Hi there, I was using InDesign to experiment with some word art ideas, however when I tried to text wrap around separate objects in line with each other the text inexplicably broke off to the right of the object if there was another object to the left of it. I've attached a screenshot. It seems InDesign possibly doesn't like having to wrap around multiple objects, is there a setting or a workaround for this? Thanks!
Hi jdc5294 ,
best do this with Adobe Illustrator.
There is no restriction for text composition with the number of wrapping objects in a row.
See my Illustrator screenshots: Re: Compound Path as a Text Box
Regards,
Uwe
The same behaviour like here?
Yes, thank you very much. Sorry my googlefu is lacking.
Hi there,
I would like to know if the workarounds shared on the link shared Hans worked for you or the issue still persists.
Kindly update the discussion if you need further assistance with it.
Srishti
Hi jdc5294 ,
Regards,
Uwe
Hi all, the suggestion of subtracting out the shapes was a good thought but unfortunately InDesign still does the same thing. Looks like Illustrator will have to be what I use. Thanks for the help.
