6 Replies Latest reply on Jan 30, 2008 9:33 AM by wam4
    not getting session variables
    wam4
      I must be missing something. I thought once you set the session variable in the in the application.cfc file and then used cfset on the main page to set the session variable to something it remained active till you logged out/ended the session/browser closed,etc. But mine aren't carrying over from one page of the form to the next page. I also need them to remain if a person goes out of the folder containing the application.cfc page. Do I need to use <cfset session.id = "#form.variable#"> on all the pages or does the application.cfc file need to have this somewhere in my onRequestStart function? If a person goes out of the folder containing the .cfc file and returns to the maintenance page shouldn't the session variable still remain active? Any help is greatly appreciated. Wendy
        • 1. Re: not getting session variables
          Level 7
          That is the way sessions generally work. Do sessions work at all on the
          site? Is it possible that they have been disabled in the ColdFusion
          Administrator. They can be turned off there.
          • 2. Re: not getting session variables
            wam4 Level 1
            Ian, Session variables are enabled in the administrator and set for 2 days before timing out. So what you are telling me is that I need to use client variables instead? Or will these "disappear' if a user goes out the folder containing the application.cfc and then back in to continue updating?
            • 3. Re: not getting session variables
              Level 7
              No, I'm saying that for some reason in your application, session
              variables are not working like they work for 99.9% of the rest of us.
              But I do not know enough about your configuration or code to be able to
              offer more then the most general advice.
              You are looking at this application in a browser with cookies enabled,
              correct? Without cookies or a 'cookieless session implementation' of
              your code, session variables will not persist from one request to another.
              In order for CF to know what request belongs to what session state, it
              needs the CFID & CFTOKEN OR JSESSION values normally stored in cookies.
              They can also be passed back and forth in URL variables if a system
              design as choose to do so. Without these values returned with a
              request, every request is a new session.
              The basic question here is do session work at all for you anywhere but here?
              • 4. Re: not getting session variables
                wam4 Level 1
                I have my cookies set to accept all in my browser and at one time I did notice the cfid and cftoken's being transfered in the URL. I must have changed something.
                In the application.cfc file I added <cfset this.setClientCookies = true> and I'm using <cfoutput>session = #SESSION.emplid#<br></cfoutput> at the top of my page to verify that I am getting the session variable on the first page. That's been working fine.
                I guess what I'm trying to figure out is if I can retain those session variables if the user goes out of the folder and back in to the maintenance page so they can continue working. If not, then how do I force them to log back in. Right now the cflogin allows them to go out and come back without logging back in.
                thanks,
                • 5. Re: not getting session variables
                  Level 7
                  > logging back in.
                  > thanks,
                  Yes, the session will normally persist even if you leave the
                  'application' for which it is set. Of course the session timeout is
                  ticking away. While the user is using another section of the site that
                  is a different or undefined application or even completely different web
                  sites, the session timeout is not being reset. If it expires before
                  they return then the session will no longer exist.
                  But as long as the user returns to the application before the session
                  expires, session variables will still exist. And as long as the browser
                  returns the required session ID's they will be able to access the
                  previous session state.
                  Under normal circumstances, anyway.
                  • 6. Re: not getting session variables
                    wam4 Level 1
                    Thanks Ian, that helped me figure this out.
                    Wendy
