my friend and i are trying to start an educational math channel, which explains math in Arabic via animation, But we're having problems writing a stacked fraction (where the numerator and the denominator are in different lines, separated by a horizontal line) I could write it by hand, but it's not efficient to repeat this process over and over.
I tried to use my little knowledge of coding to write a script that does it for me, but I'm facing a couple of problems, I couldn't fix them, i need help, either with the script or if you could guide me to an existent tool that would be great..
var mainWindow = new Window ("palette", "Fractions", undefined);
var numeratorGroup = mainWindow.add("group");
numeratorGroup.add ("statictext", undefined, "Numerator:");
var myNumerator = numeratorGroup.add ("edittext", undefined, "1");
myNumerator.characters = 45;
var denominatorGroup = mainWindow.add("group");
denominatorGroup.add ("statictext", undefined, "Denominator:");
var myDenominator = denominatorGroup.add ("edittext", undefined, "2");
myDenominator.characters = 45;
var buttonGroup = mainWindow.add("group");
var startButton = buttonGroup.add ("button", undefined, "Write me a fraction");
var cancelButton = buttonGroup.add ("button", undefined, "Cancel");
startButton.onClick = function(){
app.beginUndoGroup("Fractions");
mainFunc();
app.endUndoGroup("Fractions");
cancelButton.onClick = function(){
mainWindow.close()}
mainWindow.show();
function mainFunc(){
var mainComp = app.project.activeItem;
var numerator = mainComp.layers.addText(myNumerator.text);
var denominator = mainComp.layers.addText(myDenominator.text);
centerAnchorPoint(numerator);
centerAnchorPoint(denominator);
var lineWidth = mainComp.layer(1).sourceRectAtTime(mainComp.time, true).width;
var line =mainComp.layers.addShape();
var contents = line.property("ADBE Root Vectors Group");
var shapeRect = contents.addProperty("ADBE Vector Shape - Rect");
var shapeFill = contents.addProperty("ADBE Vector Graphic - Fill");
shapeRect = contents.property("ADBE Vector Shape - Rect");
var rectSize = shapeRect.property("ADBE Vector Rect Size");
var rectPosition = shapeRect.property("ADBE Vector Rect Position");
var rectRoundness = shapeRect.property("ADBE Vector Rect Roundness");
rectSize.expression = "x = Math.max(thisComp.layer(2).sourceRectAtTime().width,thisComp.layer(3).sourceRectAtTime().width); [x, 10]";
rectColor = [1,1,1];
rectRoundness.setValue(0);
numerator.position.expression = "posX = Math.max(transform.position[0],thisComp.layer(2).transform.position[0]);posY = transform.position[1] - 64; [posX, posY]";
line.position.expression ="x1 = Math.abs(thisComp.layer(3).transform.position[0]-thisComp.layer(2).transform.position[0]); y1 = Math.abs(thisComp.layer(3).transform.position[1]-thisComp.layer(2).transform.position[1]);posX = Math.max(thisComp.layer(3).transform.position[0], thisComp.layer(2).transform.position[0]) + x1;posY = Math.min(thisComp.layer(3).transform.position[1], thisComp.layer(2).transform.position[1])+ y1/2;[posX, posY]";
denominator.position.expression = "posX = Math.max(transform.position[0],thisComp.layer(3).transform.position[0]);posY = transform.position[1] + 64; [posX, posY]";
mainWindow.close();
the code works okay, until i need to add another layer then every thing goes crazy + is there a way to group these objects together without precomposing them?
*the centerAnchorPoint function is not mine, i took it from a web search
Are you sure you want this in the After Effects forum? Here is a link to After Effects Scripting forum which I believe is more suitable.
Thanks, I'm going to ask them too, but i'm not sure if there was an existing tool that does that for me, I think it would be better if there was.
