• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Uploading multiple files in the same form
New Here ,
Jan 17, 2019 Jan 17, 2019
I am having a problem uploading multiple files at the same time. The site we are building is a catalog of sorts, and each item may have anywhere from 1-20 images.
For this discussion, let's say we're uploading three images
The input on the form creates three cffile tags in the form, named img1, img2, img3. Those are working.
After inputting the form, I see three distinct temp files. However, when the <cffile> tag runs, it only uploads the first file. Three times.
I created output that would show all of the variables, and the output shows the three distinct images, but then <cffile> runs and all of the server variables are correct for the first image, but shown three times.
Now, these file names also have to be written to a database, so I have to write the actual file name to the table, with time and date appended on it so that the file names are truly unique. Everything is working for the first file, it's the second and third that are the issue.
The code that generates the input tags:
<cfloop index="i" from="1" to="#imageCount#">
<cfoutput>
<tr>
    <td valign="top" rowspan="2">Image #i#</td>
        <td><cfif #i# is 1>This is the main photo for the item, and will show by default in the inventory.<br /></cfif><cfinput type="file" name="img#i#" id="img#i#" size="50" /></td>
    </tr>
    <tr>
    <td nowrap="nowrap">Description - <cfinput type="text" required="no" name="imgDesc#i#" message="Please enter text for image #i#" size="100" maxlength="100"> </td>
    </tr>
</td>
</cfoutput>
</cfloop>
The code that generates the output:
<cfloop index="i" from="1" to="#form.imageCount#">
<!--- make new file name --->
<cfset theFile = "img"&#i#>
    #theFile#<br />
    <cfset theFile = evaluate(theFile)>
    -the temp file - #theFile#<br />
    <!--- <cffile destination="#fileLocation#" file="#theFile#" action="upload" nameConflict="overwrite"> --->
    **cffile runs**<br />
     <cffile accept="image/jpeg" file="#theFile#" action="upload" destination="#fileLocation#" nameConflict="makeunique">
        --fileName - #CLIENTFILE#<br />
        --clientFileName - #clientFileName#<br />
        --file Location - #fileLocation#<br />
        --serverFileName - #serverFileName#<br />
        --serverFile - #serverFile#<br />
        --serverFileExt - #serverFileExt#<br />
        --date - #dateFormat(now(),"yyyymmdd")#<br />
        --time - #timeformat(now(),"HHMMSS")#<br />
        ---file on the server - #serverFile#<br />
        ---original file name - #CLIENTFILE#<br />
        ---rebuilt file name - #clientFileName#_#session.memberID#_#dateFormat(now(),"yyyymmdd")##timeformat(now(),"HHMMSS")#.#serverFileExt#<br />
<hr />
</cfloop>
And the output I see on the screen:
-the temp file - C:\ColdFusion2018\cfusion\runtime\work\Catalina\localhost\tmp\neotmp13005993552846511814.tmp
**cffile runs**
--clientFileName - testImage1
--file Location - D:\home\elfquestinventory.com\wwwroot\images\uploaded
--serverFileName - testImage16
--serverFileExt - jpg
--date - 20190117
--time - 142050
-the temp file - C:\ColdFusion2018\cfusion\runtime\work\Catalina\localhost\tmp\neotmp7930083167237002815.tmp
**cffile runs**
--serverFileName - testImage17
--date - 20190117
--time - 142050
-the temp file - C:\ColdFusion2018\cfusion\runtime\work\Catalina\localhost\tmp\neotmp2975829891593456969.tmp
**cffile runs**
--serverFileName - testImage18
--date - 20190117
--time - 142050
Any input would be appreciated. I really do NOT want to have to have 20 individual inserts to get to all of the images, because that will be REALLY annoying for users.
Michelle
Views
560
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I have tried writing code to upload multiple files only once.  It was a learning experience, I can tell you.
I asked about it a little over two years ago, for CF10.  I hope this will be able to help you.
https://forums.adobe.com/thread/2158602
HTH,
^ _ ^
Votes
Translate
Translate
Report
Report
New Here ,
Jan 18, 2019 Jan 18, 2019
I had actually read through that thread yesterday before I posted.
It might work, but it seems awful painful. I just don't understand why the variables aren't changing and it's uploading the same file over and over. It seems like an issue actually IN ColdFusion itself. The three temp files are different, and it knows that three different files are there, but it only loads the information from the first.
Makes no sense!
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
I see that you're using CF2018.  This could be a bug.  You could try reporting it to see if there's a fix.  The code I wrote was for CF10 and could be a workaround until such time as your issue is fixed.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Resources
Documentation
