I am new to Lightroom Classic CC. I have set up library and all was working well. Exploring other areas I looked at the web section but didn't finalise anything I did in there. I then looked at Portfolio and tried to find some photos to put into it, Portfolio could not find any. I then opened Lightroom, everything starts as normal and it opens to the library screen set. Then a white, blank, window pops up in front of the Library screens. The only thing the window has is a red button at top left. When you click this Lightroom goes into shut down mode and the query on backing up catalog pop-up appears.
This happens every time I try Lightroom now. I have tried backing up, not backing up and forcing quit, same thing happens
any help most welcome as I am really enjoying Lightroom apart from this.
Many thanks
The situation seems to have resolved itself, luckily as it was not possible to get into any part of the app with the white window flashing.
This seems like a Lightroom Classic question, moving it to that forum for better responses
I would look into the preferences to switch GPU use off. That may be a good starting point.
As youre just at the start, you can also try as a second releave to reset preferences to default. You willl loose any customization you did.
How to set Lightroom Classic CC preferences
If it still does not work as expected update this thread with a screenshot of the screen situation.
