Apparently, Photoshop doesn't have ram to do anything as simple as editing text or saving the file, the file size is about 70mb but worked fine months ago when I first made it for a client and now I went into it to make changes he requested & even if I give it 85-100% ram which I have 16gb of, I still get the stupid not enough memory message!
I also noticed Photoshop won't detect my GeForce graphics card only the Intel integrated card
System:
Microsoft 10 64bit
Nvidia GeForce 940MX
Intel i7-7500U 7th gen @ 2.70GHZ
3840 x 2160 @ 60Hz
I reverted to 19.1.7 & all the issues are solved, it almost feels like every update is more of a screw up than an update. Kind of sad that a multi-billion dollar corporation can't get their crap together & push out fixes / be more involved in their community shows how much they care!
If Photoshop failed to detect your gpu then yes the ram will not be able to get used.
Try shuting down Photoshop and reopen it as normally the sniffer software is the underpinning cause and restarting should bypass the bug
I already tried reopening Photoshop many times and made sure everything on my computer is up to date & restarted my computer, it didn't fix it.
If Photoshop Elements, and not Photoshop, see here:
Error while accessing performance preferences​
If Photoshop, make sure you are using the latest version of CC.
I already tried that whole Registry stuff & it didn't solve it and think it made it worse. I am using the latest version of Photoshop CC.
yes the lastest Photoshop is bugged... I recommend you keep the last Photoshop build as well and use that because no quick fix is coming
I agree that Adobe should do more about bug fixes and they seem slow in that respect, having said that you're the only one that I have seen on the forum with memory issues in version 20.0.1
I have that version installed on 3 PC's and haven't had that issue, there are bugs still in this version but non of them have caused issues with my workflow, I just work around them
Hi
Is this just happening on that particular file or all files, about the GPU issue have you made sure that the drivers for both the Intel and Nvidia are up to date, also take a look here, especially section 7
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
I would undo the registry hack if you haven't already as it's not needed in version 20.0.1
All files I can't even save for web now aswell, its pathetic
