimer.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVTimer.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.dia -c /project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUserAgentUtil.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.dia -c /project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVConfigParser.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVGestureHandler.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVHandleOpenURL.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewNavigationDelegate.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.dia -c /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/NSMutableArray+QueueAdditions.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.dia -c /project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVCommandQueue.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.dia -c /project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPluginResult.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.dia -c /project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin+Resources.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.dia -c /project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVURLProtocol.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /project/CordovaLib
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVUIWebViewEngine.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o Classes/Public/CDVPlugin.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.dia -c /project/CordovaLib/Classes/Public/CDVPlugin.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVPlugin.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVLocalStorage.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch armv7 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wno-shorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/armv7 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-curmkwvjonutziaauvfhxizuupxo/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavi gationFilter.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/CDVIntentAndNavigationFilter.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o Classes/Public/CDVViewController.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.dia -c /project/CordovaLib/Classes/Public/CDVViewController.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVViewController.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.o Classes/Public/NSDictionary+CordovaPreferences.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.dia -c /project/CordovaLib/Classes/Public/NSDictionary+CordovaPreferences.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSDictionary+CordovaPreferences.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o Classes/Public/CDVAppDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.dia -c /project/CordovaLib/Classes/Public/CDVAppDelegate.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVAppDelegate.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewDelegate.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewDelegate.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o Classes/Public/CDVCommandDelegateImpl.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.dia -c /project/CordovaLib/Classes/Public/CDVCommandDelegateImpl.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandDelegateImpl.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o Classes/Private/CDVJSON_private.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.dia -c /project/CordovaLib/Classes/Private/CDVJSON_private.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVJSON_private.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o Classes/Public/CDVWhitelist.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.dia -c /project/CordovaLib/Classes/Public/CDVWhitelist.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVWhitelist.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o Classes/Public/CDVInvokedUrlCommand.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.dia -c /project/CordovaLib/Classes/Public/CDVInvokedUrlCommand.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVInvokedUrlCommand.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o Classes/Public/CDVTimer.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /project/CordovaLib
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.dia -c /project/CordovaLib/Classes/Public/CDVTimer.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVTimer.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o Classes/Public/CDVUserAgentUtil.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.dia -c /project/CordovaLib/Classes/Public/CDVUserAgentUtil.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUserAgentUtil.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o Classes/Public/CDVConfigParser.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.dia -c /project/CordovaLib/Classes/Public/CDVConfigParser.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVConfigParser.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVGestureHandler/CDVGestureHandler.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVGestureHandler.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        export LANG=en_US.US-ASCII
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVHandleOpenURL/CDVHandleOpenURL.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVHandleOpenURL.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDelegate.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewNavigationDele gate.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewNavigationDelegate.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o Classes/Public/NSMutableArray+QueueAdditions.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.dia -c /project/CordovaLib/Classes/Public/NSMutableArray+QueueAdditions.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/NSMutableArray+QueueAdditions.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o Classes/Public/CDVCommandQueue.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.dia -c /project/CordovaLib/Classes/Public/CDVCommandQueue.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVCommandQueue.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o Classes/Public/CDVPluginResult.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.dia -c /project/CordovaLib/Classes/Public/CDVPluginResult.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPluginResult.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o Classes/Public/CDVPlugin+Resources.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.dia -c /project/CordovaLib/Classes/Public/CDVPlugin+Resources.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin+Resources.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o Classes/Public/CDVURLProtocol.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.dia -c /project/CordovaLib/Classes/Public/CDVURLProtocol.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVURLProtocol.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVUIWebViewEngine/CDVUIWebViewEngine.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVUIWebViewEngine.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o Classes/Public/CDVPlugin.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        cd /project/CordovaLib
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.dia -c /project/CordovaLib/Classes/Public/CDVPlugin.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVPlugin.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVLocalStorage/CDVLocalStorage.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVLocalStorage.o
      CompileC /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavigationFilter.m normal arm64 objective-c com.apple.compilers.llvm.clang.1_0.compiler
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /clang -x objective-c -arch arm64 -fmessage-length=0 -fdiagnostics-show-note-include-stack -fmacro-backtrace-limit=0 -std=c99 -fobjc-arc -fmodules -fmodules-cache-path=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex -fmodules-prune-interval=86400 -fmodules-prune-after=345600 -fbuild-session-file=/Library/Developer/Xcode/DerivedData/ModuleCache.noindex/Session.mod ulevalidation -fmodules-validate-once-per-build-session -Wno-trigraphs -fpascal-strings -Os -Wno-missing-field-initializers -Wno-missing-prototypes -Wno-implicit-atomic-properties -Wno-objc-interface-ivars -Wno-arc-repeated-use-of-weak -Wduplicate-method-match -Wno-missing-braces -Wparentheses -Wswitch -Wunused-function -Wno-unused-label -Wno-unused-parameter -Wunused-variable -Wunused-value -Wempty-body -Wuninitialized -Wno-unknown-pragmas -Wno-shadow -Wno-four-char-constants -Wno-conversion -Wconstant-conversion -Wint-conversion -Wbool-conversion -Wenum-conversion -Wno-float-conversion -Wno-non-literal-null-conversion -Wno-objc-literal-conversion -Wshorten-64-to-32 -Wpointer-sign -Wno-newline-eof -Wno-selector -Wno-strict-selector-match -Wundeclared-selector -Wno-deprecated-implementations -DOBJC_OLD_DISPATCH_PROTOTYPES=1 -isysroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -fstrict-aliasing -Wprotocol -Wdeprecated-declarations -miphoneos-version-min=8.0 -g -Wno-sign-conversion -Wno-infinite-recursion -Wno-comma -Wno-block-capture-autoreleasing -Wno-strict-prototypes -Wno-semicolon-before-method-body -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-generated-files.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap -iquote /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Cordova-project-headers.hmap -I/project/build/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/usr/local/lib/include -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i nclude -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/i phoneos/include -I/project/build -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources/arm64 -I/Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermed iates.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Rele ase-iphoneos/CordovaLib.build/DerivedSources -F/project/build -include /private/project/build/sharedpch/CordovaLib_Prefix-ayityvrhhqbzbnhinaboinneczkl/CordovaLi b_Prefix.pch -MMD -MT dependencies -MF /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.d --serialize-diagnostics /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.dia -c /project/CordovaLib/Classes/Private/Plugins/CDVIntentAndNavigationFilter/CDVIntentAndNavi gationFilter.m -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/CDVIntentAndNavigationFilter.o
      Libtool /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a normal armv7
        export IPHONEOS_DEPLOYMENT_TARGET=8.0
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /libtool -static -arch_only armv7 -syslibroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -L/project/build -filelist /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a
      Libtool /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a normal arm64
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /libtool -static -arch_only arm64 -syslibroot /Applications/Xcode101.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/SDKs/ iPhoneOS12.1.sdk -L/project/build -filelist /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a
      CreateUniversalBinary /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a normal armv7\ arm64
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /libtool -static /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/armv7/libCordova.a /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/CordovaLib.build/Releas e-iphoneos/CordovaLib.build/Objects-normal/arm64/libCordova.a -o /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
      Strip /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
        /Applications/Xcode101.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin /strip -S -T /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
      SetOwnerAndGroup gimlet:staff /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
        /usr/sbin/chown -RH gimlet:staff /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
      SetMode u+w,go-w,a+rX /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
        /bin/chmod -RH u+w,go-w,a+rX /Library/Developer/Xcode/DerivedData/PWCApp-djmesarxzbkusxdqrvetsqxhfrus/Build/Intermedia tes.noindex/ArchiveIntermediates/PWCApp/IntermediateBuildFilesPath/UninstalledProducts/iph oneos/libCordova.a
      === BUILD TARGET PWCApp OF PROJECT PWCApp WITH CONFIGURATION Release ===
      Check dependencies
      Code Signing Error: Provisioning profile "iOS Team Provisioning Profile: net.qazana.example.Music-App" is Xcode managed, but signing settings require a manually managed profile.
      Code Signing Error: Code signing is required for product type 'Application' in SDK 'iOS 12.1'
      ** ARCHIVE FAILED **
      The following build commands failed:
      Check dependencies
      (1 failure)
      Error code 65 for command: xcodebuild with args: -xcconfig,/private/project/cordova/build-release.xcconfig,-workspace,PWCApp.xcworkspace,- scheme,PWCApp,-configuration,Release,-destination,generic/platform=iOS,-archivePath,PWCApp .xcarchive,archive,CONFIGURATION_BUILD_DIR=/private/project/build/device,SHARED_PRECOMPS_D IR=/private/project/build/sharedpch,-UseModernBuildSystem=0
