• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Audio glitch
Guest
Jan 17, 2019 Jan 17, 2019
In spite of republishing the MP4 several times, as well as closing and reopening Captivate, the NeoSpeech voice is cut off at the transition between slides one and two. Any thoughts?
Views
340
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
My practice with the Neospeech agents and the text you enter for each line of text is to add a pause of about 500 milliseconds. Here is an example of how I begin and end my text to speech narration.
Paul Wilson, CTDP
Votes
Translate
Translate
Report
Report
Guest
I had been using the audio track in the timeline and adding a half second by hand and that didn't solve the problem.
Votes
Translate
Translate
Report
Report
Community Expert ,
If the audio is generated from TTS then it will have absolutely no sound before or after the actual clip.  Unfortunately Captivate has always had the habit of truncating clips to remove any silence before or at the end of audio files.  When I say 'silence' here I mean the complete absence of audio data.
With recorded voiceover there is always at least a small amount of audio data being picked up by the microphone even when the voiceover artist isn't speaking.  I usually refer to this as 'dirty silence' because it's not complete silence.  Captivate leaves this in even when it has been reduced down in volume to almost nil.
So if you really want your TTS clips to be protected at the beginning and end, just edit them to copy in a very short section of very low audio.  You can use your computer microphone to record this audio.
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 18, 2019 Jan 18, 2019
LATEST
On occasion I have had the video duration shortened in the slide inadvertently by myself or by a bug in the app. (Can't say for sure which). This created the TTS cut off at the end of the slide as you described.
I stumbled on the fix for this by looking at the Edit Video Timing window and increasing the zoom to 1000 which allowed me to see a lightened area at the end of the timeline. I was then able to drag the end marker a few milliseconds to the end of the timeline in the Edit Video Timing window and resolve the narration cut off problem.
This happened to me when  using a single slide with event video inserted. (Not video across multiple slides)
Hope this helps.
Votes
Translate
Translate
Report
Report
Resources
Help resources
