Is anyone else experiencing issues on Windows? It's been a week since I was last able to open NEF (raw) photos in Photoshop from Lightroom to successfully edit them. Lightroom is very, very slow to being with. When Photoshop finally loads the photos, I cannot add layer masks or use Liquify, to name two examples. Photoshop does work fine IF you open it from outside to work on JPG files.
It is super frustrating to pay for a service that gets repeatedly "broken" after Creative Cloud updates.
[ moved from Adobe Creative Cloud to Lightroom Classic CC — The desktop-focused app]
I reached out to other photographers, and yes, they are reporting similar issues. Is Adobe aware of the problem with the latest update?
First off
This is an Internet Forum, an online place to converse on a common subject. This is not a support page. Mostly just customers sharing information and advice. Rarely will you find an Adobe employee responding.
Now as to your issue with Photoshop not working correctly when sent image(s) from Lightroom Classic Cc.
This is a known problem with the latest Photoshop update, Hopefully it might get fixed in the next update. None of the members of this Forum know.
It is now seen as a very old issue, repeatedly brought up in this forum. I will count to ten, Ok.
Three workarounds, I will list them from probably most tolerable (note I did not say acceptable, or desirable),
1. In PS, in preferences, disable the home screen
or
2. Start PS before sending it image(s) from LR
or
3. Degrade PS back one version.
Thank you for the steps. I have been using CC Lr+Ps for over 3 years and never had any issues bringing files from the former to the latter (perhaps I have missed those updates?). My hardware specs have remained constant over the past year (i7, 32GB, 2GB video, SSD hds). From my perspective as a user, it seems that Lightroom's performance slows down every few updates, which is not ideal but can be dealt with while we await for a new update that addresses whatever "improvements" they had made. Losing Photoshop last week impacted my ability to perform work. This is why I turned to this forum. Thanks again!
Your specs are ok. Switch off the GPU in Lr except if you have high res screens (4k+).
Thanks, Abambo!
I turned it off a while ago when Lightroom "first" became slow (not this time). This is what I have:
Oh, and I have been turning on/off the using smart previews instead of originals as well. It doesn't seem to help. Let me know if you see anything else that needs changing.
The smart previews definitively improve speed, because Lr does not need to load the full res image in memory.
Now as to your much worse issue, performance.
First many members will request you accomplish the following as a baseline. Note that this is a tried and true procedure that eliminates arguments.
In LR, click on Help, click on System Information, click on Copy. Paste results in a reply.
I have several computers. My computer at work configured by IT is super slow on everything. May computers at home, nominally weaker, are fast enough -- I would not say lightning fast with Lightroom, that would be a lie, but fast enough for working with.
Thank you, everyone, for your replies and insight. In my frustration in needing to have a functional Photoshop, I used Windows System Restore. Now Lightroom won't work (load) at all. I will uninstall it and reinstall it later today.
I undid the System Restore and applied the newest update for Photoshop (which was not there yesterday). That solved the issue! I can open NEF files from Lightroom into Photoshop and apply layer masks, use Liquify, etc as usual. It looks like I now have 2 versions.
