I am new to Lightroom-
When I am in Develop mode editing a photo and then switch over to library mode, the photo doesn't look the way it was edited.
Would someone please advise, super frustrating.
Thank you kindly, Ashley
Lightroom CC or Lightroom Classic CC?
LR Classic CC
LR Classic CC
Can you give some more detail?
Perhaps post a couple of screenshots showing what you mean.
First picture in Library mode
Second picture in Develop mode
On first glance they look identical. What are you seeing?
The colors also seem to become little more enhanced and in Library mode. Making it appear overly edited
Notice the clouds for instance- Develop one is soft and creamy- Library one is grainy and textured - which is the one that becomes saved when I export
The Library and Develop modules use different color spaces.
See if this helps How to manage color in Lightroom Classic CC
Do you calibrate and profile your monitor?
Lightroom color issue Develop vs Library modules: Retouching Forum: Digital Photography Review
Will you confirm if Im looking at the right setting page?
At what magnification are you viewing the image? And what magnification were the screenshots created at?
When evaluating (and applying) noise and sharpening, you must view the image at 1:1. Any other view will be inaccurate and misleading because the image has been scaled.
So do you see a difference when viewing at 1:1?
I have posted crops of your first two screenshots below, at 100%.
The first one (from Library) has color artifacts in the sky that looks like jpg compression artifacts. Is the image a jpg?
I typically edit all photos in the fit magnification. I didn't realize 1:1 was needed for noise and sharpening; Im very new to Lightroom and editing for that matter.
Those screenshots were exported as a JPEG- yes- but I edit all pictures in RAW
Any other tips would be appreciated!
So what do you see when you view the image at 1:1 in Library and Develop?
Is there still a difference?
Its better for sure. But will that transfer over when I go to export?
Yes, as long as you view the exported image at 1:1 (100%)
I might be able to give you some more advice if you post a screenshot of the entire Lightroom window with the image of the cross and sky open in Develop at 1:1 (with the noisy area around the cross visible), and with the Histogram and the Basic and Detail panels expanded and visible.
All these panels might not be visible on your screen without scrolling, so post separate screenshots of the panels if required.
How do I check if it's at 100% on 1:1?
Here is another picture with the all the tools visible
You choose magnification in the Navigator on the left hand side of the screen.
If you don't see any panels there, press F7.
Please confirm whether the screenshots you posted are at 1:1 or not.
Some comments on your edits:
In addition to Per Berntsen good suggestions I'll also add that your Basic panel Tone adjustments may be contributing to the differences you're seeing in the Develop and Library module previews. In general it's best to keep the the Highlights and Shadows settings equal and opposite such as -50 Highlights and +50 Shadows. Also keeping Whites in the positive setting region (or 0) and Blacks in the negative or 0 region works best. Using extreme maximum settings (-100) is not recommended or necessary. More on the Basic panel Tone control settings adjustment , which you can download here:
Dropbox - Lightroom Classic CC Basic Panel Tone Control Adjustment Procedure .pdf
Per Berntsen said, "It's possible that the noise reduction is causing the artifacts you see in Fit view in Library. Todd Shaner knows more about this than I do."
As already mentioned extreme settings can cause the Develop and Library module <1:1 previews (Fit, Fill, 1:16, etc.) to look different. This is primarily due to the Develop module using a less accurate and faster nearest neighbor interpolation and the Library module the more accurate and bicubic interpolation for preview generation. This is done to because the Develop module requires real-time preview updates of control adjustments so you can see their effect onscreen.
The Develop module also uses 16 bit/color live image data and ProPhoto RGB color space. The Library module uses 8 bit/color data and the smaller Adobe RGB color space JPEG preview files. This is done to help prevent banding or posterization in the Library module preview, but as you're seeing it doesn't always prevent it. Following the Basic Panel Tone Control Adjustment Procedure and Per Berntsen suggestions should help to prevent these artifacts.Enjoy!
This is so helpful! Little over my head but I'm slowly understanding all the lingo . Thanks a million to you and Per Berntsen ​ for all your help. I really appreciate it! Baby steps, I'll get there..
Todd Shaner​-- is the basic panel control settings adjustment link you sent able to be applied to Lightroom Classic CC?
The Develop module uses a different preview architecture from ALL other modules so do not expect 100% visual match to the other's depending on several factors.
As others have stated, you MUST view both modules at 1:1 (100%) or greater to inspect precise color rendering. Zooming out will sub sample pixels to show you this zoomed out view and between that and the differences in how the two modules preview data, that can produce subtle but visual differences.
Thank you. When you specify, 1:1 "100%"- where do I check the percentage on this?
