I'm using a Steinberg UR12 2 channel interface.
I'm trying to record a bass guitar track over a song (stereo MP3) that my friend sent me.
I've imported the MP3 and have it on Track 1.
I'm trying to record the bass on Track 2. Set the Input to the Steinberg Chanel 1.
When I arm Track 2 and then hit 'record', not only does Track 2 record the bass guitar, but it's also recording the Stereo file in Track 1 as well with the mono bass track onto Track 2.
I've updated Adobe. And have installed the latest firmware for my Steinberg.
Nothing I'm trying seems to be able to fix this? What is Track 1 being re-routed as an input onto Track 2?
Probably this is happening because you have the 'loopback' function enabled. You should turn this off, otherwise it sends everything you can hear back to the line output - which is what you are recording!
Hi SteveG,
I'll see if I'm able to find this and turn it off.
Ian
Is the 'loopback' function within Audition or on the Steinberg that you're referring to?
SteveG .... you were spot on !!!!
Thank you so very much for your help. All good. I would never have figured this out.
No idea why it turned on this 'loopback' setting in the first place.
I can now go and record my bass track.
You have made my day !!!
Thank you,
Ian
