2 Replies Latest reply on Feb 1, 2008 8:54 AM by Newsgroup_User
    cpu 100%
    Level 7
      Hi all,
      I install FB 3 beta 3 on a windows XP pro sp2 with 1.5gb of memory.
      When I'm working on the code the javaw.exe goes to 99% making everything run
      slow.
      Anybody can help me with this?
      Rgds
      JFB
        • 1. Re: cpu 100%
          cxf02
          This is a very open question and has no easy answer without far more information. What is the type of application your working on? What version of Eclipse? Is it the full stack or a plugin? What exactly are you doing when the CPU clocks to 99%? What are your build options set for in Eclipse? But try this first before going any further: http://www.kyrsoft.com/downloads/downloads.html#MemoryMonitor.
          It will give you a means by which to reclaim your memory, but as far as the CPU is concerned, it may not help.
          • 2. Re: cpu 100%
            Level 7
            Thanks for you quick reply.
            My app is a Coldfusion/Flex
            I'm using CF3 beta 3 with eclipse
            Eclipse Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore
            Version: 2.3.0.v200706262000
            Build id: 200706262000
            Full Stack
            Just typing code.
            Where can I see this options? I dont see this in Adobe Flex Builder 3
            I see the memory going to 99% for javaw.exe and when I execute the app I saw
            99% for jrun.exe but this is only for less than a minute that coldfusion is
            call.
            javaw is an issue because i can't type code fast.
            Rgds
