I have Oracle ERP and when I open reports its open in Internet Explorer as report format is PDF and the background application is Adobe Acrobat 9 Standard.
When I try to save this PDF on my local computer every time it asks for location to save PDF file however when I uninstall Acrobat 9 and install Adobe DC or Reader it remembers the location of PDF.
Below are the screenshots
New Update and Observations :
I have figured out that if I change the association of Adobe Acrobat Forms Documents to Acrobat Reader so it will open under reader (Latest) software instead of Acrobat 9 Std.
Hi Osamam,
As I understand, you are opening the PDF in Acrobat extension on Internet Explorer and then saving it computer locally.
Then you have mentioned that you uninstall the Acrobat 9 version and install the Adobe Acrobat/ Reader DC version on your machine.
Could you please let us know what exactly you are referring to when you say " It remembers the PDF location'?
Are you trying to say that when you save a new PDF, the Save as window remembers the location?
It would be helpful if you can elaborate on this. Share the exact workflow you do.
We will be waiting for your response.
Regards,
Meenakshi
Much thanks for the feedback
When I don't have Acrobat 9 Std version every time when I save different reports it always remembers the location, for example, I have run the first report and save it on the desktop then after a 2nd report, it remembers the location like my desktop when I click on save button.
But when I have Acrobat 9 Std it always asks for the location.
Waiting for your response
Acrobat 9 is old and outdated, and not compatible with any current operating system, so problems with it are to be expected.
so will newer version resolve this problem for sure?
and what is a new and updated version?
You said yourself it worked well with Reader DC, then it will most likely work well with Acrobat DC, too, which is the current version.
