• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Scrolling problems. I can go down but not up )-:
Engaged ,
Jan 13, 2019 Jan 13, 2019
I have been working on publishing a rather large monograph/book length project. So far everything seems to be working well but on this page http://tinyurl.com/y9rt6h9x I have a pesky problem.
Expanding the accordion and clicking on any link works and we get to the desired position in the document. The problem is that after I arrive at my chosen destination if I try to scroll up I get stuck. On some links I may be able to scroll a few screens up but I am soon stopped.
I can only scroll down but not up. Even the Scroll To Top arrow doesn’t work.
Hitting the ← Back Button doesn’t work either.
It is only on this page that this happens not the others. What have I done wrong?
Views
469
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor , Jan 13, 2019 Jan 13, 2019
I found the problem. I'll give you the summary here and tomorrow I will give you a detailed explanation via email.
Your anchor links are going to headings. That's fine. The problem is that those headings are set to animate when scrolled to. When you are in the Accordion, the elements you are linking to are staged off-screen, ready to be animated. This is confusing the browser. I simply assigned a smooth scroll script to your anchor links, and that appears to do the trick.
Votes
Translate
Translate
Mentor ,
I answered your email, as well as your post on our forum. Let's take the issue there and see if we can solve it for you. I did create a clean test page, using your content and behaviors, but with our default CSS and scripts. I also removed your third-party scripts. The issue seems to have disappeared:
http://projectseven.com/testing/customers/branko-01-19/
I'll spend some time reintroducing your other scripts to see if we can find the culprit.
But let's pick this up on our system.
Votes
Translate
Translate
Report
Report
Mentor ,
Votes
Translate
Translate
Report
Report
Engaged ,
Jan 15, 2019 Jan 15, 2019
LATEST
Thank you.
Votes
Translate
Translate
Report
Report
